vfr on top
Old February 15th 10, 06:51 AM posted to rec.aviation.ifr
Myname
Default vfr on top
What are the advantages of vfr-on-top in the real world? I understand the
ifr to vfr-on-top then cancel, but what about other uses?
Old February 15th 10, 10:11 AM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default vfr on top
the ifr to vfr-on-top then cancel, but what about other uses?
Well, what are the advantages of IFR to VFR-on-top then cancel?
Old February 15th 10, 10:21 AM posted to rec.aviation.ifr
Mxsmanic
Default vfr on top
Myname writes:
The main advantage is that it allows a pilot to choose his altitude at his
discretion, within broad limits, rather than request approval for every change
of altitude from ATC.
Old February 15th 10, 05:03 PM posted to rec.aviation.ifr
Default vfr on top
On Feb 15, 4:11*am, "Steven P. McNicoll"
Well, what are the advantages of *IFR to VFR-on-top then cancel?
To legally punch a cloud deck.
I have done this several times on a 50NM trip where it was VFR at my
destination.
It's easier to cancel in the air with KJAN once I am 1000 foot above
the cloud deck then to have to call FSS to cancel my IFR.
I would only be with Memphis center a mere 3 to 5 minutes before
initiating a descent below radar coverage so I can't cancel with them
on the ground.
Old February 20th 10, 06:46 AM posted to rec.aviation.ifr
A Guy Called Tyketto
Default vfr on top
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mxsmanic wrote:
Myname writes:
You can already do that with VFR w/flight following.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
iD8DBQFLf4VLyBkZmuMZ8L8RAvhqAJwPt2twDJ17gZuIASVZMz r2jz3nDACfbybn
41Yw8FCdcXUnRaeVLoSN0ts=
=pFbw
-----END PGP SIGNATURE-----
Old February 20th 10, 07:46 AM posted to rec.aviation.ifr
Mxsmanic
Default vfr on top
A Guy Called Tyketto writes:
Not if you have to fly through clouds to get to your cruising altitude. While
you have the option of cancelling IFR once you are in VMC, ATC is not required
to provide flight following, whereas it is required to accommodate IFR.
Old February 20th 10, 04:43 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default vfr on top
destination.
on the ground.
That's not "IFR to VFR-on-top then cancel", that's IFR to punch
through a cloud deck then cancel upon reaching VFR conditions. You're
not VFR-on-top until you've been cleared to maintain VFR-on-top and
you can't be cleared to maintain VFR-on-top until you've reported
reaching VFR-on-top.
Old February 20th 10, 04:46 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default vfr on top
On Feb 15, 4:21*am, Mxsmanic wrote:
Myname writes:
You can do that under VFR with even broader limits on altitude and the
additional advantage of altering your route at your discretion.
Old February 20th 10, 04:49 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default vfr on top
Required to accommodate IFR? If traffic or SUA does not allow the
issuance of that IFR clearance to climb through the clouds it's not
going to be issued.
Old February 20th 10, 06:38 PM posted to rec.aviation.ifr
Mxsmanic
Default vfr on top
Steven P. McNicoll writes:
going to be issued.
ATC cannot deny service to IFR flights once a clearance has been issued, so
once you've started your IFR flight they cannot cut you off. Flight following,
on the other hand, is at the discretion of ATC, based on the controllers'
workload and other considerations. So, while you're guaranteed to continue
getting IFR services once you've got them, if you cancel IFR and then request
flight following, there's no guarantee that you'll get it.
