![]() Thanks for all leads and tips that you have provided. It seems that what I am after is a single sided headphone like the Telex 750 SS from Sporty's. The original problem with hearing the speaker is that it is mounted behind the back panel and facing the undercarriage. There doesn't seem to be an easy place to mount the speaker box that will allow access to the linkages etc and face the pilot so I guess the previous owner did it this way for a reason. I was thinking that I could just use the the second DIN connection for a headset. This would be a semi permanent installation so the DIN would be useful as it does have the threaded retention collar. Maybe I will replace the plug on the Telex for a DIN and leave it connected. Would this override the speaker or would I have both speaker and headphone at the same time? Tim, do you sell the Telex? Bob 7U On Jan 10, 1:03*pm, Darryl Ramm wrote: On Jan 10, 9:30*am, "Tim Mara" wrote: both of these DIN connectors on the Becker loudspeaker junction box are for Microphone inputs (for 2 seaters) and have leads for Audio output also. The Mic inputs can be selected on the radio itself for dynamic (non-amplified) microphones or amplified (standard) amplified dynamic, electret, or carbon type) microphones on the 3201 via a jumper in the radio you can select either or mic type but not both at once) these connectors also have audio output and ground so you can use headphone from either din connector, you just would have to make a Din connector on a headphone to use this connector. see diagrams and installation on my website "useful info" pagehttp://wingsandwheels.com/useful.htm tim "Bob 7U" wrote in message .... Hi, I have a Becker 3201, connected to a Becker Speaker box (1PL 042) that has two DIN sockets. One is currently being use by the Mic and the other I believe is for a headset. Any ideas where I can get a lightweight headset with the DIN connection? Thanks, Bob 7U The original question was not clear. Is this a motoglider or conventional glider? Is it a headset (with mic) or just a set of heaphones that is wanted? If its a *motorglider I do recommend the Clarity Aloft Fred linked to. I fly with them. However if it is a conventional glider then the level of isolation (~30dB on the Clarity Aloft) is way too high and you miss all those audible cues we need for better gliding (and safety). That may of course be irrelevant if the original issue is needing louder volume becasue of hearing loss. Also headsets like the Clarity Aloft with their expanding foam earpieces are intended to be inserted once per flight and left there. You can't quickly reinsert like you want for a quick engine restart. But those earbuds are a standard size and it is possible to replace the foam type with a slightly less isolation type that is great for quickly donning (but with slightly less isolation). Seehttp://www.darryl-ramm.com/2007/03/clarity-aloft-headset/ The Becker junction box while handy for basic installs is a fairly useless design when using a headset. Becker makes a headset with a DIN plug connection. I have no idea what the headset looks like or if it is any good. You could cut of the leads off a conventional headset and install a din plug. Then you can't use that anywhere else. I would install the 1/4" phone jacks used for a conventional headset (and mic if wanted Switchcraft series 480/PL-68) jacks. I am not sure if there is room inside the junction box to do that but that is what I'd look at first. The 4201 has a nice wiring diagram in the back of the manual. I assume the 3201 manual has a similar diagram. Remember things are likely wired for a dynamic mic, which most new headsets will have. If this is a motorglider, or even an conventional glider and you want a headset with a microphone then it is likely a good idea to mute the conventional microphone in the cockpit. That requires either wiring a conventional phone style mic jack type to suppress the fixed microphone or installing a selector switch for the microphone (you could do that in the junction box). Another choice is to just run a new set of wires for the headphone from the back of the radio and install conventional headset jacks elsewhere. That way you can put the mic selector switch in easy reach on the panel (which is what I have). If you just want a headphone (no mic) I would look at trying to modify the junction box to replace the the stupid DIN socket with a standard 1/4" phone jack. I would stay away from making any type of inline adapter. Too many things to fail or get unplugged. And DIN plugs tend to be less robust than a well installed/high quality phone style plug and since this is a headset or at least headphone it is likely to get accidently pulled on/mishandled. Remember mic phone style plugs are .206" not 1/4" like headphone jacks. Look for parts made by Switchcraft. (Does it show that I *hate* stupid DIN connectors) Darryl |
On Jan 10, 1:15*pm, Bob 7U wrote:
Thanks for all leads and tips that you have provided. It seems that what I am after is a single sided headphone like the Telex 750 SS from Sporty's. The original problem with hearing the speaker is that it is mounted behind the back panel and facing the undercarriage. There doesn't seem to be an easy place to mount the speaker box that will allow access to the linkages etc and face the pilot so I guess the previous owner did it this way for a reason. I was thinking that I could just use the the second DIN connection for a headset. This would be a semi permanent installation so the DIN would be useful as it does have the threaded retention collar. Maybe I will replace the plug on the Telex for a DIN and leave it connected. Would this override the speaker or would I have both speaker and headphone at the same time? Tim, do you sell the Telex? Bob 7U On Jan 10, 1:03*pm, Darryl Ramm wrote: On Jan 10, 9:30*am, "Tim Mara" wrote: both of these DIN connectors on the Becker loudspeaker junction box are for Microphone inputs (for 2 seaters) and have leads for Audio output also. The Mic inputs can be selected on the radio itself for dynamic (non-amplified) microphones or amplified (standard) amplified dynamic, electret, or carbon type) microphones on the 3201 via a jumper in the radio you can select either or mic type but not both at once) these connectors also have audio output and ground so you can use headphone from either din connector, you just would have to make a Din connector on a headphone to use this connector. see diagrams and installation on my website "useful info" pagehttp://wingsandwheels.com/useful.htm tim "Bob 7U" wrote in message .... Hi, I have a Becker 3201, connected to a Becker Speaker box (1PL 042) that has two DIN sockets. One is currently being use by the Mic and the other I believe is for a headset. Any ideas where I can get a lightweight headset with the DIN connection? Thanks, Bob 7U The original question was not clear. Is this a motoglider or conventional glider? Is it a headset (with mic) or just a set of heaphones that is wanted? If its a *motorglider I do recommend the Clarity Aloft Fred linked to.. I fly with them. However if it is a conventional glider then the level of isolation (~30dB on the Clarity Aloft) is way too high and you miss all those audible cues we need for better gliding (and safety). That may of course be irrelevant if the original issue is needing louder volume becasue of hearing loss. Also headsets like the Clarity Aloft with their expanding foam earpieces are intended to be inserted once per flight and left there. You can't quickly reinsert like you want for a quick engine restart. But those earbuds are a standard size and it is possible to replace the foam type with a slightly less isolation type that is great for quickly donning (but with slightly less isolation). Seehttp://www.darryl-ramm.com/2007/03/clarity-aloft-headset/ The Becker junction box while handy for basic installs is a fairly useless design when using a headset. Becker makes a headset with a DIN plug connection. I have no idea what the headset looks like or if it is any good. You could cut of the leads off a conventional headset and install a din plug. Then you can't use that anywhere else. I would install the 1/4" phone jacks used for a conventional headset (and mic if wanted Switchcraft series 480/PL-68) jacks. I am not sure if there is room inside the junction box to do that but that is what I'd look at first. The 4201 has a nice wiring diagram in the back of the manual. I assume the 3201 manual has a similar diagram. Remember things are likely wired for a dynamic mic, which most new headsets will have. If this is a motorglider, or even an conventional glider and you want a headset with a microphone then it is likely a good idea to mute the conventional microphone in the cockpit. That requires either wiring a conventional phone style mic jack type to suppress the fixed microphone or installing a selector switch for the microphone (you could do that in the junction box). Another choice is to just run a new set of wires for the headphone from the back of the radio and install conventional headset jacks elsewhere. That way you can put the mic selector switch in easy reach on the panel (which is what I have). If you just want a headphone (no mic) I would look at trying to modify the junction box to replace the the stupid DIN socket with a standard 1/4" phone jack. I would stay away from making any type of inline adapter. Too many things to fail or get unplugged. And DIN plugs tend to be less robust than a well installed/high quality phone style plug and since this is a headset or at least headphone it is likely to get accidently pulled on/mishandled. Remember mic phone style plugs are .206" not 1/4" like headphone jacks. Look for parts made by Switchcraft. (Does it show that I *hate* stupid DIN connectors) Darryl Plugging in headphones to the DIN connector will not take the speaker out of the circuit (or the mic) things that are easy to do with phone jacks. That may or may not be what you want. It may be more important to switch out the mic. I've seen problems with the cockpit mic and air vents blowing on them etc.. You could add a remote switch if needed. There is no way to relocate the speaker box? To the side of the pilot's head? Darryl |
FS: Becker Transponder | Fox Two | Soaring | 2 | October 29th 10 11:55 PM |
Becker vs Microair | Dixie Sierra | Soaring | 31 | August 19th 08 06:02 PM |
Looking for a Becker AR3201 | Ira Blieden | Soaring | 0 | December 8th 06 01:38 PM |
Becker radio AD | Tom Serkowski | Soaring | 3 | November 2nd 04 01:43 AM |
Microair vs Becker | Ian McPhee | Soaring | 0 | August 30th 03 09:45 PM |
