LiPo Batteries in Gliders
Old February 25th 10, 02:03 PM posted to rec.aviation.soaring
Karl Striedieck
Default NIMH Batteries in Gliders
While charging a LiPo model airplane battery with a top-of-the-line charger
at the proper rate it burst into flame. I had carelessly left it out of the
flame-proof charge bag and when I checked strange noises the room was filled
with acrid smoke and a Mt Vesuvius mass of sputtering pyrotchnics was
burning a hole in the work bench. Don't fly with you-do-it LiPos unless you
have an ejection seat!
Karl Striedieck
"johngalloway" wrote in message
What about Li Ion batteries like these? Is the fire risk sinificantly
less than Li Polymer?
http://www.streckenflug.at//shop/pro...roducts_id=608
A bit pricey, and probably not approved in Europe, but might be a
thought when a transponder has to be carried.
John Galloway
Old February 25th 10, 02:20 PM posted to rec.aviation.soaring
Dave Nadler
Karl Striedieck
What about Li Ion batteries like these? *Is the fire risk sinificantly
A bit pricey, and probably not approved in Europe, *but might be a
John Galloway
Karl, model gliding is DANGEROUS !
See ya, Dave
Old February 25th 10, 03:48 PM posted to rec.aviation.soaring
Mike the Strike
Years ago, a lab next to the one I worked in had experimental
batteries under development. All the high energy density ones utilize
very reactive elements, of which lithium is one. However, nothing
would beat the sodium-sulfur battery in its capacity to "go
Vesuvius". It was colloquially referred to as "the fire and brimstone
battery". The lab had a sulfurous smell that reminded one of the
entrance to nether regions.
I'm going to stick with lead-acid, thanks very much!
Mike
Old February 25th 10, 03:56 PM posted to rec.aviation.soaring
bildan
batteries under development. *All the high energy density ones utilize
very reactive elements, of which lithium is one. *However, nothing
Vesuvius". *It was colloquially referred to as "the fire and brimstone
battery". *The lab had a sulfurous smell that reminded one of the
Mike
If you think lead-acid gel-cells are safe, try a dead short on a fully
charged one. Splattering hot gelled acid is pretty nasty stuff.
Old February 25th 10, 05:04 PM posted to rec.aviation.soaring
Darryl Ramm
Mike
charged one. *Splattering hot gelled acid is pretty nasty stuff.
Who exactly flies with gel-cells? There is no gelled anything inside
the VRLA (Valve Regulated Lead Acid) aka SLA (Sealed Lead Acid) or
often incorrectly called "gell cell" batteries almost universally used
in gliders. There is a surprisingly small amount of liquid
electrolyte, sulfuric acid electrolyte, basically the same as inside a
regular car battery but here used to moisten the thin fiberglass mats
between the plates.
But yes the dead short scenario is a worry and people need to be
careful. These little batteries can source hundreds of amps. Most
likely is not a destructive failure of the VRLA battery but damage
caused by the wire shorting across the battery, getting red hot,
burning molten PVC insulation, etc. burning somebody or causing a
fire. There is a misconception as well that VRLA/SLA batteries are
sealed and they will explode if the pressure inside gets too high.
They are vented with neoprene valves that will release pressure so
they won't just pressurize and eventually explode, but they still can
suffer catastrophic case failure in some situations. And they can also
cause explosions if overcharged in confined spaces from the hydrogen
leaking out the neoprene valves.
Darryl
Old February 25th 10, 05:28 PM posted to rec.aviation.soaring
Grider Pirate
Mike
That's why it's a good idea to use a FUSE and keep the terminals
covered. I can't think of any high capacity battery that won't react
spectacularly to a dead short.
Old February 25th 10, 06:56 PM posted to rec.aviation.soaring
Jim[_18_]
Karl Striedieck
John Galloway
Here's an intersting video of a laptop battery fire.
http://www.youtube.com/watch?v=mlZggVrF9VI
NIMH Batteries K M Soaring 23 December 9th 08 09:27 PM
AGM Batteries Dave Anderer Owning 13 March 29th 08 07:38 PM
2-Batteries [email protected] Soaring 69 January 4th 07 04:09 AM
160 new batteries Mal Soaring 0 October 27th 06 11:36 AM
Sealed Batteries Gene Vignali Owning 5 October 2nd 03 08:32 PM
