Compass Correction Card
Old January 25th 10, 02:39 PM posted to rec.aviation.soaring
John Smith
Default Compass Correction Card
Am 25.01.10 15:11, schrieb jcarlyle:
I have the advantage of reading it in English, no ad hoc translation
required. And yes, it is exactly as I posted above, a compass is on
both the minimum equipment list and on the cloud flying list. Since a
LS1f driver also has a compass on the minimum equipment list, it looks
like the fish is rotting on your side.
A bit harsh, considering the German manual is the one on on which the LS
8 has been type certified. So maybe your FAA has added something to the
requirements, or maybe you're talking about a motorised LS8.
Old January 25th 10, 03:01 PM posted to rec.aviation.soaring
jcarlyle
Ah, well, there you're wrong again. The LS8 wasn't FAA type certified
on the German manual, but rather on the English one, according to the
references in the TCDS. The TCDS came about 2 years after my plane was
built, too. The manual I'm quoting refers to the motorless version,
and it definitely has a compass in the MEL.
-John
Old January 25th 10, 03:55 PM posted to rec.aviation.soaring
John Smith
Am 25.01.10 16:01, schrieb jcarlyle:
If you have missed it: The LS is (was) a German factory, and the LS8 has
been first certified by the German LBA on the basis of JAR-22 (more
precisely: JAR-22, state of October 1985). Neither JAR-22 nor the
original German manual, which has been approved by the certifying
authorities, ask for a compass (or a magnetic direction indicator, as it
is officially called).
So if your manual prescribes one, then the only reason I can see is your
FAA asking for that addition. It is definitely not needed on this side
of the pond.
Old January 25th 10, 05:09 PM posted to rec.aviation.soaring
jcarlyle
I didn't miss a thing - you did. You publically doubted that I could
read what in fact clearly appears in my manual. Now, faced with facts,
you're back-pedaling into "well, maybe it's in your manual but it
isn't in mine". Just because you're assuming things doesn't make me
wrong, you know.
Still waiting for that apology...
-John
of the pond.
Vertical card compass? Bubba[_2_] Home Built 1 March 31st 07 12:49 AM
Vertical Card Compass? Bubba[_2_] Products 0 March 30th 07 06:58 PM
Vertical Card Compass Bubba[_2_] General Aviation 0 March 30th 07 06:56 PM
Vertical Card Compass? Bubba[_2_] Aviation Marketplace 0 March 30th 07 06:56 PM
Airpath C2400 compass correction card template ? [email protected] Soaring 4 March 9th 07 06:55 PM
