Gel coat removal - water sanding vs. straight line sanding
Old February 9th 10, 07:17 AM posted to rec.aviation.soaring
Morgans[_2_]
Default Gel coat removal - water sanding vs. straight line sanding
"mike" wrote
You mentioned, " I can't imagine a reason to remove all of the gelcoat
off of anything."
and then in a following post,
" If there is degradation of the gelcoat to fiberglass/carbon fiber/
Kevlar
bonding, then the detail is the devil. Nothing to do but to take it
all
off."
I was addressing your first dictum.
You got me on that one.
OK, how about, I can't imagine removing all of the jelcoat unless it was
already trying to remove itself. g
Jim in NC
Old February 10th 10, 03:42 AM
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Hello,
Having refinished only a shk which is primarily wood construction with fiberglass cockpit and leading edges, IMHO if you decide to purchase a pneumatic (air) driven sander, dual action orbital or "air file" there is a world of difference between quality tools and Harbor freight cheap imports.
I recomend Hutchins brand tools, powerful, smooth action, and easy on air demand. also you can use a water flood with air tools.
For heavens sake wear a high quality air mask, that previous comment of not needing one because the particles are too big is B.S. and dangerous!
As an ICU RN I work with pulmonologists every day and ran that one by them, one simply stated "I wouldn't breath that with your lungs"
As far as time required, I removed three complete top coats of paint (about 75 lbs worth) and primers and fillers. brought up the new coatings and used polyurethane top coat, 18 meter wings, 4 foot wing root, big constant taper fuse, about 1100 hours.
B.T.W. prestec products ROCK!
Good luck and best wishes!
Scott W.
Old February 10th 10, 06:27 PM posted to rec.aviation.soaring
jsbrake[_2_]
Good luck and best
wishes!
Scott W.
1100 hrs... divide by 20 hours/week = 55 weeks , just over a year of
working in the shop after the full-time job.
YIKES! I'm really, really glad I've got good ol' Scwabbelack
(spelling?) on my Kestrel... original 1972 gelcoat in great shape.
Old February 10th 10, 07:58 PM posted to rec.aviation.soaring
Good luck and best
wishes!
Scott W.
YIKES! *I'm really, really glad I've got good ol' Scwabbelack
650 man hrs for club members to refinish ASK-21. Gelcoat off, fill,
contour, respray in acrylic urethane.
About 1/2 that for ASW-19 in gelcoat.
Good news is no need to go to gym for upper body exercise. My doctor
says that, for a fat guy, I have pretty good arms and shoulders.
LOL
UH
Old February 11th 10, 05:30 AM posted to rec.aviation.soaring
Morgans[_2_]
"shkdriver" wrote
Hello,
imports.
I can only agree with the comment to buy quality air tools, made by any of a
number of manufacturers. The difference in air consumption between a cheap
one and a better one doing the same amount of work can easily be twice as
much air being consumed by the cheap one. No kidding.
Jim in NC
Old February 11th 10, 05:55 AM posted to rec.aviation.soaring
Brad[_2_]
On Feb 9, 7:42*pm, shkdriver
Hello,
imports.
I recomend *Hutchins brand tools, powerful, smooth action, and easy on
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Scott..............Prestec isn't a PU product is it?
I'll be looking at a total paint job of the HP-24 sometime soon. Right
now it is all bare carbon. Can't decide if I want to go with Simtec
products or use a 2-pack PU. a-la PPG concept.
Brad
Old February 11th 10, 02:56 PM posted to rec.aviation.soaring
JJ Sinclair
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Brad- Hide quoted text -
- Show quoted text -
I recommend PPG Concept (90288 super white) with PCL polyprimer (907
white) for primer. You must be very careful when spraying acrylic
urathane, this stuff can kill you! Get a respirator with hose outside
the spray booth, use plastic gloves, hat and glasses leaving no
exposed skin. You will need about 3 gallons of mixed product which
means 2 gal of paint, 1 gal of catalist and half gal of thinner ($1000
bucks or so). Spray on 4 medium coats or until you get good orange
peal everywhere which is an indication you have enough paint on. Let
it cure out for 24 hours at 70 degrees, then block sand (wet) with 600
followed by 800. I spray on guide coat (spray can) before hitting it
with 600 then use the black powder rubbed on in the area before
hitting it with 800. Then let it cure out for a good 3 more days
before buffing with a wool pad and liquid rubbing compound.
Hope this helps,
JJ
Old February 11th 10, 05:20 PM posted to rec.aviation.soaring
Brad[_2_]
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
followed by 800. *I spray on guide coat (spray can) before hitting it
Hope this helps,
JJ
Hey JJ,
This sounds like what I'll end up doing. I'll probably spray the
Polyprimer myself (this is a polyester right?). Then..........I'll
sand the primer, fill pin holes, repeat as needed, then take it to a
pro to have the top coat/PPG sprayed on.
My backyard tarp shed probably won't work!
Brad
Old February 11th 10, 09:52 PM posted to rec.aviation.soaring
JJ Sinclair
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Hope this helps,
JJ
Hey JJ,
Brad, Have a talk with the painter to make sure you're both on the
same page. An auto paint shop will normally give it 2 coats and it
should come out bright and shinny and that might be all you want. In
this case you want to do final sanding with 220 grit. If, on the other
hand, you wish to wet sand it as in my earlier post, you need 4 coats
with orange-peal. The painter will think your nuts, just tell him you
need lots of paint so's you can sand one coat off and have it
perfectly smooth, which his car paint job isn't. For a 4 coat job,
the final sanding can be done with 80 grit on a long board followed by
a pass with 150 (hand sanded) to knock down the high scratch marks.
This gives your paint good 'tooth' and you shouldn't be pulling any
paint when removing wing tape. The 80 grit scratch marks will
disappear after the second coat of paint is applied. Many auto paint
shops aren't ready to do a 25' wing and will probably end up with lots
of over-spray...........not a problem if your going to wet sand later.
I think 4 coat then wet sanded and buffed is the way to go. Williams
Soaring has a paint booth and Rex can deliver whatever you wish. I saw
an RV-8 he painted with 2 passes and it looked great.
Have fun,
JJ
Old February 12th 10, 01:11 AM posted to rec.aviation.soaring
Papa3
Hello,
imports.
dangerous!
Good luck and best
wishes!
Scott W.
shkdriver
Hope this helps,
JJ
Hey JJ,
perfectly smooth, which his car paint job isn't. For a *4 coat job,
Have fun,
JJ- Hide quoted text -
Hey JJ,
Scratching my head a bit on this one. I think what you were driving
at is that the final primer coat is left at 150 grit, followed by the
four coats of top coat. Or did I miss something?
P3
Sanding of plywood before epoxy [email protected] Home Built 6 July 15th 08 01:21 PM
Sanding or Waxing - PIK 20 Question culverflyer Soaring 22 September 22nd 05 09:01 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
