I don't know of any sailplane design that uses full span single surface
flaperons. I know I'm getting in late on this but the original LS-3 had one full- span control surface per wing panel. It was fairly flexible (said anyone who ever removed one from the wing for maintenance) and apparently required a fair amount of lead to mass balance (IIRC, 40 lbs. was mentioned, probably split between left and right). The result was that the wings were not only quite heavy (175 lbs.each) but the balance was biased towards the trailing edge, making it more awkward to handle during rigging. Maximum flap settings were -7 to +10 degrees, probably to prevent the one-piece surface from distorting or even splitting/buckling at the trailing edge at higher wing deflections. The wing itself was very stiff (probably another reason for its weight since this was pre-carbon fibre) so the deflection in turbulence was low (read: it was a rough ride on the ridge). It sounds a little odd but the glider was a joy to fly and both climbed and ran very well when new. Alas, LS-3s experienced shrinkage over the spar caps over time, which hurt the cruise performance though they still climbed well. Some owners (including me) sanded and/or added gel coat/ filler to restore the original profile and the glider was transformed, making it equal to the ASW 20, Ventus, and LS-6 of its day. It's still a great, wonderfully strong airplane with a lot of performance that gives its owners a great deal (for one with a good finish). Not to be confused with the LS-3a or LS-3 17, both of which had more conventional flap/aileron control surfaces and lighter wing panels. Chip Bearden ASW 24 "JB" USA |
On Mar 19, 2:58*pm, Chip Bearden wrote:
I don't know of any sailplane design that uses full span single surface flaperons. I know I'm getting in late on this but the original LS-3 had one full- span control surface per wing panel. It was fairly flexible (said anyone who ever removed one from the wing for maintenance) and apparently required a fair amount of lead to mass balance (IIRC, 40 lbs. was mentioned, probably split between left and right). The result was that the wings were not only quite heavy (175 lbs.each) but the balance was biased towards the trailing edge, making it more awkward to handle during rigging. Maximum flap settings were -7 to +10 degrees, probably to prevent the one-piece surface from distorting or even splitting/buckling at the trailing edge at higher wing deflections. The wing itself was very stiff (probably another reason for its weight since this was pre-carbon fibre) so the deflection in turbulence was low (read: it was a rough ride on the ridge). It sounds a little odd but the glider was a joy to fly and both climbed and ran very well when new. Alas, LS-3s experienced shrinkage over the spar caps over time, which hurt the cruise performance though they still climbed well. Some owners (including me) sanded and/or added gel coat/ filler to restore the original profile and the glider was transformed, making it equal to the ASW 20, Ventus, and LS-6 of its day. It's still a great, wonderfully strong airplane with a lot of performance that gives its owners a great deal (for one with a good finish). Not to be confused with the LS-3a or LS-3 17, both of which had more conventional flap/aileron control surfaces and lighter wing panels. Chip Bearden ASW 24 "JB" USA And due to the lead in the wings, the German speakers in this group will understand why the "LS-Drei" was referred to as the LS-Blei"... Ray Lovinggood Carrboro, North Carolina, USA |
I've heard the LS-Blei joke many times, and laughed ruefully.
![]() Interestingly, however, while the wings ARE heavy (my entire ASW 24 wing weighs as much as the root end of my LS-3 wing!), they're comparable to those of the ASW 20B, a much more highly thought of glider with almost identical performance (when the LS-3 wings are profiled properly, that is). Pursuant to the original poster's question, I should have added that the LS-3 has large, very effective conventional dive brakes and does not rely on the flaps for glide path control. Also, while the ailerons are light and very effective when the flaperons are set at 0 to 10+ degrees, the stick is very stiff with the flaperons at -7 degrees (at least in my old glider). I didn't have much ridge time in my LS-3 but I recall on more than one occasion yanking the flaps down when encountering a strong rolling motion so that I could apply countering aileron. This also had the effect of lifting me off the ridge at the same time. It was a nice combination but I would have prefered just being able to roll a little easier. Pilots with more ridge time might disagree this was necessary but the ailerons were still very stiff. I presume this was from the geometry of the mixer since much of it was apparent even on the ground. I hope I'm not making the LS-3 out to be unpleasant in any way. It was a great glider that I flew happily for many years. Chip Bearden ASW 24 "JB" USA |
On Mar 20, 4:27*pm, Chip Bearden wrote:
I've heard the LS-Blei joke many times, and laughed ruefully. ![]() Interestingly, however, while the wings ARE heavy (my entire ASW 24 wing weighs as much as the root end of my LS-3 wing!), they're comparable to those of the ASW 20B, a much more highly thought of glider with almost identical performance (when the LS-3 wings are profiled properly, that is). FWIW, 20B wings are 155 lbs ea. Go find your old -3 and let's go race. It'll be tough luck for you if there's any rain on course, won't it grin. -Evan Ludeman / T8 |
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): | [email protected] | Naval Aviation | 0 | January 27th 07 02:18 PM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
Flaperons | Lou Parker | Home Built | 26 | November 15th 04 04:40 AM |
