2009 Nall report and Soaring Safety
Old February 26th 10, 04:25 AM posted to rec.aviation.soaring
noel.wade
Default 2009 Nall report and Soaring Safety
Martin (and others) -
For graphical representations, I like www.runwayfinder.com (which
overlays this stuff on top of Google Maps and a sectional-chart view.
I can't say for sure whether it catches ALL NOTAMs, but I know it
catches TFRs very well.
Enjoy,
--Noel
Old February 26th 10, 07:00 AM posted to rec.aviation.soaring
JS
Another site for graphical TFRs.
http://tfr.faa.gov/tfr_map_ims/html/index.html
Old February 26th 10, 02:43 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Thu, 25 Feb 2010 23:00:44 -0800, JS wrote:
I've learnt something from this: NOTAMS aren't nearly as heavily used in
the US as they are here.
I couldn't see how to make www.runwayfinder.com show NOTAMs but
http://tfr.faa.gov/tfr_map_ims/html/index.html works quite nicely (though
won't show a task or flight plan) and does show NOTAMS. The shock was
seeing that it only lists 22 current NOTAMS for the whole USA and only 4
in California!
By contrast today in the UK we have 77 active and applicable below FL070,
another 23 that lack plottable co-ordinates (like many American SECURE
category NOTAMS), and another 60 that were been excluded from by my
filter (inactive today and/or inapplicable below FL070).
http://www.gregorie.org/temp/notams/ contains a NOTAMplot screenshot
showing NOTAMs that apply in East Anglia today below FL070. I also added
a 177 km task to show how it appears.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 26th 10, 06:25 PM posted to rec.aviation.soaring
JS
Controlled airspace isn't as heavily used as in Europe, either!
Simple NOTAMs such as a closed taxiway, snow on the runway, or a
light not working don't make it on the map. They would be in a
briefing for your route, along with PIREPs etc. Of course, pilot
reports of turbulence are often a good sign for soaring!
Why are security NOTAMs typed "caps lock", which seems a poor way to
communicate? Most people receiving an e-mail typed in caps would hit
the delete button.
On Feb 26, 6:43*am, Martin Gregorie
Old February 26th 10, 08:01 PM posted to rec.aviation.soaring
light not working don't make it on the map. They would be in a briefing
for your route, along with PIREPs etc. Of course, pilot reports of
Those were excluded. Sorry, I should have said that my list was purely en-
route NOTAMS.
Anything else is of little interest to UK glider pilots since we don't
usually fly from GA airfields and only talk to ATC if we need to enter
through an ATZ or land out on a GA field.
communicate?
Thats the way they appeared on the NOTAM list.
Most people receiving an e-mail typed in caps would hit the
delete button.
So? That was a single 8 letter upper case word. Who trod on *your* toe?
org |
Brian[_1_]
the delete button.
My guess is, it is a leftover from the days of teletypes that only had
capital letters.
Good points about Notams though, In the US we have gotten some good
resources for quickly identifying TFRS that might affect our flights.
However the Notam system is lagging far behind the TFR System. It is
easy to look at a TFR map and determine all is clear and then find out
the airport in the next town is closed due to an air show.
One of my memorable flights was a Cross country that I got very low on
and was planning on landing in a field. At the last moment I contacted
a very weak thermal and slowly climbed out at about 25-50 ft/min. The
closest airport was closed for resurfacing, but I call Flight Service
anyway and asked about the airports status. The told me it was closed.
When I asked "How closed? i.e. is a taxiway useable?" they said the
only information they had was "it is closed". Fortunately I was able
to climb enough to make it the next airport.
Old February 26th 10, 09:06 PM posted to rec.aviation.soaring
JS
You're probably right, Brian.
As it's 30 years or so since the first computer-based teletype
machines were introduced, perhaps it's just a matter of decades until
all NOTAMs are made legible. Weather reports won't need to be
abbreviated either, as the days of the 300 baud (even the new 1200
Baud) modem are numbered.
I may be wrong, but improving this information to make it easily
understood could add to safety.
Better have a meeting to consider forming a committee!
On Feb 26, 12:01*pm, Brian wrote:
* Why are security NOTAMs typed "caps lock", which seems a poor way to
communicate?
capital letters.
Old February 26th 10, 09:09 PM posted to rec.aviation.soaring
noel.wade
Also remember that (until recently), NOTAMs were chopped up into 3
categories. Some would only be available from local sources at/around
the affected airport(s).
And I think there are far more than 22 NOTAMs out there; its just
tough to find them all on one webpage.
Here, for example, are the NOTAMs just affecting Seattle Boeing Field
(KBFI). Currently, 10 are listed:
https://pilotweb.nas.faa.gov/PilotWe...trievalByICAOs
*sigh*
--Noel
Old February 27th 10, 12:13 AM posted to rec.aviation.soaring
On Fri, 26 Feb 2010 13:09:46 -0800, noel.wade wrote:
And I think there are far more than 22 NOTAMs out there; its just tough
I thought I was comparing like with like - UK En-route NOTAMS with the
list I found on http://tfr.faa.gov/tfr_map_ims/html/index.html - the
content looked similar apart from the secure notices: stuff like airshow
NOTAMS. Is that an invalid comparison?
BTW what do the initials TFR stand for? I can work what its all about but
not what TFR is an abbreviation of.
org |
Old February 27th 10, 01:08 AM posted to rec.aviation.soaring
bildan
the delete button.
capital letters.
a very weak thermal and slowly climbed out at about 25-50 ft/min. *The
only information they had was "it is closed". *Fortunately I was able
I remember an incident on a business trip when a sudden change of plan
required me to fly to an another city ASAP. When I called the FBO
from my hotel asking them to tow my airplane to the front ramp and
fuel it, the lady at the counter just happened to tell me the airport
was closing for a month for runway work starting at 11AM that day.
Where the hell was THAT NOTAM? It was nowhere in the system.
A large tip to a cabbie got me to the airport at 10AM and airborne
just before my airplane got marooned.
2009 Nall Report released Jim Logajan Home Built 0 February 19th 10 06:50 PM
Numbers don't add up in 2007 Nall report? Jim Logajan Piloting 2 December 24th 07 01:20 AM
Numbers don't add up in 2007 Nall report? Jim Logajan Home Built 2 December 24th 07 01:20 AM
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
State of GA safety (2005 Nall Report) [email protected] Piloting 23 March 10th 06 09:42 PM
