Bruce wrote:
Eric Greenwell wrote: Why is the ability to stall in a steep turn a useful criteria? It sounds like a safety problem to me. I expect it has to do with efficiency. If your CG is such that your control inputs are minimised - you reduce drag. In the case of steep thermalling, it reduces safety - because you can now stall and theoretically spin. There can be few things as frustrating as my experience with my (new to me) Kestrel 19. First flight I wanted to be cautious so set the CG at 35%. Then the day was booming - but with tight strong thermals, and I was continually running out of elevator. Stick against the back stop and the thermal is still tighter. My Cirrus with it's all flying tail never had that problem. Of course you could depart controlled flight if you got too enthusiastic... At 35%, you are a long way from stalling in a steep turn. With a more rearward CG, you would turn tightly enough, but still without enough elevator to stall in a "tight" turn. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
Bruce wrote: Eric Greenwell wrote: Why is the ability to stall in a steep turn a useful criteria? It sounds like a safety problem to me. I expect it has to do with efficiency. If your CG is such that your control inputs are minimised - you reduce drag. In the case of steep thermalling, it reduces safety - because you can now stall and theoretically spin. There can be few things as frustrating as my experience with my (new to me) Kestrel 19. First flight I wanted to be cautious so set the CG at 35%. Then the day was booming - but with tight strong thermals, and I was continually running out of elevator. Stick against the back stop and the thermal is still tighter. My Cirrus with it's all flying tail never had that problem. Of course you could depart controlled flight if you got too enthusiastic... At 35%, you are a long way from stalling in a steep turn. With a more rearward CG, you would turn tightly enough, but still without enough elevator to stall in a "tight" turn. Hi Eric That is the point I was trying to make. With the CG so far forward the behaviour is really benign, but I can't get enough elevator to stall her. Even straight and level the nose just wallows around at the back stop with ~38kt indicated. I will be moving the CG back until I can stall it, or the handling deteriorates, then move it a little forward. There is no virtue in being able to stall in a tight turn, just efficiency in not holding undue control deflection. Bruce |
Need a little more range for your 304S jet? | Marc Ramsey[_2_] | Soaring | 1 | July 22nd 07 01:39 PM |
VOR volume range | kevmor | Instrument Flight Rules | 7 | February 7th 07 10:46 PM |
Long range Wx | Paul kgyy | Piloting | 4 | December 31st 04 04:25 PM |
What is the range of the B-1B? | user | Military Aviation | 10 | December 24th 03 04:15 AM |
Fuel Range | Toks Desalu | Home Built | 2 | November 14th 03 12:51 PM |
