I have had problems like this before, and it turned out to be the DAT
file format. It's easily edited using Notepad. Once, I found that GNII was choking on a line that exceeded 72 or 80 characters (can't remember which). Trim any long lines down and see if that helps. Another time, I found that there was a snafu with the line numbers. The initial line numbers proceeded smoothly from 1 up to 199, then started over again instead of progressing as they should have into the 200s. I simply hand edited the initial numbers and things worked fine. Also, there was a limit of 256 waypoints in Cambridge GPS devices - if you have more waypoints than say, 240, you might try editing some out to see if that helps. You might also try removing any SUA files into GNII, just to keep things simple. Good luck! -John On Mar 21, 12:12 pm, Ryan Spicer wrote: Hi all, I'm trying to help a club member upload updated waypoint (.dat) files onto his Compaq Aero 1520 for use with GlideNavigator II v3.0. I'm an IT guy, but pretty new to the world of soaring software. We've downloaded the .dat file (http://soaringweb.org/TP/ASA/nm_asa10.dat). It opens correctly in SeeYou, and when we copy it to PocketPC/Storage Card/My Documents, it appears in the list of WP files from within GNII, but when we select "add," to add it to the list of active waypoint files, and remove the old .dat, no waypoints are available within GNII. Does anyone have any idea what might be causing the problem? What other information should I be looking at to diagnose this? |
I think you are downloading the wrong file for GNII.
1) There are lots of files that end in .dat or .txt on the World Wide Turnpoint Exchange web site (http://soaringweb.org/TP) but only one kind that works with GNII. I believe that all the GNII files are .txt, at least mine are. Once you navigate to the correct country (and then state and then location within the state), click on "Files formatted for downloading and importing into your programs". Then look for "Soaring Innovations Glide Nav II". Click on the icon of four hands holding a file (I think that is what the icon is) to download the file. Don't click on the Eyeglass icon (which opens the file) and then doing a save-as ~ I find that the resulting file doesn't always work. 2) Make sure that the .txt file is stored in the same directory as the GNII executable. I keep all the files right at the root of "My Documents" (on my memory card). If GNII can see the files in the "SUA and WA Files" menu, then you have them in the right place. Again, GNII will find and seem like it is reading .txt and .dat, but only .txt files specifically formatted for GNII will work correctly. 3) There is a Yahoo groups for GNII users. You and/or your friend should join. It isn't very active until you ask a question. http://groups.yahoo.com/group/GNII/. 4) Paul Remde is *THE* go-to guy for GNII questions. His web site has some how-to documents which are helpful. http://cumulus-soaring.com/gn.htm Some comments on the above comments. 1) I always keep all of my files on the memory (CF) card on my HP 2215. Never had a problem. The advantage is that I never have to worry about keeping the PDA charged up between flights (so I don't loose the built in memory contents. And I can edit all the contents on the memory card from within my PC (via a card reader). I find that much easier. 2) Only older Cambridge GPS devices have the 256 waypoint issue I believe. The Cambridge 302 and 302A has a much larger memory. Then again I don't download waypoints into my Cambridge 302, I keep them in my PDA only. I hope that this helps. Let us know. As always, "my $0.02". - John DeRosa http://aviation.derosaweb.net |
OK, I am not too proud to admit that I was wrong. Ouch. GNII will
work with .dat files. I went to the Exchange and got a hold of the appropriate Arizona file, which was a .dat, loaded it into my PDA and it works just fine. In my case the correct file was named "asa_2010.dat" which is different than the file you mention above. So I still stand behind that you probably have the wrong file for GNII. Could this be an issue with the old Compaq 1500 series and the Operating System it uses? - John |
Hi,
GNII will work fine with waypoint files with up to 2000 waypoints. The files on John Leibacher's Worldwide Turnpoint Exchange (www.soaringweb.org) are all created by John and will work in GN II. But you must be sure to get the correct file type. You can use either "Cambridge" files or "Glide Navigator II" files. You cannot use "Glide Navigator I" or "Glide Navigator" files. They are for the early 1990s version of Glide Navigator for the HP95 (if I'm remembering correctly) computer. Due to the potential for confusion on that issue, I always recommend going to the "Cambridge" files. The file extension is ".dat" by default, but GN II will still open the files if you change the file extension to ".txt". I usually leave the file extension at .dat, but some pilots change it to .txt so the file can be edited using PocketWord on the PDA. PocketWord doesn't know what a .dat file is. It doesn't matter whether you put the waypoint files into the memory card's "My Documents" directory, or the PDA's "My Documents" directory. However, if you have different files in both places then GN II may "latch on" to the files in one of the locations and not notice the files in the other location. I normally keep all my files in the memory card's My Documents directory. It is also OK to put ALL the files in both locations - that way you don't lose files if the PDA loses its memory due to lack of charging, or of the memory card becomes corrupt or lost. If you can't get it working you can give me a call. I charge for technical support but I'm confident we can figure it out quickly. We can use web conferencing to allow me to view your computer screen. Best Regards, Paul Remde Cumulus Soaring, Inc. "jcarlyle" wrote in message ... I have had problems like this before, and it turned out to be the DAT file format. It's easily edited using Notepad. Once, I found that GNII was choking on a line that exceeded 72 or 80 characters (can't remember which). Trim any long lines down and see if that helps. Another time, I found that there was a snafu with the line numbers. The initial line numbers proceeded smoothly from 1 up to 199, then started over again instead of progressing as they should have into the 200s. I simply hand edited the initial numbers and things worked fine. Also, there was a limit of 256 waypoints in Cambridge GPS devices - if you have more waypoints than say, 240, you might try editing some out to see if that helps. You might also try removing any SUA files into GNII, just to keep things simple. Good luck! -John On Mar 21, 12:12 pm, Ryan Spicer wrote: Hi all, I'm trying to help a club member upload updated waypoint (.dat) files onto his Compaq Aero 1520 for use with GlideNavigator II v3.0. I'm an IT guy, but pretty new to the world of soaring software. We've downloaded the .dat file (http://soaringweb.org/TP/ASA/nm_asa10.dat). It opens correctly in SeeYou, and when we copy it to PocketPC/Storage Card/My Documents, it appears in the list of WP files from within GNII, but when we select "add," to add it to the list of active waypoint files, and remove the old .dat, no waypoints are available within GNII. Does anyone have any idea what might be causing the problem? What other information should I be looking at to diagnose this? |
How to import turnpoints into SeeYou | Scott Alexander[_2_] | Soaring | 5 | January 12th 10 12:03 PM |
convert turnpoints to KML for google earth? | chris | Soaring | 4 | January 15th 08 10:56 PM |
Region 6 contest turnpoints? | kirk.stant | Soaring | 0 | June 7th 07 07:14 PM |
2006 Region 9 turnpoints | [email protected] | Soaring | 0 | March 15th 06 04:02 AM |
Recording and Deleting Tasks and Turnpoints in the Volkslogger | Nyal Williams | Soaring | 3 | May 18th 05 09:42 PM |
