V-8 powered Seabee
Old October 24th 03, 02:54 PM
Corky Scott
On Thu, 23 Oct 2003 18:38:23 -0500, Barnyard BOb --
I am NOT against auto conversions.
I'm against simplistic auto conversion bull****.
*YOU'RE* the one who doesn't "get it".
Barnyard BOb --
BOb, I think I understand your position , now more than ever. The thing I
don't understand what about this particular conversion you feel falls short
of the mark. It seems they have done their homework, are expecting
realistic power levels of the machine, and have a good start on a number of
hours on it.
So, if you would, spell it out.
I'm not critical of what has been done to date.
They have a good start....
There are issues that I would normally pursue,
but I've had enough of "shoot the messenger"
to last me a while. Especially when I watch
John Stricker unable to get to first base with
some good points.
What exactly were those good points? And what's first base? My
impression is that he asked some questions and the people who
engineered the conversion responded with precise answers. Then
somehow the subject got sidetracked to Cadilacs and the Northstar
system, like that had anything to do with Seabee's flying with a Chevy
LS1 engine.
Time to let go until some
jackoff starts flaming Lycoming and
Continental beyond my capacity to resist
once more.
BOb, lest you forget, **I** was the messenger in this case. I posted
the link to the converted Seabee's.
It's a pretty ****ed up world when it's OK to drop the
hammer at will on certified engines with impunity while any
auto conversion that can get airborne gets a free pass.
Barnyard BOb --
What, it's not ok to question that certified aircraft engines have
seen the zenith of their development and are anachronistic, overpriced
and tempermental? BIG grin here
Auto conversions don't get free passes here but they do get discussed.
May I respectfully direct your attention once again to the subject
heading for the group in which you are reading this: Recreational
Aviation Homebuilt.
Corky Scott
Old October 24th 03, 05:30 PM
Barnyard BOb --
Corky Scott
Does the BIG grin imply that you do not believe this?
Matters not. We've been at our impasse far too long.
I no longer care what you think or do.
Plonk.
Barnyard BOb -- 50 years of flight
Old October 24th 03, 06:33 PM
Corky Scott
On Fri, 24 Oct 2003 11:30:49 -0500, Barnyard BOb --
Corky Scott
Plonk.
BOb Urban, I_am_hurt! You mean after years of gratuitous insults and
nearly automatic acerbic comments to me, you leave the field?
And here I thought your lack of personal attacks against me lately
were a sign that at last I was gaining your respect because so many
auto coversions had been successful lately.
I guess not.
Corky (who wants my tattered battle flag) Scott
PS, you mean you think that certified aircraft engines AREN'T
anachronistic, overpriced and tempermental? Lordy, I thought that was
something everyone could agree on.
Old September 21st 04, 10:46 PM
On Fri, 24 Oct 2003 17:33:02 GMT,
Corky Scott
Plonk.
I guess not.
I talked with the man behind the V8 SeaBee last saterday.
Over 1000 trouble free hours on the LT1 in his own plane.
Several hundred on the doc's LT6.
The LT1 has had the drive apart several times checking for wear - none
found. Engine has not changed compression, oil pressure, oil temp, or
oil consumption since first 20 hour of break-in.
And that "trouble free" IS trouble free. No changes required.
The LT6 has needed some changes in code for theO2 sensors from what I
remember. (2 sensor vs 4 sensor vs no sensor)
Old September 22nd 04, 01:52 AM
Drew Dalgleish
Snip other stuff
The problem with the doc's engine was as soon as he went over 2/3
throttle the computer went to full rich. The problem was solved by
changing to an overseas computer or program for an engine that didn't
have a catalytic converter. Since the change the engine has been
trouble free. before the change the only problem was high fuel
consumption and less power. If I remember all from my visit with the
doc this spring. There's another Sea-Bee getting converted in
centralia this winter.
Old September 25th 04, 12:59 PM
NW_PILOT
I seen one of them Seabee's come in to 59S one day very interesting sight
very loud also not sure what power plant it had in it he has a for sale sign
on the bulletin board at the Simi-FBO on the field.
Corky Scott
Plonk.
I guess not.
Old September 25th 04, 06:23 PM
On Sat, 25 Sep 2004 04:59:57 -0700, "NW_PILOT"
99.9% sure it will be a Franklion six. Virtually impossible to keep
100% legal as traceability of Franklin parts dissapeared a decade or
so ago when the last Franklin parts stock changed hands.
The subject engine, by the way, is an LS1, not an LT1 - my mystake,
and the LS6 is also going into a big Murphy.
Corky Scott
Plonk.
I guess not.
Old October 2nd 04, 11:45 PM
Ted Azito
The bottom line is not that the noncertified engines get a free pass,
or they shouldn't, but that:
1. Certification of the engine, is not required of aircraft with
Experimental/Amateur-Built C of A:
2.Is of no benefit except you get a shorter fly off period:
3.The commonly available choices of certificated engine unless you
can buy a new PT6A-34 are simply ridiculous from any reasonable
standpoint.
I believe if you want a certified engine perhaps you ought to have a
certified airframe to go with it. If type certification improves
powerplants, doesn't it improve airframes as well? To think otherwise
is schizoid, particularly in a world where you can buy easily
rebuildable certificated aircraft and an overhauled museum piece and
prop to match for less than a lot of people are putting into kit
planes.
And as far as the electronic issues go, I don't want FADEC on any
engine, certified or not. I would rather have mechanical FI or a float
bowl carb and a one mag one electric system (like Franklin so
intelligently used as did Shaky Jakes). Actually the most reliable
engine control system in the world is PT Cummins Diesel injection but
that's another story entirely. All hydromechanical.
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Powered Parachute Plans MJC Home Built 4 July 15th 03 07:29 PM
Powered Parachute Plans- correction Cy Galley Home Built 0 July 11th 03 03:43 AM
