Dallas wrote:
A vertical stabilizer in coordinated flight would have equal pressure on both sides of the surface, Just askin', but is that always true? In a turn, even if coordinated, is there not a force against the vertical stab causing it to act as a keel to help maintain lateral stability? |
On Mon, 22 Feb 2010 17:21:21 -0700, romeomike wrote:
Just askin', but is that always true? In a turn, even if coordinated, is there not a force against the vertical stab causing it to act as a keel to help maintain lateral stability? (Disclaimer: I don't claim to be an aeronautical engineer, but I like the subject.) To me, coordinated is coordinated. Sure, there are micro disruptions that try to produce a yaw that the vertical stabilizer is called upon to resist, after all, that's why it's there. But, in a coordinated turn, the goal is to balance the pressure on both sides of the stabilizer. Have you ever seen those short strands of yarn some glider pilots tape to the front of their canopies? The goal is to keep the strand straight down the centerline during a turn which can only be accomplished if there is equal airflow on either side of the hull. -- Dallas |
Dallas wrote:
Have you ever seen those short strands of yarn some glider pilots tape to the front of their canopies? The goal is to keep the strand straight down the centerline during a turn which can only be accomplished if there is equal airflow on either side of the hull. Actually, yes, I have a comm rating in gliders, but that string is on the wind screen, not sure if it reflects the forces on the vertical stab. I don't know, maybe someone does. |
Dallas wrote:
Have you ever seen those short strands of yarn some glider pilots tape to the front of their canopies? The goal is to keep the strand straight down the centerline during a turn which can only be accomplished if there is equal airflow on either side of the hull. Being a glider pilot, I beg to differ: First, to keep the yaw string centered in a turn, one must apply some amount of rudder. A coordinated turn is a turn around all three axes. The required amount of rudder depends a lot on the glider type and of course the bank angle. Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside, because the cockpit is situated in front of the turn radius. (A second reason is that for various reasons you want the glider to slightly slip into the turn, hence the yaw string to point slightly to the outside, but that's another story altogether.) And third, the situation at the windscreen is not the same as the situation at the rudder. All that said, the lateral forces at the fin are pretty small during a coordinated turn. But coodinated flight is only part of the story. |
On Sun, 28 Feb 2010 13:54:54 +0100, John Smith wrote:
Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside Ok.. the spam can pilot stands corrected. Funny, I tried the string thingie on my Cessna and almost crashed trying to keep it centered. :-/ -- Dallas |
Dallas wrote:
On Sun, 28 Feb 2010 13:54:54 +0100, John Smith wrote: Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside Ok.. the spam can pilot stands corrected. Funny, I tried the string thingie on my Cessna and almost crashed trying to keep it centered. :-/ Is your Cessna a twin? In a single, the string does not work with the fan just in front of it. A twin is a different story, see e.g. http://www.airliners.net/photo/Embry-Riddle-Aeronautical-University/Diamond-DA-42-Twin/1413056/L/&sid=d969e71238e1e84442331da93fb3cb59 -- Tauno Voipio |
On Sun, 28 Feb 2010 21:37:05 +0200, Tauno Voipio wrote:
In a single, the string does not work with the fan just in front of it. Oh... so that's what the problem was.. :- ) (I was kidding :- ) -- Dallas |
On Feb 27, 2:08 pm, Dallas wrote:
To me, coordinated is coordinated. Sure, there are micro disruptions that try to produce a yaw that the vertical stabilizer is called upon to resist, after all, that's why it's there. But, in a coordinated turn, the goal is to balance the pressure on both sides of the stabilizer. The rudder/fin produces a lateral force to cause the coordination and will generate a tip vortex. Otherwise, why would we need the vertical surface? Dan |
On Feb 28, 5:38*pm, wrote:
On Feb 27, 2:08 pm, Dallas wrote: To me, coordinated is coordinated. *Sure, there are micro disruptions that try to produce a yaw that the vertical stabilizer is called upon to resist, after all, that's why it's there. But, in a coordinated turn, the goal is to balance the pressure on both sides of the stabilizer. The rudder/fin produces a lateral force to cause the coordination and will generate a tip vortex. Otherwise, why would we need the vertical surface? Dan I am clearly missing something here. I use the control surfaces to roll into a turn, then return them to neutral and trim away the back pressure once the desired bank is established in a coordinated turn. I don't think in that case the airplane knows it's in a turn. The G vector in normal to the wings and the fuselage centerline, but we will of course be experiencing more than 1 G. I won't bother posting to the other topic of interest, but most of us who are rated simply file IFR and don't worry about cloud separation, except for the concern that someone not flying on an instrument flight plan may be poking around. Solid IMC is somewhat better in that sense. By the way, if on an instrument flight plan in the US, just ask center to allow you to cruise within an altitude range, and then if it's granted you can play in and out of the clouds: it is priceless. Once out of congested areas in the east that permission is almost always given, the controller will understand -- he or she will be green with envy, but will understand. |
On Feb 28, 5:21 pm, a wrote:
I am clearly missing something here. I use the control surfaces to roll into a turn, then return them to neutral and trim away the back pressure once the desired bank is established in a coordinated turn. I don't think in that case the airplane knows it's in a turn. The G vector in normal to the wings and the fuselage centerline, but we will of course be experiencing more than 1 G. Are you using any rudder in the established turn? If not, you either have a very tame airplane, or the turn isn't quite coordinated. Introducing bank causes the airplane to move sideways, and the fin and rudder resist sideways movement so that the nose is forced to change direction. Therefore, there is lateral force being generated by the vertical surfaces and a vortex will be produced. Dan |
Vertical stabilizer wont come out (Asw-19) | [email protected] | Soaring | 13 | June 4th 09 12:45 AM |
Vertical Card Compass? | Bubba[_2_] | Owning | 10 | April 2nd 07 03:31 PM |
Vertical Card Compass? | Bubba[_2_] | Products | 0 | March 30th 07 06:58 PM |
Vertical Card Compass | Bubba[_2_] | General Aviation | 0 | March 30th 07 06:56 PM |
Vertical Card Compass? | Bubba[_2_] | Aviation Marketplace | 0 | March 30th 07 06:56 PM |
