Could Blackjack bombers reach USA?
Old January 18th 04, 11:39 AM
Cub Driver
What about it's range? Could the BlackJack bomber have taken off in
the Soviet Union and bombed the United States?
Well, a late-model Piper Cub could take off in the former USSR and
bomb the United States, or at least that portion of it that is
inhabited by Alaskans.
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old January 18th 04, 01:43 PM
BUFDRVR
Say what ?
Larger than a B-52 even ?
Actually, yes, but only slightly.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old January 18th 04, 02:03 PM
BUFDRVR
Anyway
do you have any doubts about the question asked
"Could Blackjack bombers reach USA?"
Perhaps, but only a very few. Their mission capable rates were as low as 25%,
and that was in 1995.
I've told this story before, but its a good one and still makes me chuckle. In
1995 Barksdale AFB was host to two Russian Bear Bombers (Tu-95), their crews
and leadership. On the second day of their visit, several BUFF and Bear crews
were out on the flightline exchanging tours of their respective aircraft. A
B-1B from Dyess had weather diverted into Barksdale the previous night and as
the BUFF and Bear crews were doing their exterior tour of the Bear, the B-1B
attempted to leave and head back to Dyess. Due to the tremendous noise the B-1
created as it took off, all conversation, both Russian and translated English
stopped and everyone diverted their attention to the B-1 taking off. As the
B-1 got halfway down the runway, and almost directly in front of the Bears, a
puff of white smoke appeared and the throttles were brought back to idle.
Everyone continued to watch as the B-1 taxied to the end of the runway where it
was joined by emergency response vehicles. As the B-1 made the turn off the
runway, hydraulic fluid could be seen, literally, pouring out from underneath
the aircraft. The B-1 stopped, the entry hatch opened and the crew performed an
emergency egress. With the noise now gone, both BUFF and Bear crews returned
their attention to the exterior of the Bear. Before the tour could resume, one
of the Bear crewmembers looked at the others and uttered something in Russian
which made the rest of the Bear crewmembers burst out in laughter. When a BUFF
squadron commander asked what the joke was, the translator looked afraid to
answer. Just then in pretty good English, one of the Bear crewmembers pointed
to the B-1B, now in the hammerhead and surrounded by emergency vehicles and
said; "Just like Tu-160....piece of ****". At that, all the BUFF crews began to
roar with laughter, which made the Bear crews, and their concerned translator,
more relaxed and they began to laugh out loud again. It was truely a moment of
international bonding, crews of bombers built in the 1960s having a laugh at
the expense of their newer "replacement aircraft". Any way, when asked about
the Tu-160's mission capable rate, a rather gruff Russian Colonel said less
than 1 in 4 is flyable at any given time.
BUFDRVR
Old January 18th 04, 03:11 PM
Scott Ferrin
Range, loaded on internal fuel - 7,640 miles (B-1B - 3,444 miles)
Equipped for IFR.
Those are brochure numbers for the Blackjack.
How about B1 are the cited numbers for B1 are brochure numbers
as well?
Pretty much from what I understand. The B-1 is definitely faster than
789 mph though I'd be surprised if any operational aircraft had done a
takeoff at 477,000lbs.
In the real world (at
least as far as FAI records go) the B-1 has the Blackjack beat in the
paylaod/range department.
In its department where B1 is the only one amybe. Tu160
is much bigger?much faster and longer lange.
Speed over a closed circuit of 5000 km with 30000 kg payload : 1054.21
km/h
Date of flight: 17/09/1987
Pilot: H. Brent HEDGPETH (USA)
Crew: Robert A. CHAMBERLAIN (copilot)
Course/place: Palmdale, CA (USA)
Aircraft:
Rockwell B-1B (4 General Electric F 101-GE-102, 14 700 kg each)
Registered 'S/N70'
Speed over a closed circuit of 5000 km with 30000 kg payload : 1017.80
km/h
Date of flight: 28/05/1990
Pilot: Serguei OSSIPOV (USSR)
Crew: D.N. MATVEEV (USSR)
Course/place: Podmoskovnoe Aerodrome (USSR)
Aircraft:
Tupolev Aircraft "70N-304" (Tupolev TU-160 "Blackjack") (4 Model "P",
25 000 kg each)
As you can see, with the same 30,000kg payload flown over a distance
of 5000km, the Blackjack was slower than the B-1B. Since the
Blackjack's record attempt was flown at a later date one would assume
they'd try to beat the B-1's. If they did try they failed. The
Blackjack also holds no 10,000km speed records while the B-1 does.
While this in itself doesn't say the Blackjack can't fly that far, it
doesn't exactly help it's case either.
As for the Blackjack being faster, the lower speed of the B-1b was
intentional. The original B-1A reached Mach 2.22 which was faster
than the Blackjack. That speed was judged so important that pretty
much nobody cared when they gave it up. As for the Blackjack being
bigger. . .well if you think an aircraft that needs to be 27% heavier
and 83% more powerful to do an inferior job is something to brag
about. . .well, that's your business.
Anyway
It probably had the range for a one way trip, but any aircraft that
can fly far enough could say the same.
Old January 18th 04, 03:25 PM
Henry J. Cobb
Tank Fixer wrote in message nk.net...
on 17 Jan 2004 16:29:00 -0800,
Henry J. Cobb attempted to say.....
Though the Tu-160 bears a remarkable resemblance to the American B-1
bomber, the Blackjack is far larger, being the world's largest combat
aircraft.
Say what ?
http://www.fas.org/nuke/guide/russia/bomber/tu-160.htm
Maximum take-off weight 275.000 kg
http://globalsecurity.org/wmd/systems/b-52-specs.htm
Maximum Takeoff Weight: 488,000 pounds (219,600 kilograms)
-HJC
Old January 18th 04, 03:40 PM
Spot
Yep, the B-1 is a real piece of ****...
Responsible for over 10% of the DMPIs struck in OIF with less than 1% of the
sorties...
9.4 DMPIs struck per sortie...
Went downtown Baghdad and Tikrit everyday, even in broad daylight, sometimes
with no SEAD support...
MC rate better than many aircraft during OIF...
"The weapon of choice"--CAOC Director
Hope you had a good laugh back then...
BONE WSO
"BUFDRVR" wrote in message
Anyway
25%,
chuckle. In
crews
crews
A
as
B-1B
B-1
English
Bears, a
where it
underneath
performed an
returned
one
Russian
BUFF
to
pointed
and
began to
translator,
moment of
at
about
less
BUFDRVR
harelips
Old January 18th 04, 05:09 PM
Jim Baker
Anyway
25%,
chuckle. In
crews
crews
A
as
B-1B
B-1
English
Bears, a
where it
underneath
performed an
returned
one
Russian
BUFF
to
pointed
and
began to
translator,
moment of
at
about
less
BUFDRVR
That's a great story! Here's another.
In late 1989, my crew was selected to fly a B-1B to Luke AFB for a kind of
static display. This display was arranged as the reciprocal for the
Minister of Defense of the USSR and his staff. You might recall that our
CJCS visited the USSR in the middle/late '80s and this was the U.S. turn to
reciprocate this unprecedented, high-level military exchange. On the ramp
at Luke, arranged in a semi-circle, was a KC-10, C-5, F-15C, F-16, B-1B and
B-52H. At the arranged time we all trooped out to our jets and waited.
Soon, a caravan of civilian stretch limos, suburbans and staff cars pulled
up and out gets a big crowd of military, U.S. & USSR, and civilians. After
some milling about, the civilians (wives of the visitors and their hosts)
head off and the military types walked slowly into the lare semicircle of
aircraft. A couple of minutes later, they come walking with purpose
straight over to us, a Major and three Captains. Sooo, this is my 15
minutes of fame I figure and I stride out to greet the highest ranking
military member of, arguably, the 2nd strongest nation in the world. We
exchange salutes, shake hands, he looks over the Bone, and I ask if he'd
like a tour inside. A hush falls over the crowd, the MoD looks pensive and
says........ "Nyet!" I was relieved since he was a big dude and I'm not
sure it would have been that easy getting him up there. Anyway, he sent two
staff members with me to go inside, and several others with the Co, O and D
for a tour of the outside. I have no idea what rank the two officers were
that went up with me, just that they were bomber pilots who were now working
in the MoD. One of them spoke good English so he translated for the other
guy and me. The Russian only speaker asked pretty innocuous questions about
how the aircraft worked, how it was to fly, my thoughts about its
performance etc. I told him the general P.R. answers but gave him a fairly
detailed description of our mainteance and birthing-of-a-new-weapon system
problems (those were in the news a lot at that time) that our Ops and MX
people were battling through. He listened and said that they were having
the same problems with the Blackjack only much worse. They had difficulty
getting more than a couple of sorties a day off the ground. I told him that
we were getting a lot more off the ground than that and were flying, fleet
wide, several dozen sorties a day. He responded that they knew that in the
MoD and were convinced that the "American Air Force" would solve the
problems and the B-1B would be their biggest air breathing threat. I then
said that I had flown the B-52 for 5 years and that there were many more
B-52s on alert than B-1Bs and he waved his hand and said "...not a problem,
we can shoot down slow B-52, we are not sure about shooting down B-1". (Of
course, the whole world knew that a C-172 could fly into Red Square unharmed
so I took that statement with a grain of salt). After some more
pleasantries, we climbed out and he handed me a couple of little boxes with
hero of the soviet union type trinkets inside and they went on their way to
the next aircraft. I noticed that the MoD and the crew looked in the
fighters, talked to the crew of the Buff and the other heavies but didn't go
inside any off them, and then trooped back to their caravan. They drove out
to some bleachers at midfield and soon the TBirds showed up and did a show.
Before the group left, a Lt Col came up to us in a hurry and asked if we
wanted our picture taken with the VCJCS. I said sure, bring him on over.
LOL. Pretty neat day. Anyway, I got the distinct impression that even in
the early days of the B-1B fielding, the people responsible for planning the
defense of the USSR knew of the teething problems the Bone was going
through, but were distinctly worried about the Bone making it through their
defenses. So I guess the Piece-of-**** scale is proportional and sliding
based on rank and seriousness of the job of the observer.
Regards,
Old January 18th 04, 06:07 PM
Ken Duffey
BUFDRVR wrote:
Anyway
BUFDRVR
Bufdrvr,
I have been meaning to ask you this since last August..........
I visited the MAKS airshow at Zhukovsky, Moscow and amongst the aircraft on display
was an operational example of both the Tu-95MS and Tu-160 from Engels.
Also on display - for the first time - were some visiting USAF a/c - KC-135, C-130,
F-15, F-16 plus a Buff from Minot - I just checked my photo of it - and I can't
make out the full serial - but it was AF xx 027 on the fin and 1027 on the forward
fuselage. It also had a red fin flash with yellow lettering that looks something
like 'Badoms' ??
I took the photo from a tethered balloon at the limit of my lens!
We couldn't get near the crews for the Russian crowd (not that I wanted too - I was
there to see Russian a/c, I can see Buffs at RAF Fairford anytime). The crews of
all the visiting a/c must have been overwhelmed by the Russian public who were
asking for autographs, getting their photos taken with the American running dog
agressors etc
What I wondered was whether you had heard any feedback from these visiting crews??
How was the evil empire ?
How did they enjoy the visit, what was the Russian hospitality like, how were they
treated, what was their impressions of the RusAF etc etc.
How did they route to Moscow - did they mingle with the crews of the Tu-95/Tu-160
etc
Anything ?
Cheers
Ken
Ken Duffey - Flanker Freak & Russian Aviation Enthusiast
Flankers Website - http://www.flankers.co.uk/
Old January 18th 04, 10:26 PM
Ken Duffey
Tank Fixer wrote:
on 18 Jan 2004 13:43:18 GMT,
BUFDRVR attempted to say .....
Say what ?
Ah, ok.
For some reason I'd thought it only a bit larger than a B1.
When dealing with propaganda terminology one sometimes always speaks in
variable absolutes. This is not to be mistaken for an unbiased slant.
I built a 1:72 scale model of a Tu-160. About 3/4 of the way down the page
at
http://www.flankerman.fsnet.co.uk/modl_tu160.html
is a plan view of a Tu-160 with a B-1 superimposed over it.
And down at the bottom of -
http://www.flankerman.fsnet.co.uk/modl_tu160_page3.html
there are photos of the finished model Tu-160 next to a model B-1 and Tu-22M
Backfire for size comparison.
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
Bombers and Fighters ArtKramr Military Aviation 4 September 18th 03 12:37 AM
water bombers Stew Hicks Home Built 2 September 8th 03 11:55 PM
F-111 bombers flying from carriers ? Mike Military Aviation 38 August 7th 03 12:19 AM
Backfire bombers: Reach USA ? Mike Military Aviation 11 July 28th 03 11:56 AM
