Frank,
I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. |
On Mar 28, 7:52*am, Coucked wrote:
Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) |
On Mar 28, 9:31*am, Frank wrote:
On Mar 28, 7:52*am, Coucked wrote: Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) Frank, what about the official data sheet at the faa website? My friend/AI Roger pulled that up when we did the w&b on my 19 last fall. Don't ask me exactly where it is since I searched fruitlessly to find that sheet again, but I know it's in there someplace! -- Matt |
The FAA TCDS for the V2b is he
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/133e98b92a385fdb862570c80050abd1/$FILE/G04CE.pdf and it does list the forward and aft CG range. I don't know how different the "x" variant is from the 2b. -John On Mar 28, 1:49 pm, mattm wrote: what about the official data sheet at the faa website? My friend/AI Roger pulled that up when we did the w&b on my 19 last fall. Don't ask me exactly where it is since I searched fruitlessly to find that sheet again, but I know it's in there someplace! -- Matt |
On Mar 28, 7:52*am, Coucked wrote: Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) If it's type certified, you might try looking here if you haven't already: http://rgl.faa.gov/Regulatory_and_Gu...e?OpenFrameSet They usually have all the cg limits, various stations (pilot, baggage, water ballast, ballast, etc), etc listed in the document. WD |
On Mar 28, 3:07*pm, Whiskey Delta wrote:
On Mar 28, 9:31*am, Frank wrote: On Mar 28, 7:52*am, Coucked wrote: Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) If it's type certified, you might try looking here if you haven't already: *http://rgl.faa.gov/Regulatory_and_Gu...keModel.nsf/Ma... They usually have all the cg limits, various stations (pilot, baggage, water ballast, ballast, etc), etc listed in the document. WD oh, I see John beat me to it... sorry for the double post. |
On Mar 28, 9:31*am, Frank wrote: On Mar 28, 7:52*am, Coucked wrote: Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) If it's type certified, you might try looking here if you haven't already: *http://rgl.faa.gov/Regulatory_and_Gu...keModel.nsf/Ma... They usually have all the cg limits, various stations (pilot, baggage, water ballast, ballast, etc), etc listed in the document. WD Thanks - that did it! Frank (TA) |
On Mar 28, 12:26*pm, Frank wrote:
Thanks - that did it! Frank (TA) I don't see how it is possible, or legal, for the flight handbook of any modern glider not to include the forward and aft CG limits. Schleicher provides a graphical depiction of the complete mass and CG envelope. As discussed here previously the limitations may not be as simple as a single forward, and a single aft, limit. When you received the additional information did it agree with what was already published in the handbook? Andy (GY) |
Frank wrote:
On Mar 28, 7:52 am, Coucked wrote: Frank, I have a spread sheet I can send you that only requires you put your moment arms in and your weights and will calculate the rest. Set up for and ASW-20. Dave, Thanks, but this doesn't help for a V2bx unless I know the corresponding forward/aft CG limits ;-). Frank (TA) Those are obtained from the BGA datasheets - just go to the BGA technical section. Bruce --- news://freenews.netfront.net/ - complaints: --- |
blanik life limits, and new AD | john | Soaring | 1 | October 7th 07 12:55 AM |
Crosswind rental limits? | nrp | Piloting | 30 | November 7th 06 12:26 PM |
Canopy limits - How tall are you ??? | Montblack | Home Built | 11 | April 15th 06 03:50 PM |
Canopy limits - How tall are you ??? | Montblack | Piloting | 2 | April 13th 06 04:41 AM |
Insurance - smooth limits | Paul kgyy | Owning | 22 | May 13th 05 07:56 PM |
