On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote:
On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry |
On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote:
On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry Sorry to butt in -- i've been following this. If only Mark had all the cards. No, it can't be easily reversed even if it is only occasional during a lifetime. The problem now, is that once you are on meds for bp or any disorder for that matter, you cannot be taken off without *that* disorder returning (timing is everythin) or some other disorder caused by drug withdrawal, which can be worse or fatal. -- JM |
On Thu, 25 Mar 2010 13:49:31 -0400, John wrote:
On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote: On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry Sorry to butt in -- i've been following this. If only Mark had all the cards. No, it can't be easily reversed even if it is only occasional during a lifetime. The problem now, is that once you are on meds for bp or any disorder for that matter, you cannot be taken off without *that* disorder returning (timing is everythin) or some other disorder caused by drug withdrawal, which can be worse or fatal. ***** YOU* What do you know all i wanted was a public discussionand along you come with all your *****ING GODDAMNED* philosophies ans ****, go ***** yourself in the nose* -- Mark inventor/artist/pilot/guitarist/scientist/philosopher/ scratch golfer/cat wrangler and observer of the mundane. And much much more including wealthy beyond anything you can imagine. My website http://www.hosanna1.com/ www.myspace.com/gayincarolina |
On Thu, 25 Mar 2010 13:52:24 -0400, Mark wrote:
On Thu, 25 Mar 2010 13:49:31 -0400, John wrote: On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote: On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry Sorry to butt in -- i've been following this. If only Mark had all the cards. No, it can't be easily reversed even if it is only occasional during a lifetime. The problem now, is that once you are on meds for bp or any disorder for that matter, you cannot be taken off without *that* disorder returning (timing is everythin) or some other disorder caused by drug withdrawal, which can be worse or fatal. ***** YOU* What do you know all i wanted was a public discussionand along you come with all your *****ING GODDAMNED* philosophies ans ****, go ***** yourself in the nose* Mark, look, I'm only trying to help. You're off your meds aren't you? -- JM |
On Thu, 25 Mar 2010 13:54:46 -0400, John wrote:
On Thu, 25 Mar 2010 13:52:24 -0400, Mark wrote: On Thu, 25 Mar 2010 13:49:31 -0400, John wrote: On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote: On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry Sorry to butt in -- i've been following this. If only Mark had all the cards. No, it can't be easily reversed even if it is only occasional during a lifetime. The problem now, is that once you are on meds for bp or any disorder for that matter, you cannot be taken off without *that* disorder returning (timing is everythin) or some other disorder caused by drug withdrawal, which can be worse or fatal. ***** YOU* What do you know all i wanted was a public discussionand along you come with all your *****ING GODDAMNED* philosophies ans ****, go ***** yourself in the nose* Mark, look, I'm only trying to help. You're off your meds aren't you? *GODDAMMIT TO HELL* No i'm fully medicated to the fukken hilt and yes cocaine helps. -- Mark inventor/artist/pilot/guitarist/scientist/philosopher/ scratch golfer/cat wrangler and observer of the mundane. And much much more including wealthy beyond anything you can imagine. My website http://www.hosanna1.com/ www.myspace.com/gayincarolina |
On Thu, 25 Mar 2010 13:55:52 -0400, Mark wrote:
On Thu, 25 Mar 2010 13:54:46 -0400, John wrote: On Thu, 25 Mar 2010 13:52:24 -0400, Mark wrote: On Thu, 25 Mar 2010 13:49:31 -0400, John wrote: On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote: On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry Sorry to butt in -- i've been following this. If only Mark had all the cards. No, it can't be easily reversed even if it is only occasional during a lifetime. The problem now, is that once you are on meds for bp or any disorder for that matter, you cannot be taken off without *that* disorder returning (timing is everythin) or some other disorder caused by drug withdrawal, which can be worse or fatal. ***** YOU* What do you know all i wanted was a public discussionand along you come with all your *****ING GODDAMNED* philosophies ans ****, go ***** yourself in the nose* Mark, look, I'm only trying to help. You're off your meds aren't you? *GODDAMMIT TO HELL* No i'm fully medicated to the fukken hilt and yes cocaine helps. Marc, KB here, I remember you when you first came into alt.support.depression.manic, boy, you were something! What, we never figured out!! I see your back on the coke again. We told you that you cannot go off Prozac, Dilantin, etc Variables such as time taken, dose, state of the brain, age, and of course most importantly the drug, play a role. To give you an example, some cocaine addicts once successfully withdrawn, cannot just recover back to their pre-coke addiction state, but must take a substitute drug for the rest of their lives. This is a secondary problem in pharmacological treatment. Why not switch off the coke to say, psilocybin? |
On Thu, 25 Mar 2010 14:05:25 -0400, Krazee Brenda wrote:
Mark, look, I'm only trying to help. You're off your meds aren't you? *GODDAMMIT TO HELL* No i'm fully medicated to the fukken hilt and yes cocaine helps. Marc, KB here, I remember you when you first came into alt.support.depression.manic, boy, you were something! What, we never figured out!! I see your back on the coke again. We told you that you cannot go off Prozac, Dilantin, etc Variables such as time taken, dose, state of the brain, age, and of course most importantly the drug, play a role. To give you an example, some cocaine addicts once successfully withdrawn, cannot just recover back to their pre-coke addiction state, but must take a substitute drug for the rest of their lives. This is a secondary problem in pharmacological treatment. Why not switch off the coke to say, psilocybin? Hey Krazee! Good to hear from you, all these *GADDAMNED FUKKEN ******S* are giving me a bunch of ****. Hmm, trade in my coke for 'shrooms, eh? Would that fix my screwed up face too? www.myspace.com/gayincarolina |
Mark wrote:
On Thu, 25 Mar 2010 13:54:46 -0400, John wrote: On Thu, 25 Mar 2010 13:52:24 -0400, Mark wrote: On Thu, 25 Mar 2010 13:49:31 -0400, John wrote: On Thu, 25 Mar 2010 13:46:19 -0400, Mark wrote: At this point, I only want to know what Matthew and Luke have to say. -- pete |
On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry D00d, cool down, cool down, don't go all BPD on us! lol |
On Thu, 25 Mar 2010 13:43:44 -0400, (¯`·.¸Chris Millbank¸.·´¯) wrote: On Thu, 25 Mar 2010 13:42:05 -0400, Mark wrote: aka Manic Depressive. Bipolar Disorder is a name given to a behavior pattern. I can think of at least 5 different reasons why one would have this pattern. So what should *we* do? Find the source of your personal experience. The behaviour pattern is no longer a disorder if it doesn't interfer with the productivity of your life. ******* Mark Sort of, you got it backwards - if there was interference in the past which would constitute a disorder, the disorder is permanent and fluctuates, so it only appears to "go away". No, I don't have anything backwards. Just because you had it in the past, doesn't AT ALL mean it's permanent. In fact, some psychological abberations are simply "outgrown" with maturity. In the case of bipolar behaviour, it occured for a reason, and it can unoccur for a reason. Bipolar isn't a noun, it's a verb. I'm trying to have a decent discussion here and you come with all the *GODDAMNED* negativity, it makes me so fukking mad, why don't you grab your balls and rip them off your body, you SCUMBAG!!! ***** Mark The Angry See, this is why we can't discuss your disorders with you, you get all disorderly!! *ha* |
My EW is not talking to my SN-10 | Jim Archer | Soaring | 1 | March 29th 09 06:10 PM |
My EW is not talking to my SN-10 | Jim Archer | Soaring | 4 | March 29th 09 04:51 PM |
Attention Deficit Disorder... | [email protected] | Piloting | 16 | November 17th 06 05:17 AM |
Bipolar/Schizoaffective Disorder and Soaring | DL152279546231 | Soaring | 35 | June 14th 04 04:27 PM |
Gps with voice, "talking" GPS | gyrobob | Instrument Flight Rules | 4 | September 9th 03 12:11 AM |
