On Mar 17, 8:49*pm, Bruce Hoult wrote:
On Mar 18, 2:00*am, toggles mcfarley wrote: Hi, *after a hiatus of nearly 20 years I'd like to start soaring again only this time I'm carrying a few extra pounds. Having decided on this last year I started working on the weight in Jan and am down to 230lb in boxers though I am continuing work on it. It's really not a big deal. Yeah, most gliders have the seats placarded as 110 kg (242.5 lb), but it's not as hard a limit as some people like to make out. All gliders are built to take at least 5g of acceleration at the placarded maximum weights, so they have huge amounts of reserve strength in normal flying never going above 2 - 3 Gs. There are a number of things that impose weight limits, but the main one for the standard 110 kg per-seat limit is that the seat belt straps and mounting points are rated for a 40g load with a 110 kg pilot in the event of a crash. If you're a bit over, like me, then try to keep any crashes down to 35g. Weight of the non-lifting parts is an important limit. You can compensate for that one with a light instructor, in which case feel free to throw the beast around as much as you like. Otherwise go easy on the aerobatics and fly a bit slower in rough air than the book says. The other technical thing to worry about is CofG. *Most gliders are very tolerant of a too-forward C of G. It's pretty common to not be able to completely trim out the elevator force in a thermalling turn, even for pilots within the placarded limits, but you'd have to be grossly out of trim for it not to fly ok. I'm not very proud of this, but I once forgot to look under the seat for ballast and took off in a Janus with around 145 - 150 kg in the front seat, between me and the ballast I didn't notice, and with a reasonably large guy in the back seat as well. I did notice on liftoff that the stick needed to be maybe half an inch further back than normal, but it flew just fine with *no problems at all in tight thermalling or in the flare on landing, and it could still be stalled at right around the normal speed. More of a worry, especially with operators in the USA, seems to be insurance. Some places are absolutely strict about doing everything by the book. As far as I can tell they are worried about claims being denied in the event of an accident. Or maybe being sued, I don't know. *Here in NZ a claim could only be denied if exceeding a particular placarded limit can be shown to have contributed to the crash, but it may be different elsewhere. *Excess weight is of great concern in powered aircraft as it can easily contribute to failure to take off in the available space, or failure to get an adequate rate of climb, but that is far less of an issue in gliders where we regularly throw 200 kg of ballast in the wings and we're probably only talking at most 10 or 20 kg extra in a pilot. *Maybe it's a different attitude here but, for example, it is absolutely standard for agricultural operators to take off at 30% over the manufacturer's MTOW and the aviation authorities and insurers are happy with it as long as the excess can be jettisoned in a few seconds. Many BGA gliders get a weight concession for non-aerobatic flights, but that's strictly a BGA matter AFAIK. Not sure if it will apply after EASA gets done. |
Horney to Soar! | GARY BOGGS | Soaring | 5 | January 9th 10 04:15 PM |
XC-Soar | [email protected] | Soaring | 4 | January 26th 09 04:06 PM |
Get out of the Cold and SOAR! | Mike Schumann | Soaring | 4 | January 22nd 09 06:03 AM |
XC Soar and iPaq 310? | Brad[_2_] | Soaring | 4 | November 19th 08 12:30 PM |
why do you soar? | Mark James Boyd | Soaring | 27 | October 21st 03 07:48 PM |
