GlideNavigator II and SoaringWeb Turnpoints?
Old March 22nd 10, 02:31 PM posted to rec.aviation.soaring
Andy[_1_]
Default GlideNavigator II and SoaringWeb Turnpoints?
On Mar 21, 8:44*pm, Andy wrote:
On Mar 21, 10:12*am, Ryan Spicer wrote:
Hi all,
* I'm trying to help a club member upload updated waypoint (.dat)
files onto his Compaq Aero 1520 for use with GlideNavigator II v3.0.
I'm an IT guy, but pretty new to the world of soaring software. We've
downloaded the .dat file (http://soaringweb.org/TP/ASA/nm_asa10.dat).
It opens correctly in SeeYou, and when we copy it to PocketPC/Storage
Card/My Documents, it appears in the list of WP files from within
GNII, but when we select "add," to add it to the list of active
waypoint files, and remove the old .dat, no waypoints are available
within GNII. *Does anyone have any idea what might be causing the
problem? What other information should I be looking at to diagnose
this?
I have the ASA 2010 *tp file loaded on my Aero 1530 and it runs just
fine with with 2.3 beta 18 which, to the best of my recollection, *is
the same as 3 except for a different password scheme.
There are 3 versions on TP Exchange, name only, number before name,
and number after name. *The file should be loaded in the CF directory
- storage card/SUAsandWPs/ *or it can be loaded in the Aero 15xx
memory at mydocuments/sSUAsandWPs/
If the CF is present and the directory SUAsandWPs is there GN gets the
files from there, not from the local directory.
I'm currently using asa_2010.dat because that is my preferred format.
I have not tested nm_asa_10.dat with GN but have no reason to think
there is anything wrong with file.
Try putting the file in the correct directory and see if it works. *If
not I'll be at the field on Friday if you haven't solved it by then.
I'll be at the front end of the rope.
Andy (GY)
Ryan,
I downloaded the tp file using the link you published in the original
post, copied the file to my cf card in the SUAsand Wps subdirectory,
opened GNII, deleted the waypoint file I normally use, and added the
nm_asa10 file. GN loaded the new file and displayed the waypoints
correctly.
Note that when GN loads a new file it may assume a current position
that is at the "center" of the loaded waypoints. Depending on your
map scale you may not see any waypoints displayed. On restart, GN
will assume a position equal to the "home" airport coordinates if
there is one. For this file "home" is "El Tiro".
I also tried adding before delete, adding and not deleting, and it all
works as intended.
If you can't make it work, and can't wait til Friday, give me a call
in the evening. I'm in the TuSC directory. I'll just change you a
beer
Andy (GY)
How to import turnpoints into SeeYou Scott Alexander[_2_] Soaring 5 January 12th 10 01:03 PM
convert turnpoints to KML for google earth? chris Soaring 4 January 15th 08 11:56 PM
Region 6 contest turnpoints? kirk.stant Soaring 0 June 7th 07 08:14 PM
2006 Region 9 turnpoints [email protected] Soaring 0 March 15th 06 05:02 AM
Recording and Deleting Tasks and Turnpoints in the Volkslogger Nyal Williams Soaring 3 May 18th 05 10:42 PM
