Help !! Ventus CM- engine stuck
Old February 16th 10, 03:14 AM posted to rec.aviation.soaring
hoss
Default Help !! Ventus CM- engine stuck
After stowing the engine on a self-launch I heard a high pitched
whine. I turned off the circuit breakers.. The problem is now I can
not extend the engine. The circuit breaker will pop if it is reset.
Any ideas on how to extend a stuck engine? ( other than cutting a hole
in the side of the fuselage)
Old February 16th 10, 05:10 AM posted to rec.aviation.soaring
Brad[_2_]
unbolt the jack screw?
Brad
Old February 16th 10, 05:43 AM posted to rec.aviation.soaring
Craig[_2_]
Brad
If it comes down to cutting, I'd rather have to repair an engine bay
door than get into the fuselage structure.
Craig
Old February 16th 10, 06:16 AM posted to rec.aviation.soaring
hoss
Brad
Craig
You can manually pull open the engine bay doors and then unbolt them. I just wasn't sure if unbolting the jackscrew actuator was the only option.
Ken
Stuck ident Bob Noel[_6_] Owning 4 September 14th 09 03:41 AM
Stuck Canopy David Hartung Aviation Photos 2 June 21st 07 05:08 AM
Stuck Collective Linc Rotorcraft 4 November 27th 06 06:07 PM
Ever stuck your neck out too far? And got away with it? pacplyer Piloting 31 January 2nd 04 06:21 AM
Ever stuck your neck out too far? And got away with it? pacplyer Home Built 26 January 2nd 04 04:04 AM
