Transponder article updated with Trig info
Old February 12th 10, 09:18 PM posted to rec.aviation.soaring
Eric Greenwell
Default Transponder article updated with Trig info
JJ Sinclair wrote:
Eric,
I tow with my transponder on and I'm hoping this will protect me and
my tow plane from a Boulder type scenario.
Your thoughts appreciated,
JJ
It could help, if you are towing where radar can reach you, and the
other aircraft has a PCAS or has flight following from ATC. If radar
does reach you, then having your own PCAS will help, too.
It _will_ help if a TCAS equipped aircraft approaches, because they
don't need radar or ATC contact for TCAS to work.
It might be appropriate to inform the local Approach people when you
begin towing, so they can pass on the info to pilots they talk to.
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Jan/2010" also ADS-B, PCAS, Flarm tinyurl.com/yg76qo9
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
TRIG TT21NOW IN STOCK Tim Mara[_2_] Soaring 5 September 29th 09 10:29 PM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
Seeking KT-79 transponder install/operational info [email protected] Owning 7 July 26th 06 01:11 PM
