Dallas wrote:
Have you ever seen those short strands of yarn some glider pilots tape to the front of their canopies? The goal is to keep the strand straight down the centerline during a turn which can only be accomplished if there is equal airflow on either side of the hull. Being a glider pilot, I beg to differ: First, to keep the yaw string centered in a turn, one must apply some amount of rudder. A coordinated turn is a turn around all three axes. The required amount of rudder depends a lot on the glider type and of course the bank angle. Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside, because the cockpit is situated in front of the turn radius. (A second reason is that for various reasons you want the glider to slightly slip into the turn, hence the yaw string to point slightly to the outside, but that's another story altogether.) And third, the situation at the windscreen is not the same as the situation at the rudder. All that said, the lateral forces at the fin are pretty small during a coordinated turn. But coodinated flight is only part of the story. |
On Sun, 28 Feb 2010 13:54:54 +0100, John Smith wrote:
Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside Ok.. the spam can pilot stands corrected. Funny, I tried the string thingie on my Cessna and almost crashed trying to keep it centered. :-/ -- Dallas |
Dallas wrote:
On Sun, 28 Feb 2010 13:54:54 +0100, John Smith wrote: Second, the optimal position of the yaw string in a turn is *not* centered, but slightly outside Ok.. the spam can pilot stands corrected. Funny, I tried the string thingie on my Cessna and almost crashed trying to keep it centered. :-/ Is your Cessna a twin? In a single, the string does not work with the fan just in front of it. A twin is a different story, see e.g. http://www.airliners.net/photo/Embry-Riddle-Aeronautical-University/Diamond-DA-42-Twin/1413056/L/&sid=d969e71238e1e84442331da93fb3cb59 -- Tauno Voipio |
On Sun, 28 Feb 2010 21:37:05 +0200, Tauno Voipio wrote:
In a single, the string does not work with the fan just in front of it. Oh... so that's what the problem was.. :- ) (I was kidding :- ) -- Dallas |
Vertical stabilizer wont come out (Asw-19) | [email protected] | Soaring | 13 | June 4th 09 12:45 AM |
Vertical Card Compass? | Bubba[_2_] | Owning | 10 | April 2nd 07 03:31 PM |
Vertical Card Compass? | Bubba[_2_] | Products | 0 | March 30th 07 06:58 PM |
Vertical Card Compass | Bubba[_2_] | General Aviation | 0 | March 30th 07 06:56 PM |
Vertical Card Compass? | Bubba[_2_] | Aviation Marketplace | 0 | March 30th 07 06:56 PM |
