Need Help with VOR error adjustment
Old February 5th 10, 11:09 AM posted to rec.aviation.owning
EK[_2_]
Default Need Help with VOR error adjustment
Thanks Bill.
How is the adjustment made for minor deviation? Is it on the indicator or
the radio? Appreciate your input.
PiperFlyer
" wrote in message
On Feb 3, 5:38 am, "PiperFlyer" wrote:
King KI-209 with MX170B, shows an error of 30 degrees. Is there an
adjustment screw on the indicator or a correction potentiometer on the
radio
to correct the error? I work weekdays and the avionics shops are open only
on weekdays.
There is an adjustment. But: If it's off by 30 degrees, there is
something
wrong with the unit. The adjustment does not have anywhere near that
range.
Bill Hale BPPP Instructor
Fix radios part time.
Old February 26th 10, 10:32 PM posted to rec.aviation.owning
On Feb 5, 4:09*am, "EK" wrote:
Thanks Bill.
" wrote in message
209
You remove the upper left mounting screw. Stick a long, flat blade
screwdriver
in there to access a 1 turn pot about 2 1/2" behind the panel.
I think the range is in the neighborhood of ten degrees.
Bill Hale
radio
on weekdays.
There is an adjustment. *But: *If it's off by 30 degrees, there is
something
wrong with the unit. *The adjustment does not have anywhere near that
range.
Old March 7th 10, 01:50 PM posted to rec.aviation.owning
PiperFlyer
Thanks for the info. Appreciate it.
" wrote in message
On Feb 5, 4:09 am, "EK" wrote:
Thanks Bill.
" wrote in message
209
screwdriver
Bill Hale
radio
only
on weekdays.
something
range.
PZL vario zero adjustment. [email protected] Soaring 1 September 29th 07 03:38 AM
ARC RT385A CDI Adjustment facpi General Aviation 3 October 19th 06 11:52 PM
KI-209 VOR/LOC/GS Indicator adjustment kontiki Owning 13 April 25th 05 11:35 PM
Brake adjustment on the 2-33 GM Soaring 11 April 19th 05 07:05 PM
Adjustment of Altimeter Ron Home Built 5 April 5th 04 03:12 AM
