KJZI (Charleston Executive, S.C.) ILS RWY 9 DME Required
Old March 13th 10, 02:14 PM posted to rec.aviation.ifr
Default KJZI (Charleston Executive, S.C.) ILS RWY 9 DME Required
On Mar 13, 7:13*am, Sam Spade wrote:
I care as much about your view of my attitude as your concern for
control tower operations.
Doesn't surprise me, you know it all, I just fly in the system and
regularity stay current so just like Mx, you speak without foundation
about "my concerns"......
Show me where I have made any safety errors with regards to control
tower operations. YOU CAN'T.
ATC's job is separation, my job is flying the plane. If you consider
my safety parameters of holding MDA altitude to missed bad for control
tower operations, they you have the problem not me, NOT ATC either..
Why I say this about ATC? ATC does not have a problem with what I do
holding MDA altitude to the MAP at several D class airports of the
likes of KNEW, KTUP, KHKS, KOWB, and the list goes on. I haven't
received instructions to call the tower after landing because of my
technique so there must be merit on what I say.
BUT THIS IS OK as I take your opinion for what it's worth. You
APPARENTLY sit behind a keyboard like Mx, make judgment. I am in a
plane.
At the end of the flight, I am the one that has to land, not you so I
am comfortable with my process. Again, while nice to know I can
descend below MDA before MAP thanks to Mark and Bob getting me up to
speed, my safety parameters will continue to err on the side of the
thought process altitude is my friend. My way still REASONABLY (not
guarantee) assures me gliding distance to the runway should the fan
quit.
You are sadly mistaken if you think that I don't work with or not
concerned about ATC operations. Don't believe me, watch my boring
videos as you call it. I have more then plenty to show that I
willingly accommodate to ATC requests outside of my normal operating
parameters but within my safety parameters.
Perfect I am not Sam, don't profess to be and never will be as long as
I am on the top side of where the green grass grows. I even got a
video where I made a mistake, thought I was cleared for an approach
and posted it so others can learn. But apparently you are too good to
watch my videos.
Direct Air Executive BAe 125-800B @ Edinburgh Drew Malcolm Aviation Photos 0 August 18th 09 11:14 AM
Neoconservatives have taken over the Executive Branch NOMOREWARFORISRAEL[_2_] Naval Aviation 0 October 8th 08 11:57 PM
Boeing DreamLifter at the Charleston Air Show 4-26-08 Jim Austin Aviation Photos 0 April 27th 08 07:48 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
flying clubs in Charleston, SC Guillermo Piloting 1 June 22nd 05 02:50 PM
