On Mar 23, 8:20*am, Tony wrote:
Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley |
On Mar 23, 7:24*am, Frank Whiteley wrote:
On Mar 23, 8:20*am, Tony wrote: Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley I don't know CBSIFTCB. I use A ltimiter B elts B allast C ontrols C anopy C able D ivebrakes D irection (wind) E mergency plan ... and for landing: F laps U ndercarriage S peed T rim A irbrakes L ook L and |
Good lists.
The only things I've forgotten multiple times a Drinking water (sitting on the hose) Oxygen (main valve closed) Sunglasses (left in the car) They won't cause an accident - but the first two require coming back to land. 9B |
Nine Bravo Ground wrote:
Good lists. The only things I've forgotten multiple times a Drinking water (sitting on the hose) Oxygen (main valve closed) Sunglasses (left in the car) They won't cause an accident - but the first two require coming back to land. Just in case you haven't thought of this: * water is a tough one. I've used a clip to hold it out of the way; the current glider, it just goes in the side pocket. * invent/devise/whatever a cable/lever/remote electric valve that lets you open the bottle while flying. I used bicycle cable to a simple bolt-on lever to the oxygen knob on the bottle in my Libelle. Easy - it only has to be cracked less than a quarter turn. My other four gliders had the bottle where a determined pilot could reach back to the baggage area or beside himself and turn it on. * buy a pair of sunglasses that _never_ leave the glider (easy for me because I don't have prescription glasses, but cheez! at least put a pair of clip-ons in the pocket!). -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Mar 23, 8:03*pm, Eric Greenwell wrote:
Nine Bravo Ground wrote: * * invent/devise/whatever a cable/lever/remote electric valve that lets you open the bottle while flying. I used bicycle cable to a simple bolt-on lever to the oxygen knob on the bottle in my Libelle. Easy - it only has to be cracked less than a quarter turn. My other four gliders had the bottle where a determined pilot could reach back to the baggage area or beside himself and turn it on. A couple of points Mountain High has a clever remote valve operating device for their cylinders. Some older oxygen cylinder valves may leak past the stem if not fully opened. I open O2 valves fully to seat the stem seal. |
On Mar 23, 8:31*am, Grider Pirate wrote:
On Mar 23, 7:24*am, Frank Whiteley wrote: On Mar 23, 8:20*am, Tony wrote: Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley I don't know CBSIFTCB. *I use A ltimiter B elts B allast C ontrols C anopy C able D ivebrakes D irection (wind) E mergency plan .. and for landing: F laps U ndercarriage S peed T rim A irbrakes L ook L and C ontrols B allast S traps I nstruments F laps T rim C anopy B rakes W ater U ndercarriage L loose items F laps S peed T rim A irbrakes L ook L and as the eventual migration from USTALL in the late '70's. Some of the liturgy of soaring. |
On Mar 23, 7:48*am, Frank Whiteley wrote:
On Mar 23, 8:31*am, Grider Pirate wrote: On Mar 23, 7:24*am, Frank Whiteley wrote: On Mar 23, 8:20*am, Tony wrote: Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley I don't know CBSIFTCB. *I use A ltimiter B elts B allast C ontrols C anopy C able D ivebrakes D irection (wind) E mergency plan .. and for landing: F laps U ndercarriage S peed T rim A irbrakes L ook L and C ontrols B allast S traps I nstruments F laps T rim C anopy B rakes W ater U ndercarriage L loose items F laps S peed T rim A irbrakes L ook L and as the eventual migration from USTALL in the late '70's. *Some of the liturgy of soaring. Does "Land" mean anything beyond the obvious? 9B |
On Mar 23, 9:01*am, Nine Bravo Ground wrote:
On Mar 23, 7:48*am, Frank Whiteley wrote: On Mar 23, 8:31*am, Grider Pirate wrote: On Mar 23, 7:24*am, Frank Whiteley wrote: On Mar 23, 8:20*am, Tony wrote: Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley I don't know CBSIFTCB. *I use A ltimiter B elts B allast C ontrols C anopy C able D ivebrakes D irection (wind) E mergency plan .. and for landing: F laps U ndercarriage S peed T rim A irbrakes L ook L and C ontrols B allast S traps I nstruments F laps T rim C anopy B rakes W ater U ndercarriage L loose items F laps S peed T rim A irbrakes L ook L and as the eventual migration from USTALL in the late '70's. *Some of the liturgy of soaring. Does "Land" mean anything beyond the obvious? 9B IIRC, in the original USTALL I learned in 1977 the second L (modified in later club checks) was 'Look again', which is good advice. |
On Mar 23, 9:37*pm, Frank Whiteley wrote:
On Mar 23, 9:01*am, Nine Bravo Ground wrote: On Mar 23, 7:48*am, Frank Whiteley wrote: On Mar 23, 8:31*am, Grider Pirate wrote: On Mar 23, 7:24*am, Frank Whiteley wrote: On Mar 23, 8:20*am, Tony wrote: Seems to me that it's been a while since we had a good brouhaha over pretakeoff checklists. *Most of use use either ABBCCCDDE (or is it AABBCCDDE? Or ABBBCCCCDDEEFG?) or CBSIFTCB or some other variant. *I'm curious what you use and WHY? *What have you added or subtracted to the "base" checklist to fit your specific glider or operation, or to prevent problems you have encountered. I personally use CBSIFTCB in all the gliders I fly. After that is complete I'm OK hooking up the rope, then I review WET (Wind, Emergency, Traffic) and give the signal to launch. Ditto the checklist you use, mostly due to law of primacy. Frank Whiteley I don't know CBSIFTCB. *I use A ltimiter B elts B allast C ontrols C anopy C able D ivebrakes D irection (wind) E mergency plan .. and for landing: F laps U ndercarriage S peed T rim A irbrakes L ook L and C ontrols B allast S traps I nstruments F laps T rim C anopy B rakes W ater U ndercarriage L loose items F laps S peed T rim A irbrakes L ook L and as the eventual migration from USTALL in the late '70's. *Some of the liturgy of soaring. Does "Land" mean anything beyond the obvious? 9B IIRC, in the original USTALL I learned in 1977 the second L (modified in later club checks) was 'Look again', which is good advice. I use "BUFSTALL". Ballast: (Dump takes up to 10 minutes so it's first - "S" turn while looking back or check shadow to make sure water is going overboard.) Undercarriage: (Approaching and circling field with gear down lets people know I want to land - I have two gear warning systems for backup.) Flaps: (Set as appropriate or think about when and where to set them, i.e. go to full flaps on short final), Speed(s): (Select two speeds for conditions: a faster pattern speed and a slower, yellow triangle "over-the-fence" speed.) Trim-set: Air brakes-check: (I've found them frozen on several occasions and once only one side opened.) Look: (Final check for traffic on the ground and in the air, select aim, touchdown and stopping points which will be very different if "A" didn't work.) Land. The final L for Land isn't redundant. It's a reminder the checklist is complete and it's time to focus 100% of my attention to making a safe, accurate landing. There's a 1000 other things that could be discussed for inclusion such as radio calls. I think a "landing checklist" should be as short as possible while covering the basic items. "Basic" in the sense that it'll be expensive and/or I'll look stupid if they're overlooked. |
The ABC pre-takeoff checklist came from Schweizer gliders that had the
list posted on the instrument panel. I remember a CFI revalidation course I presented some years ago, where I asked the 80 CFIs to write the list on a piece of paper. Doris checked the results. Not a single instructor got the list correct. This indicates one of the primary problems: Pilots are not trained to memorize the list so it can be used in gliders without a posted checklist. Our ASK-13 has a factory supplied pre-takeoff checklist with two items: Close and lock canopy, close and lock dive brakes. My recent ten-year accident summary indicates 50% of glider fatalities occurred during the first few seconds of flight, so performing an adequate pre-takeoff checklist is an important ingredient to flight safety. The most common pre-takeoff checklist (English language) is CB-SIFT- CB. Most of us have added some letters to this list, inserting a W for “Wind,” And an all-important E for “Emergency plan.” This results in the recommended, CB-SWIFT-CBE. Arguably, this can be considered the basic universal per-takeoff checklist. The reality is this checklist is not universally adequate, because our gliders may have some complexity needing to be checked before takeoff. The factory-supplied checklist must be used, and takes precedence over a memorized checklist in case of some important item unique to that glider. In addition, there may be items important to check such as the flight computer, data logger, etc. My written pre-takeoff checklist is rather extensive (Duo Discus) and includes the factory items plus essential items like removing my wallet from my back pocket and unzipping my fly. For more information about this subject, you might consider a booklet titled , “Preventing Glider Accidents” or a DVD titled, “Preventing Launching Accidents” available on our web site: WWW.EGLIDER.ORG The DVD is especially suited for club safety meetings using a laptop and projector. Tom Knauff |
checklists | Private | Piloting | 5 | February 6th 08 12:48 PM |
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? | P S | Piloting | 7 | September 20th 07 07:29 PM |
Pre-launch Checklists. | Nyal Williams | Soaring | 28 | January 28th 06 03:30 PM |
Pre-launch Checklists. | keithw | Soaring | 0 | January 26th 06 02:54 AM |
maintenance checklists | tony roberts | Owning | 2 | January 25th 05 10:59 PM |
