On Feb 8, 7:00*pm, "Morgans" wrote:
"jsbrake" wrote I'm probably not going to like the answer... I'm very glad that the gelcoat on my mistress is in great shape. *I can't imagine a reason to remove all of the gelcoat off of anything. *In refinishing, you get down as deep as needed in problem areas and then build it back up, scuff up the rest, and shoot a new thin even coat on the whole thing, and be done with it. *Thin is the key; don't put on more than you took off. -- Jim in NC I have seen several examples where someone attempted to remove only the "bad gelcoat" layer. In a year or two it looked terrible! |
![]() "mike" wrote I have seen several examples where someone attempted to remove only the "bad gelcoat" layer. In a year or two it looked terrible! Oh, yes, the devil is in the details, isn't it. There are degrees of bad. If the bad is cosmetic, i.e., scratches and oxidation, a removal of the surface and reapplication of a compatible (ah, more details that can be the devil) new layer will look fine. If there is degradation of the jelcoat to fiberglass/carbon fiber/Kevlar bonding, then the detail is the devil. Nothing to do but to take it all off. This is a case where working with someone that can teach the ins and outs of fiberglass work can be invaluable, or valuable enough to save many man-hours and material bucks. -- Jim in NC |
On Feb 8, 10:11*pm, "Morgans" wrote:
"mike" wrote I have seen several examples where someone attempted to remove only the "bad gelcoat" layer. In a year or two it looked terrible! Oh, yes, *the devil is in the details, isn't it. There are degrees of bad. *If the bad is cosmetic, i.e., scratches and oxidation, a removal of the surface and reapplication of a compatible (ah, more details that can be the devil) new layer will look fine. I can't imagine a reason to remove all of the gelcoat off of anything. This is a case where working with someone that can teach the ins and outs of fiberglass work can be invaluable, or valuable enough to save many man-hours and material bucks. -- Jim in NC You mentioned, " I can't imagine a reason to remove all of the gelcoat off of anything." and then in a following post, " If there is degradation of the gelcoat to fiberglass/carbon fiber/ Kevlar bonding, then the detail is the devil. Nothing to do but to take it all off." I was addressing your first dictum. Mike |
![]() "mike" wrote You mentioned, " I can't imagine a reason to remove all of the gelcoat off of anything." and then in a following post, " If there is degradation of the gelcoat to fiberglass/carbon fiber/ Kevlar bonding, then the detail is the devil. Nothing to do but to take it all off." I was addressing your first dictum. You got me on that one. OK, how about, I can't imagine removing all of the jelcoat unless it was already trying to remove itself. g -- Jim in NC |
Hello,
Having refinished only a shk which is primarily wood construction with fiberglass cockpit and leading edges, IMHO if you decide to purchase a pneumatic (air) driven sander, dual action orbital or "air file" there is a world of difference between quality tools and Harbor freight cheap imports. I recomend Hutchins brand tools, powerful, smooth action, and easy on air demand. also you can use a water flood with air tools. For heavens sake wear a high quality air mask, that previous comment of not needing one because the particles are too big is B.S. and dangerous! As an ICU RN I work with pulmonologists every day and ran that one by them, one simply stated "I wouldn't breath that with your lungs" As far as time required, I removed three complete top coats of paint (about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours. B.T.W. prestec products ROCK! Good luck and best wishes! Scott W. |
(about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours. B.T.W. prestec products ROCK! Good luck and best wishes! Scott W. 1100 hrs... divide by 20 hours/week = 55 weeks , just over a year of working in the shop after the full-time job. YIKES! I'm really, really glad I've got good ol' Scwabbelack (spelling?) on my Kestrel... original 1972 gelcoat in great shape. |
On Feb 10, 1:27*pm, jsbrake wrote:
As far as time required, I removed three complete top coats of paint (about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours. B.T.W. prestec products ROCK! Good luck and best wishes! Scott W. 1100 hrs... divide by 20 hours/week = 55 weeks , just over a year of working in the shop after the full-time job. YIKES! *I'm really, really glad I've got good ol' Scwabbelack (spelling?) on my Kestrel... original 1972 gelcoat in great shape. 650 man hrs for club members to refinish ASK-21. Gelcoat off, fill, contour, respray in acrylic urethane. About 1/2 that for ASW-19 in gelcoat. Good news is no need to go to gym for upper body exercise. My doctor says that, for a fat guy, I have pretty good arms and shoulders. LOL UH |
![]() "shkdriver" wrote Hello, Having refinished only a shk which is primarily wood construction with fiberglass cockpit and leading edges, IMHO if you decide to purchase a pneumatic (air) driven sander, dual action orbital or "air file" there is a world of difference between quality tools and Harbor freight cheap imports. I recomend Hutchins brand tools, powerful, smooth action, and easy on air demand. also you can use a water flood with air tools. I can only agree with the comment to buy quality air tools, made by any of a number of manufacturers. The difference in air consumption between a cheap one and a better one doing the same amount of work can easily be twice as much air being consumed by the cheap one. No kidding. -- Jim in NC |
On Feb 9, 7:42*pm, shkdriver
wrote: Hello, Having refinished only a shk which is primarily wood construction with fiberglass cockpit and leading edges, IMHO if you decide to purchase a pneumatic (air) driven sander, dual action orbital or "air file" there is a world of difference between quality tools and Harbor freight cheap imports. I recomend *Hutchins brand tools, powerful, smooth action, and easy on air demand. also you can use a water flood with air tools. For heavens sake wear a high quality air mask, that previous comment of not needing one because the particles are too big is B.S. and dangerous! As an ICU RN I work with pulmonologists every day and ran that one by them, one simply stated "I wouldn't breath that with your lungs" As far as time required, I removed three complete top coats of paint (about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours. B.T.W. prestec products ROCK! Good luck and best wishes! Scott W. -- shkdriver Scott..............Prestec isn't a PU product is it? I'll be looking at a total paint job of the HP-24 sometime soon. Right now it is all bare carbon. Can't decide if I want to go with Simtec products or use a 2-pack PU. a-la PPG concept. Brad |
On Feb 10, 9:55*pm, Brad wrote:
On Feb 9, 7:42*pm, shkdriver wrote: Hello, Having refinished only a shk which is primarily wood construction with fiberglass cockpit and leading edges, IMHO if you decide to purchase a pneumatic (air) driven sander, dual action orbital or "air file" there is a world of difference between quality tools and Harbor freight cheap imports. I recomend *Hutchins brand tools, powerful, smooth action, and easy on air demand. also you can use a water flood with air tools. For heavens sake wear a high quality air mask, that previous comment of not needing one because the particles are too big is B.S. and dangerous! As an ICU RN I work with pulmonologists every day and ran that one by them, one simply stated "I wouldn't breath that with your lungs" As far as time required, I removed three complete top coats of paint (about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours. B.T.W. prestec products ROCK! Good luck and best wishes! Scott W. -- shkdriver Scott..............Prestec isn't a PU product is it? I'll be looking at a total paint job of the HP-24 sometime soon. Right now it is all bare carbon. Can't decide if I want to go with Simtec products or use a 2-pack PU. a-la PPG concept. Brad- Hide quoted text - - Show quoted text - I recommend PPG Concept (90288 super white) with PCL polyprimer (907 white) for primer. You must be very careful when spraying acrylic urathane, this stuff can kill you! Get a respirator with hose outside the spray booth, use plastic gloves, hat and glasses leaving no exposed skin. You will need about 3 gallons of mixed product which means 2 gal of paint, 1 gal of catalist and half gal of thinner ($1000 bucks or so). Spray on 4 medium coats or until you get good orange peal everywhere which is an indication you have enough paint on. Let it cure out for 24 hours at 70 degrees, then block sand (wet) with 600 followed by 800. I spray on guide coat (spray can) before hitting it with 600 then use the black powder rubbed on in the area before hitting it with 800. Then let it cure out for a good 3 more days before buffing with a wool pad and liquid rubbing compound. Hope this helps, JJ |
Sanding of plywood before epoxy | [email protected] | Home Built | 6 | July 15th 08 01:21 PM |
Sanding or Waxing - PIK 20 Question | culverflyer | Soaring | 22 | September 22nd 05 09:01 PM |
Advice on sanding fibreglass | [email protected] | Home Built | 12 | April 28th 05 10:39 PM |
Sanding composites | [email protected] | Home Built | 12 | January 31st 05 06:47 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
