To try and keep on point here, LS-6, LS-10, LS-3, PIK 20 D, Ventus C,
ASW-17 come to mind as having full span flaperons. The entire trailing edge moves the same amount when moved as flap or aileron. ASW-20, PIK 20B, Zuni, SGS 1-35, HP Series, 301 Libelle, Diamants, Ventus A/B, Kestrel, etc do NOT have full span flaperons. They have flaps and ailerons, and varying degrees of interconnection between the two. Only plane I know of that had a full span flap that was used at large deflections (greater than 30 degrees) was the HP-17. Notice, it did not have full span flaperons. It had spoilers for roll control. And I understand the contestants had a great time watching Schreder take off with it, as he went from tip to tip, side to side on the runway until he finally got the plane into the air. This was likely due to the fact that you could only reduce the lift a bit on the high wing and add drag to it to try and pick up the down wing. Full span, large deflection flaperons will likely provide very poor roll control at any deflection beyond about 30-45 degrees, as the flap will be likely be stalled, and the main thing you will get is differential drag or a yawing moment when you moved the stick to try and roll the plane. Oh, and I don't consider the Ventus A/B, Mini Nimbus, or Mosquito to have drag flaps. They have cruise flaps and trailing edge air brakes. Drag flaps have you looking out the top of the canopy at where you are going to land when you put them full on. You are still looking out the front of the canopy at where you are going to land with trailing edge air brakes. The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. I don't think it was done for added drag or improved in flight handling. You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. Set the flaps, use the dive brakes and land. No more needed hand changes. Steve Leonard |
Steve Leonard wrote:
To try and keep on point here, LS-6, LS-10, LS-3, PIK 20 D, Ventus C, ASW-17 come to mind as having full span flaperons. The entire trailing edge moves the same amount when moved as flap or aileron. ASW-20, PIK 20B, Zuni, SGS 1-35, HP Series, 301 Libelle, Diamants, Ventus A/B, Kestrel, etc do NOT have full span flaperons. They have flaps and ailerons, and varying degrees of interconnection between the two. Only plane I know of that had a full span flap that was used at large deflections (greater than 30 degrees) was the HP-17. Notice, it did not have full span flaperons. It had spoilers for roll control. And I understand the contestants had a great time watching Schreder take off with it, as he went from tip to tip, side to side on the runway until he finally got the plane into the air. This was likely due to the fact that you could only reduce the lift a bit on the high wing and add drag to it to try and pick up the down wing. Full span, large deflection flaperons will likely provide very poor roll control at any deflection beyond about 30-45 degrees, as the flap will be likely be stalled, and the main thing you will get is differential drag or a yawing moment when you moved the stick to try and roll the plane. Oh, and I don't consider the Ventus A/B, Mini Nimbus, or Mosquito to have drag flaps. They have cruise flaps and trailing edge air brakes. Drag flaps have you looking out the top of the canopy at where you are going to land when you put them full on. You are still looking out the front of the canopy at where you are going to land with trailing edge air brakes. The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. I don't think it was done for added drag or improved in flight handling. You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. Set the flaps, use the dive brakes and land. No more needed hand changes. Steve Leonard And unfortunately Schleicher patented the mixer - so one of the more effective safety innovations has not been widely used. Relying on a manual process as per T59D is a busy solution and error prone. So it looks like the industry went to more powerful airbrakes and dump the flaps on the ground run. Pity really. --- news://freenews.netfront.net/ - complaints: --- |
Bruce wrote:
The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. I don't think it was done for added drag or improved in flight handling. You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. Set the flaps, use the dive brakes and land. No more needed hand changes. Steve Leonard And unfortunately Schleicher patented the mixer - so one of the more effective safety innovations has not been widely used. About 15 years ago, Gerhard Waibel told me they purposely did not patent their system. They thought it was such an important safety feature it should be available to the other manufacturers; to Schleicher's surprise and dismay, none had ever used it, even though it was introduced on the ASW 20 in about 1975. -- Eric Greenwell - Washington State, USA (netto to net to email me) |
On Mar 9, 12:59*am, Eric Greenwell wrote:
Bruce wrote: The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. *I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. *I don't think it was done for added drag or improved in flight handling. *You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. *However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. *That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. *Set the flaps, use the dive brakes and land. *No more needed hand changes. Steve Leonard And unfortunately Schleicher patented the mixer - so one of the more effective safety innovations has not been widely used. About 15 years ago, Gerhard Waibel told me they purposely did not patent their system. They thought it was such an important safety feature it should be available to the other manufacturers; to Schleicher's surprise and dismay, none had ever used it, even though it was introduced on the ASW 20 in about 1975. Good to know that I didn't violate any patents. Years ago I installed this feature on the RS-15 I owned. Actually, any HP series glider with a flap/aileron interconnect can easily be set up to have this behavior and I believe that many/most are. One needs only to modify the cam slot in a piece of 3/16" aluminum plate. The guy to whom I sold the RS wanted the ailerons to go "crow" at smaller flap deflections. He was able to easily change it himself. In general, it makes a huge difference in maintaining control during landing rollout as described and the best part is crow mode happens automatically. Just set the flaps and land. Dive brakes/spoilers? What are those? ;-) Regards, -Doug |
Thanks for all the good discussion.
I don't understand why flow separation above a full-span flaperon would cause you to lose aileron control everywhere in the speed braking region. Let's say you're at 45 degrees flap, and the flow has separated on top, but you'd have plenty of pressure on them below. So I'd guess the force on the control surface might be at 45 degrees or so above horizontal. It seems you would still have some good aileron control because raising or lowering opposite-side flaperons would still change that force a lot, with its vertical component. It seems the bigger problem might be yawing effects that would come with it? |
Bret,
Model gliders have tried most of these control ideas at least once in the past 20 years. It's much easier with the servos and computer controlled radios to get almost any mixing arrangements you can think of. In the case of the full-span flaperon: Once the flap function exceeds about 25 degrees down, the additional downward deflection of the aileron function does NOT create much lift to make a roll, in fact it adds a lot more drag and really increases the adverse drag. The upward moving aileron function reduces the drag a little, but doesn't remove much lift, again resulting an adverse yaw but no real rolling effect. In the models you can change the "rate" of the controls (increase or decrease the deflection relative to the control stick input) and overcome some of the rolling problems but not very much. We don't have any mechanism in our "big" sailplanes (that I know about) that can increase the deflection of a surface at different airspeeds or by selecting a mechanical detent on a control. Having tried full-span flaperons in the model form, several times, I can say I'd rather not try them on a full size, where my life is on the line. Mike |
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): | [email protected] | Naval Aviation | 0 | January 27th 07 02:18 PM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
Flaperons | Lou Parker | Home Built | 26 | November 15th 04 04:40 AM |
