On Sun, 07 Mar 2010 15:06:04 -0800, glider wrote:
I believe the first Phonix was Polyester Resin, then the later models were Epoxy Resin. Libelles, etc are Epoxy Resin....pretty sure. The interior of the Libelle fuselage certainly looks like epoxy, but then there's that opaque tan coloured layer just under the gelcoat on the wings which made me think that maybe the wings were polyester. Could it be some sort of sandable layer between the outside (epoxy?)/glass layer and the gelcoat? I don't know if B series are different in this respect: mine is pre-B series and contains many m^2 of balsa. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Mar 7, 3:31*pm, Martin Gregorie
wrote: On Sun, 07 Mar 2010 15:06:04 -0800, glider wrote: I believe the first Phonix was Polyester Resin, then the later models were Epoxy Resin. Libelles, etc *are Epoxy Resin....pretty sure. The interior of the Libelle fuselage certainly looks like epoxy, but then there's that opaque tan coloured layer just under the gelcoat on the wings which made me think that maybe the wings were polyester. Could it be some sort of sandable layer between the outside (epoxy?)/glass layer and the gelcoat? Martin, All Libelles use only epoxy resin. In the early days some were concerned about their ship getting too hot sitting in the trailer, hence the note in your flight manual. I take it you have a H-301, if so the opaque looking areas on your wings are probably thin gelcoat allowing the balsa-wood core to show through. keep moisture away from her and she's a good old girl............ I have owned 2 and loved them both, but that removable canopy became too much for an old guy to tolerate. Hope this helps, JJ |
On Mon, 08 Mar 2010 06:05:32 -0800, JJ Sinclair wrote:
Martin, All Libelles use only epoxy resin. In the early days some were concerned about their ship getting too hot sitting in the trailer, hence the note in your flight manual. I take it you have a H-301, if so the opaque looking areas on your wings are probably thin gelcoat allowing the balsa-wood core to show through. keep moisture away from her and she's a good old girl............ I have owned 2 and loved them both, but that removable canopy became too much for an old guy to tolerate. Thanks for clearing that up, JJ. I have an early H.201, s/n 82, so its definitely got balsa-skinned flying surfaces. As a somewhat ex aeromodeler I can still recognise balsa and know what it looks like under an epoxy/glass finish having finished bits of several models that way. The tan layer under my Libelle's wing and tail gelcoat is definitely not balsa - its an even, textureless mid-tan colour with a matt finish. There's a square inch or so exposed round the tailplane's front hold-down where the tape I put over the hold-down has lifted some of the gelcoat off. IOW there's sufficient of it exposed to be confident of its lack of texture. Besides its a considerably darker yellow-brown colour than I've ever seen on a piece of balsa. I'm now really puzzled as what it might be. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Mar 8, 9:05*am, Martin Gregorie
wrote: On Mon, 08 Mar 2010 06:05:32 -0800, JJ Sinclair wrote: Martin, All Libelles use only epoxy resin. In the early days some were concerned about their ship getting too hot sitting in the trailer, hence the note in your flight manual. I take it you have a H-301, if so the opaque looking areas on your wings are probably thin gelcoat allowing the balsa-wood core to show through. keep moisture away from her and she's a good old girl............ I have owned 2 and loved them both, but that removable canopy became too much for an old guy to tolerate. Thanks for clearing that up, JJ. I have an early H.201, s/n 82, so its definitely got balsa-skinned flying surfaces. As a somewhat ex aeromodeler I can still recognise balsa and know what it looks like under an epoxy/glass finish having finished bits of several models that way. The tan layer under my Libelle's wing and tail gelcoat is definitely not balsa - its an even, textureless mid-tan colour with a matt finish. There's a square inch or so exposed round the tailplane's front hold-down where the tape I put over the hold-down has lifted some of the gelcoat off. IOW there's sufficient of it exposed to be confident of its lack of texture. Besides its a considerably darker yellow-brown colour than I've ever seen on a piece of balsa. I'm now really puzzled as what it might be. * -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Is this only in spots like the wing root and near the tail attach bolt? Could it be phenolic microballoon filler?. You'll get that in different brown to reddish-brown colors, maybe tan. I think phenolic microballons have been around for ages, but I have _no idea_ if it was ever used in a Libelle. Darryl |
On Mon, 08 Mar 2010 09:35:23 -0800, Darryl Ramm wrote:
On Mar 8, 9:05Â*am, Martin Gregorie wrote: On Mon, 08 Mar 2010 06:05:32 -0800, JJ Sinclair wrote: Martin, All Libelles use only epoxy resin. In the early days some were concerned about their ship getting too hot sitting in the trailer, hence the note in your flight manual. I take it you have a H-301, if so the opaque looking areas on your wings are probably thin gelcoat allowing the balsa-wood core to show through. keep moisture away from her and she's a good old girl............ I have owned 2 and loved them both, but that removable canopy became too much for an old guy to tolerate. Thanks for clearing that up, JJ. I have an early H.201, s/n 82, so its definitely got balsa-skinned flying surfaces. As a somewhat ex aeromodeler I can still recognise balsa and know what it looks like under an epoxy/glass finish having finished bits of several models that way. The tan layer under my Libelle's wing and tail gelcoat is definitely not balsa - its an even, textureless mid-tan colour with a matt finish. There's a square inch or so exposed round the tailplane's front hold-down where the tape I put over the hold-down has lifted some of the gelcoat off. IOW there's sufficient of it exposed to be confident of its lack of texture. Besides its a considerably darker yellow-brown colour than I've ever seen on a piece of balsa. I'm now really puzzled as what it might be. Is this only in spots like the wing root and near the tail attach bolt? Could it be phenolic microballoon filler?. You'll get that in different brown to reddish-brown colors, maybe tan. I think phenolic microballons have been around for ages, but I have _no idea_ if it was ever used in a Libelle. I'm pretty sure I've I've seen it under a chip further out on the wing, made when a 'helper' slung the tail dolly into my trailer, bouncing it off the wing undersurface. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
another gelcoat story | Brad[_2_] | Soaring | 29 | August 28th 08 01:26 AM |
another gelcoat story | Brad[_2_] | Soaring | 1 | August 24th 08 06:37 PM |
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 08:34 AM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
