On Apr 1, 6:13*am, AGL wrote:
On Mar 31, 10:14*pm, Randy wrote: A friend of mine has a Schweizer 1-35 and we need to find the correct polar numbers to put into his SeeYou Mobile program. Check which of the three models of 1-35 it is. * Numbers for a "C" that doesn't retract are different. There are very clear graphs of the polars updated in 2002 in the latest Flight Manual. * There are not too many "A" models, so I'm not sure about that one since the Flight Manual doesn't specify differences in the polar. *Seehttp://members.goldengate.net/~tmrent/soar/docs/135/types135.htm I use the following numbers are for a "regular" 1-35 with a retractable wheel. The numbers are good for final glides from 5 nm out, dry @ 685# * * (We have low cloud bases here) * I use "SoarPilot," but a polar is a polar. *Your mileage may vary given the wide range of wing finishes I've seen on 1-35's. 53 kts *-1.42 kts 82 kts -3.5 kts 109 kts -7.58 Be careful with that "stall speed" number. *It can vary from 30 kts to 56 kts, depending on model, flap settings, and ballast. *Check page 10 of the Flight Manual. ms Wow - be careful what you put into your glide calculator. You have a lot riding on it, like your butt. First of all, units matter. SeeYou accepts as settings a variety of units for airspeed and vertical speed. The manual doesn't appear to say this explicitly, but I believe you need to enter coefficients for the polar derived from the same system of units you specify in SeeYou's settings. Second, a,b and c are the coefficients of a quadratic curve that is a best fit for the glider polar. You generate this quadratic by picking three points off the polar - preferably for speeds that you typically fly. Best L/D, medium cruise, fast cruise, for example. Pick speeds for no water ballast - the computer can figure out the ballast effects. The three pairs of speeds, plugged into the generic quadratic formula y=ax^2+bx+c will give you three equations with three unknowns, which you can solve using high school algebra. I suspect this is what Paul's spreadsheet does. If you are using knots as the units for airspeed and vertical speed then the above pairs of polar coordinates yield: a -0.0014 b 0.1197 c -3.7796 This gives a polar with a best L/D of 37 at 52 knots, an L/D of 25 at 80 knots and an L/D of 17 at 100 knots. You should check the calculations and figures yourself to ensure they are correct as I have not looked at a polar directly and it's your friend's but that will end up short of the airfield on final glide if there are errors in the data or the math. Hope that helps, 9B |
On Apr 1, 7:19*am, Andy wrote:
On Apr 1, 6:13*am, AGL wrote: On Mar 31, 10:14*pm, Randy wrote: A friend of mine has a Schweizer 1-35 and we need to find the correct polar numbers to put into his SeeYou Mobile program. Check which of the three models of 1-35 it is. * Numbers for a "C" that doesn't retract are different. There are very clear graphs of the polars updated in 2002 in the latest Flight Manual. * There are not too many "A" models, so I'm not sure about that one since the Flight Manual doesn't specify differences in the polar. *Seehttp://members.goldengate.net/~tmrent/soar/docs/135/types135.htm I use the following numbers are for a "regular" 1-35 with a retractable wheel. The numbers are good for final glides from 5 nm out, dry @ 685# * * (We have low cloud bases here) * I use "SoarPilot," but a polar is a polar. *Your mileage may vary given the wide range of wing finishes I've seen on 1-35's. 53 kts *-1.42 kts 82 kts -3.5 kts 109 kts -7.58 Be careful with that "stall speed" number. *It can vary from 30 kts to 56 kts, depending on model, flap settings, and ballast. *Check page 10 of the Flight Manual. ms Wow - be careful what you put into your glide calculator. You have a lot riding on it, like your butt. First of all, units matter. SeeYou accepts as settings a variety of units for airspeed and vertical speed. The manual doesn't appear to say this explicitly, but I believe you need to enter coefficients for the polar derived from the same system of units you specify in SeeYou's settings. Second, a,b and c are the coefficients of a quadratic curve that is a best fit for the glider polar. *You generate this quadratic by picking three points off the polar - preferably for speeds that you typically fly. Best L/D, medium cruise, fast cruise, for example. Pick speeds for no water ballast - the computer can figure out the ballast effects. The three pairs of speeds, plugged into the generic quadratic formula y=ax^2+bx+c will give you three equations with three unknowns, which you can solve using high school algebra. I suspect this is what Paul's spreadsheet does. If you are using knots as the units for airspeed and vertical speed then the above pairs of polar coordinates yield: a * * * -0.0014 b * * * 0.1197 c * * * -3.7796 This gives a polar with a best L/D of 37 at 52 knots, an L/D of 25 at 80 knots and an L/D of 17 at 100 knots. You should check the calculations and figures yourself to ensure they are correct as I have not looked at a polar directly and it's your friend's but that will end up short of the airfield on final glide if there are errors in the data or the math. Hope that helps, 9B While the units of sink and speed matter the convention is to use the a, b, c quadratic coefficients with sink in m/s and speed in km/h. Changing the units that SeeYou Mobile or SeeYou uses won't change the values of a, b or c that you need to enter. The Polar dialog in SeeYou (not SeeYou Mobile) has a little calculator built in where you can enter sink vs. speed numbers and derive a, b, c coefficients or visa versa. There the sink/speed numbers are dependent on the display units selected but SeeYou must be internally converting to standard units to calculate the a, b, c. Andrej can kick me if I'm wrong. Paul's spreadheet is very handy. Darryl Darryl |
On Apr 1, 11:40*am, Darryl Ramm wrote:
On Apr 1, 7:19*am, Andy wrote: On Apr 1, 6:13*am, AGL wrote: On Mar 31, 10:14*pm, Randy wrote: A friend of mine has a Schweizer 1-35 and we need to find the correct polar numbers to put into his SeeYou Mobile program. Check which of the three models of 1-35 it is. * Numbers for a "C" that doesn't retract are different. There are very clear graphs of the polars updated in 2002 in the latest Flight Manual. * There are not too many "A" models, so I'm not sure about that one since the Flight Manual doesn't specify differences in the polar. *Seehttp://members..goldengate.net/~tmrent/soar/docs/135/types135.htm I use the following numbers are for a "regular" 1-35 with a retractable wheel. The numbers are good for final glides from 5 nm out, dry @ 685# * * (We have low cloud bases here) * I use "SoarPilot," but a polar is a polar. *Your mileage may vary given the wide range of wing finishes I've seen on 1-35's. 53 kts *-1.42 kts 82 kts -3.5 kts 109 kts -7.58 Be careful with that "stall speed" number. *It can vary from 30 kts to 56 kts, depending on model, flap settings, and ballast. *Check page 10 of the Flight Manual. ms Wow - be careful what you put into your glide calculator. You have a lot riding on it, like your butt. First of all, units matter. SeeYou accepts as settings a variety of units for airspeed and vertical speed. The manual doesn't appear to say this explicitly, but I believe you need to enter coefficients for the polar derived from the same system of units you specify in SeeYou's settings. Second, a,b and c are the coefficients of a quadratic curve that is a best fit for the glider polar. *You generate this quadratic by picking three points off the polar - preferably for speeds that you typically fly. Best L/D, medium cruise, fast cruise, for example. Pick speeds for no water ballast - the computer can figure out the ballast effects. The three pairs of speeds, plugged into the generic quadratic formula y=ax^2+bx+c will give you three equations with three unknowns, which you can solve using high school algebra. I suspect this is what Paul's spreadsheet does. If you are using knots as the units for airspeed and vertical speed then the above pairs of polar coordinates yield: a * * * -0.0014 b * * * 0.1197 c * * * -3.7796 This gives a polar with a best L/D of 37 at 52 knots, an L/D of 25 at 80 knots and an L/D of 17 at 100 knots. You should check the calculations and figures yourself to ensure they are correct as I have not looked at a polar directly and it's your friend's but that will end up short of the airfield on final glide if there are errors in the data or the math. Hope that helps, 9B While the units of sink and speed matter the convention is to use the a, b, c quadratic coefficients with sink in m/s and speed in km/h. Changing the units that SeeYou Mobile or SeeYou uses won't change the values of a, b or c that you need to enter. The Polar dialog in SeeYou (not SeeYou Mobile) has a little calculator built in where you can enter sink vs. speed numbers and derive a, b, c coefficients or visa versa. There the sink/speed numbers are dependent on the display units selected but SeeYou must be internally converting to standard units to calculate the a, b, c. Andrej can kick me if I'm wrong. Paul's spreadheet is very handy. Darryl Darryl Good catch Darryl. On that basis I believe the values a a -0.00015 b 0.0125 c -0.5905 Of course it's RAS so you should do your own math. 9B |
| Thread Tools | |
| Display Modes | |
| SeeYou Mobile 3.0 now available | [email protected] | Soaring | 0 | February 4th 08 01:17 PM |
| Using mobile SeeYou | Robert Hart | Soaring | 3 | May 10th 06 10:42 PM |
| SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 01:25 AM |
| Mobile SeeYou & Winpilot | Ian Molesworth | Soaring | 8 | March 25th 04 02:07 AM |
| SeeYou Mobile | Robert Fidler | Soaring | 0 | March 17th 04 05:18 PM |
