Hi Glen,
The error mentioned below may be simply that the communication port on the PDA is already in use by another application. Try doing a soft reset to the PDA immediately before running ConnectMe. If the VL is powered by the SN10 (which is likely), then when you power-down the SN10 you also power-down the VL - so it is rebooted. What logging interval is set on the VL? Is the VL memory cleared immediately before flight? Those are the only things that come to mind. Best Regards, Paul Remde Cumulus Soaring, Inc. "Laura betzoldt" wrote in message ... Volkslogger shuts down after about 15 min into flight, can turn off and on ILEC sn-10 and volks will start working again. Can’t down flight from Volks to PDA with see you mobile. I get ERROR OCCURRIED COMMUNICATION WITH/DEVICE EXTERNAL CODE (-10) on Connect Me. Just had Volks calibrated?? Any ideas Glen |
On Mar 31, 7:39*pm, "Paul Remde" wrote:
Hi Glen, The error mentioned below may be simply that the communication port on the PDA is already in use by another application. *Try doing a soft reset to the PDA immediately before running ConnectMe. If the VL is powered by the SN10 (which is likely), then when you power-down the SN10 you also power-down the VL - so it is rebooted. What logging interval is set on the VL? NOT SURE Is the VL memory cleared immediately before flight? YES Those are the only things that come to mind. Best Regards, Paul Remde Cumulus Soaring, Inc. "Laura betzoldt" wrote in message ... Volkslogger shuts down after about 15 min into flight, can turn off and on *ILEC sn-10 and volks will start working again. *Can t down flight from Volks to PDA with see you mobile. I get *ERROR OCCURRIED COMMUNICATION WITH/DEVICE * * EXTERNAL CODE (-10) * on Connect Me. Just had Volks calibrated?? * Any ideas * * Glen |
Volkslogger help need | Nick Kennedy | Soaring | 8 | March 17th 09 04:48 PM |
Looking for a Volkslogger | Ron Gleason | Soaring | 1 | December 14th 06 04:09 AM |
Volkslogger + Mac | Wouter Wessels | Soaring | 14 | April 14th 05 10:05 PM |
Looking for a Volkslogger | Del Ogren | Soaring | 0 | August 20th 04 03:00 AM |
Volkslogger | Going fer it | Soaring | 1 | February 17th 04 04:43 AM |
