Sailplanes are white...because of gelcoat?
Old March 8th 10, 05:05 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Sailplanes are white...because of gelcoat?
On Mon, 08 Mar 2010 06:05:32 -0800, JJ Sinclair wrote:
Martin,
All Libelles use only epoxy resin. In the early days some were concerned
about their ship getting too hot sitting in the trailer, hence the note
in your flight manual. I take it you have a H-301, if so the opaque
looking areas on your wings are probably thin gelcoat allowing the
balsa-wood core to show through. keep moisture away from her and she's a
good old girl............ I have owned 2 and loved them both, but that
removable canopy became too much for an old guy to tolerate.
Thanks for clearing that up, JJ.
I have an early H.201, s/n 82, so its definitely got balsa-skinned flying
surfaces. As a somewhat ex aeromodeler I can still recognise balsa and
know what it looks like under an epoxy/glass finish having finished bits
of several models that way.
The tan layer under my Libelle's wing and tail gelcoat is definitely not
balsa - its an even, textureless mid-tan colour with a matt finish.
There's a square inch or so exposed round the tailplane's front hold-down
where the tape I put over the hold-down has lifted some of the gelcoat
off. IOW there's sufficient of it exposed to be confident of its lack of
texture. Besides its a considerably darker yellow-brown colour than I've
ever seen on a piece of balsa. I'm now really puzzled as what it might
be.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 8th 10, 05:35 PM posted to rec.aviation.soaring
Darryl Ramm
On Mar 8, 9:05*am, Martin Gregorie
Martin,
be. *
martin@ * | Martin Gregorie
org * * * |
Is this only in spots like the wing root and near the tail attach
bolt? Could it be phenolic microballoon filler?. You'll get that in
different brown to reddish-brown colors, maybe tan. I think phenolic
microballons have been around for ages, but I have _no idea_ if it was
ever used in a Libelle.
Darryl
Old March 8th 10, 08:54 PM posted to rec.aviation.soaring
On Mon, 08 Mar 2010 09:35:23 -0800, Darryl Ramm wrote:
On Mar 8, 9:05Â*am, Martin Gregorie
Martin,
concerned about their ship getting too hot sitting in the trailer,
hence the note in your flight manual. I take it you have a H-301, if
so the opaque looking areas on your wings are probably thin gelcoat
allowing the balsa-wood core to show through. keep moisture away from
her and she's a good old girl............ I have owned 2 and loved
them both, but that removable canopy became too much for an old guy
to tolerate.
flying surfaces. As a somewhat ex aeromodeler I can still recognise
balsa and know what it looks like under an epoxy/glass finish having
finished bits of several models that way.
not balsa - its an even, textureless mid-tan colour with a matt finish.
hold-down where the tape I put over the hold-down has lifted some of
the gelcoat off. IOW there's sufficient of it exposed to be confident
of its lack of texture. Besides its a considerably darker yellow-brown
colour than I've ever seen on a piece of balsa. I'm now really puzzled
as what it might be.
Is this only in spots like the wing root and near the tail attach bolt?
Could it be phenolic microballoon filler?. You'll get that in different
brown to reddish-brown colors, maybe tan. I think phenolic microballons
have been around for ages, but I have _no idea_ if it was ever used in a
Libelle.
I'm pretty sure I've I've seen it under a chip further out on the wing,
made when a 'helper' slung the tail dolly into my trailer, bouncing it
off the wing undersurface.
org |
another gelcoat story Brad[_2_] Soaring 29 August 28th 08 01:26 AM
another gelcoat story Brad[_2_] Soaring 1 August 24th 08 06:37 PM
Gelcoat sag? [email protected] Soaring 10 December 17th 07 08:07 PM
Ferro gelcoat Basil Fairston Soaring 0 December 16th 03 08:34 AM
Refinishing gelcoat tango4 Soaring 21 November 3rd 03 07:29 AM
