Years ago, a lab next to the one I worked in had experimental
batteries under development. All the high energy density ones utilize very reactive elements, of which lithium is one. However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". It was colloquially referred to as "the fire and brimstone battery". The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike |
On Feb 25, 8:48*am, Mike the Strike wrote:
Years ago, a lab next to the one I worked in had experimental batteries under development. *All the high energy density ones utilize very reactive elements, of which lithium is one. *However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". *It was colloquially referred to as "the fire and brimstone battery". *The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike If you think lead-acid gel-cells are safe, try a dead short on a fully charged one. Splattering hot gelled acid is pretty nasty stuff. |
On Feb 25, 7:56*am, bildan wrote:
On Feb 25, 8:48*am, Mike the Strike wrote: Years ago, a lab next to the one I worked in had experimental batteries under development. *All the high energy density ones utilize very reactive elements, of which lithium is one. *However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". *It was colloquially referred to as "the fire and brimstone battery". *The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike If you think lead-acid gel-cells are safe, try a dead short on a fully charged one. *Splattering hot gelled acid is pretty nasty stuff. Who exactly flies with gel-cells? There is no gelled anything inside the VRLA (Valve Regulated Lead Acid) aka SLA (Sealed Lead Acid) or often incorrectly called "gell cell" batteries almost universally used in gliders. There is a surprisingly small amount of liquid electrolyte, sulfuric acid electrolyte, basically the same as inside a regular car battery but here used to moisten the thin fiberglass mats between the plates. But yes the dead short scenario is a worry and people need to be careful. These little batteries can source hundreds of amps. Most likely is not a destructive failure of the VRLA battery but damage caused by the wire shorting across the battery, getting red hot, burning molten PVC insulation, etc. burning somebody or causing a fire. There is a misconception as well that VRLA/SLA batteries are sealed and they will explode if the pressure inside gets too high. They are vented with neoprene valves that will release pressure so they won't just pressurize and eventually explode, but they still can suffer catastrophic case failure in some situations. And they can also cause explosions if overcharged in confined spaces from the hydrogen leaking out the neoprene valves. Darryl |
On Feb 25, 8:48*am, Mike the Strike wrote: Years ago, a lab next to the one I worked in had experimental batteries under development. *All the high energy density ones utilize very reactive elements, of which lithium is one. *However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". *It was colloquially referred to as "the fire and brimstone battery". *The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike If you think lead-acid gel-cells are safe, try a dead short on a fully charged one. *Splattering hot gelled acid is pretty nasty stuff. That's why it's a good idea to use a FUSE and keep the terminals covered. I can't think of any high capacity battery that won't react spectacularly to a dead short. |
NIMH Batteries | K M | Soaring | 23 | December 9th 08 09:27 PM |
AGM Batteries | Dave Anderer | Owning | 13 | March 29th 08 07:38 PM |
2-Batteries | [email protected] | Soaring | 69 | January 4th 07 04:09 AM |
160 new batteries | Mal | Soaring | 0 | October 27th 06 11:36 AM |
Sealed Batteries | Gene Vignali | Owning | 5 | October 2nd 03 08:32 PM |
