Downloading .igc fliles from Volkslogger
Old March 3rd 10, 01:58 AM posted to rec.aviation.soaring
JS
Default Downloading .igc fliles from Volkslogger
I suspect Tim's response is the one you're after.
If you open the file in SeeYou, look at file properties:
In SeeYou, right click anywhere in the display and select flight
properties.
At the bottom of the Flight tab, you'll see the logger type. If it
doesn't read Volkslogger, that was not the file from your
Volksologger.
Old March 3rd 10, 02:40 AM posted to rec.aviation.soaring
RN
Thanks to everyone for the help.
JS hit it. At least, I now know where the file is originating.
Checking SeeYou as he suggested shows the file is coming from SeeYou
Mobile running on the PDA. The GPS engine is reported as Volkslogger
which is correct.
Now, I just need to figure out why P-Strepla shows it has found the
Volkslogger, and has the correct file, but somehow downloads the
SeeYou file on the PDA to the SD Card.
Old March 3rd 10, 02:57 AM posted to rec.aviation.soaring
Darryl Ramm
which is correct.
Duh I should have recognized the filenames as from SeeYou Mobile.
Are you sure that P-Strepa is copying the SeeYou Mobile file?
SeeYou Mobile can put the IGC file it creates directly on your SD
card.
Start SeeYou Mobile and go to SettingsFiles and look at what "Flight
folder"
is set to. That may solve one part of the mystery.
Darryl
Old March 3rd 10, 01:46 PM posted to rec.aviation.soaring
Wojciech Scigala
I've just browsed P-Strepla's features, and it seems to me that this
software cannot download files from flight recorders (like Volkslogger).
It only uses Volkslogger as a source of GPS signal and barometric altitudes.
So P-Strepla is perfectly correct saying it has found and connected to
Volkslogger. But it has nothing in common with IGC-sanctioned flight
recording.
SeeYou Mobile cannot download files as well. There's a companion
application called ConnectMe (freeware) which does it.
Usually there's no need to download logger's files to PDA, as they are
to be analysed on PC anyway. You can connect Volkslogger to PC directly
to make the download.
WojtuÅ›.net
Old March 3rd 10, 03:25 PM posted to rec.aviation.soaring
mattm[_2_]
recording.
WojtuÅ›.net
Well, for a lot of us it's easier to download the logger igc file to
the PDA.
Laptops are impossible to use outside because the bright daylight
washes
out the screen. Personally I use SoarPilot on a Palm Tungsten T,
which
is very usable outdoors. It also downloads the log files from a
variety of
loggers onto an SD card. After flying I usually do that while I'm
wiping the
bugs off the wings. At US contests where you only have an hour to
deliver
your log file to the scorer (unless you land out, of course) the
delivery of
the igc file usually comes before pulling the wings.
Of course with the VL you can just take that with you and download it
directly to the scorer's computer. However, for people with
permanently
mounted loggers like the Cambridge 301 or LX flight computers you have
to download in the cockpit. I believe ConnectMe is provided free and
runs
on all the WinMobile platforms.
-- Matt
Old March 3rd 10, 03:58 PM posted to rec.aviation.soaring
Darryl Ramm
recording.
WojtuÅ›.net
Pocket*StrePla-Connect is marketed as part of pocket*StepLa, it is
equivalent to Naviter ConnectMe. And that begs the question of whether
the original poster meant pocket*StrePla or pocket*StrePla-Connect
(like I assumed but maybe wrongly). But if somebody is already using
SeeYou Mobile on a PDA, using ConnectMe would seem the more likely
route.
Many people download to a PDA or its SD card. If you already have a
PDA for navigation connected to the logger then you already have the
cabling needed and the PDA is already there with you in the cockpit.
Juggling a laptop at the glider to do this can be more cumbersome.
Darryl
Darryl
Old March 3rd 10, 04:56 PM posted to rec.aviation.soaring
Wojciech Scigala
Of course, embedded logger is best read with PDA. We were talking about
Volkslogger, which is quite portable unit.
WojtuÅ›.net
Old March 3rd 10, 04:44 PM posted to rec.aviation.soaring
Peter Wyld[_2_]
"Wojciech Scigala" wrote in message
Uzytkownik RN napisal:
altitudes.
recording.
Usually there's no need to download logger's files to PDA, as they are to
be analysed on PC anyway. You can connect Volkslogger to PC directly to
make the download.
Wojtus.net
From a scorer's point of view, it is considerably faster to get results done
if the igc file is handed in on a card or thumb drive. Downloading traces
from loggers is a pita and takes considerable time which could be better (or
more enjoyably) spent in the bar!
SeeYou even provide a free program (IGCMail) which collects igc files from
an email account which makes it even simpler! Neither this nor the igc file
on a card absolves the pilot from the responsibility of keeping the original
trace in the logger for possible checking.
Downloading from AOPA Lou Home Built 3 November 14th 06 02:56 PM
Help downloading this site TripFarmer Owning 17 December 2nd 05 01:59 AM
Downloading flying music? Jay Honeck Piloting 54 February 3rd 04 09:47 AM
Downloading Flying Music Jay Honeck Owning 43 January 30th 04 03:00 PM
Downloading Flying Music? Mark Mallory Owning 1 January 27th 04 12:48 PM
