Gel coat removal - water sanding vs. straight line sanding
Old February 6th 10, 10:23 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Gel coat removal - water sanding vs. straight line sanding
On Feb 6, 3:56*pm, LS3 Pilot wrote:
Well, specifically, what about this one?
http://www.google.com/products/catal...en&show=dd&cid...
Sand dry. Use a vacuum of some sort if you want to try and keep dust
in the area to a minimum. Didn't want to hear that either, did you?
Steve
Old February 6th 10, 10:31 PM posted to rec.aviation.soaring
Craig[_2_]
in the area to a minimum. *Didn't want to hear that either, did you?
Steve
One of more than a few reasons I don't do it for a living anymore.
Craig
Sanding of plywood before epoxy [email protected] Home Built 6 July 15th 08 01:21 PM
Sanding or Waxing - PIK 20 Question culverflyer Soaring 22 September 22nd 05 09:01 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
