Jay wrote:
There is a guy that was (still is?) flying a push pull power pod sea plane with a Mazda 13B in back and a Rotax (I think) in front. Talk about mixing and matching. Maybe he was going for that "disimilar" idea you see in voting flight control systems on the big 'uns. I think you're talking about Ken Welter's old Coot. It burned last year (Jun 2002 IIRC). Ken has since completed a 4-place Coot, although it is currently single-engine Wankel-only. Ken Welter wrote on 13-Mar-2002: Yes I have here is a photo of my twin pack that will go on the 4 place coot that I am starting to build, I installed this pack on my present coot and tested it for 11 hrs and was a bit heavy for it but should work on the bigger one, the front engine is a 670 Rotax snowmobile engine that puts out 125 hp but there is no reason that it should not work with two rotary's however part of the design to stop resonant vibration is to run two very different rpm's so you would run two different gear ratios and I would suggest running a 12a and a 13b, the spag clutches that I used were made by SSK and sold by Morse. Russell Kent |
CORRECTION: the quote from Ken was written 13-Mar-2003.
Russell Kent Russell Kent wrote: Jay wrote: There is a guy that was (still is?) flying a push pull power pod sea plane with a Mazda 13B in back and a Rotax (I think) in front. Talk about mixing and matching. Maybe he was going for that "disimilar" idea you see in voting flight control systems on the big 'uns. I think you're talking about Ken Welter's old Coot. It burned last year (Jun 2002 IIRC). Ken has since completed a 4-place Coot, although it is currently single-engine Wankel-only. Ken Welter wrote on 13-Mar-2003: Yes I have here is a photo of my twin pack that will go on the 4 place coot that I am starting to build, I installed this pack on my present coot and tested it for 11 hrs and was a bit heavy for it but should work on the bigger one, the front engine is a 670 Rotax snowmobile engine that puts out 125 hp but there is no reason that it should not work with two rotary's however part of the design to stop resonant vibration is to run two very different rpm's so you would run two different gear ratios and I would suggest running a 12a and a 13b, the spag clutches that I used were made by SSK and sold by Morse. Russell Kent |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
