clare, @, snyder.on, .ca wrote:
On Thu, 23 Oct 2003 15:11:37 GMT, Peter Dohm wrote: These engines were used, I assume with some success, in aircraft such as the Jodel D9; and were claimed, by the aircraft plans provider, to produce roughly 24 or 25 horsepower at typical aircraft engine rotational speeds. The Jodel had an empty weight just over 300 pounds, gross weight of about 500 pounds, and supposedly cruised around 60 statute miles per hour with a takeoff run of less than 250 feet and obstacle clearance distance of less than 500 feet. Little has been heard of the D9 or similar aircraft since ultra lights ceased to be foot-launched. Please be aware that the VW engines of 1200 cc and less displacement, and probably the 1300 cc engine as well, had a serious oil pressure problem in long term service. The camshaft of these early engines rode directly in the crankcase halves without bearing liners. As wear occurred, some mechanics attempted to have the mating surfaces of the case halves milled and the complete case line-bored. The process was only partially effective and it was generally impossible to fully restore oil pressure to these engines on any long term basis. Not only that, those cases are Magnesium, and they deteriorate significantly with age. They harden, granulate, and crack. Either start with a later model magnesium case (still risky) or get a new aluminum universal replacement case and go from there. Excellent point. I had forgotten that replacement cases might be available. Who makes them, and who distributes them. Also do you know of a source for new replacement cases and heads for the Corvair? Please also remember that VW engines from relatively new cars with only a few thousand miles of use were dirt cheap in wrecking yards and that new engines were available at very reasonable prices from every VW dealer in both the US and France (were the D9 was designed) when these aircraft were designed and for about two decades after that. Another aircraft using similar power was the Stewart Headwind. Mr. Stewart is still in business selling plans for his designs and has a web site at http://www.StewartAircraft.com/main.html Personally, I agree with BD5ER and JFLEISC that you should treat the 36hp engine as having primarily antique value and choose something else to power your project. Peter Claton Cadmus wrote: I have a 1959 36HP VW engine and would like information and opinions on converting this for use in a small single place homebuilt. Also can anyone tell me or point me to a source of this engines HP and, more importantly, torque vs RPM curve. Thanks Claton - |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
