SN10 USB connection
Old April 13th 10, 08:20 PM posted to rec.aviation.soaring
T8
Default SN10 USB connection
On Apr 13, 2:02*pm, Dave Nadler wrote:
(1) Winscore, or any scoring program, could care less what
kind of media used for the files. The scorer may however
complain if you show up with 5.25" floppy disks.
Winscore doesn't care. However the operating system does take a while
longer to recognize a USB drive. Experience shows that SD cards beat
any other option in the scoring shack by a country mile.
-T8
Old April 13th 10, 11:12 PM posted to rec.aviation.soaring
Eric Greenwell
-T8
What are scorers using for the OS - Win 98? Me? My XP computers find and
display a USB drive in 5-6 seconds vs 4-5 seconds for an SD card, not
enough time to go that country mile, even with 50 entrants. Does the
problem come from having 50 different USB drives, instead just 5 or 6
different ones?
Eric Greenwell - Washington State, USA (netto to net to email me)
Old April 14th 10, 12:40 AM posted to rec.aviation.soaring
Darryl Ramm
Winscore doesn't care. *However the operating system does take a while
longer to recognize a USB drive. *Experience shows that SD cards beat
-T8
different ones?
I also had trouble seeing a significant delay, and I was running
Windows 2000 under VMWare Fusion on a MacBook Pro (so some additional
overhead for device I/O though the virtualization software). There was
no noticeable difference in device detection speeds.
The internal operation of just about every internal SD card reader is
actually a USB interface, same with ExpressCard SD card readers.
PCMCIA is a bit different, but I'm surprised there would be a big
overhead just for USB device discovery. Is something strange going on
with autoplay?
I assume Dave's earlier comment about power consumption of USB to SD
card adapters referred to some of the larger desktop style ones, the
typical small SD to USB small adapters like my SanDisk MicroMate or
SimpleTech Bonzai draw very low currents. I don't have my USB breakout
cable handy or I'd measure the currents but I know it is low.
Darryl
Old April 14th 10, 01:21 AM posted to rec.aviation.soaring
Dave Nadler
Darryl
I have a small converter that looks like a normal USB memory
stick, with a tiny slot in the end for a uSD card (I use this for
turning in FLARM log files). The combo (adapter plus uSD card)
draws 100ma, which is the max our adapter sources.
What it needs all that power for I have no idea...
Your mileage may vary !
Best Regards, Dave
PS: In windows device manager, switch to connection view,
and you can see the USB current for each connected device.
No need for breakout cables...
Old April 14th 10, 01:49 AM posted to rec.aviation.soaring
Darryl Ramm
Darryl
Best Regards, Dave
You don't need to be in connection view do you?
Anyhow this does not work in a virtual machine like I am running. My
God, people still run Windows on native hardware? I keep mine locked
tightly is a safe container on the shelf and only open it when needed.
Darryl
Old April 14th 10, 01:23 PM posted to rec.aviation.soaring
Dave Nadler
Best Regards, Dave
Its the easiest way to find the hub controlling your device,
which is where you need to look at the power.
Depending on *which* virtualization scheme you are using
and its USB support, it may work. USB doesn't work in free
VirtualBox for example...
Darryl
Old April 14th 10, 04:03 AM posted to rec.aviation.soaring
Eric Greenwell
Darryl
Best Regards, Dave
I opened Device Manager, located my USB memory stick in the USB
controller list, opened Properties, but don't see power or current
listed in any of the tabs. The Generic hub did have a Power tab, but it
showed the requirement for the attached device (auxiliary display), not
actual current. Can you be more specific on which USB to look at, and
where in the Properties?
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
Old April 14th 10, 01:25 PM posted to rec.aviation.soaring
Dave Nadler
Darryl
draws *100ma, which is the max our adapter sources.
Best Regards, Dave
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
Start with "View by Connection".
Locate the USB hub controlling your device.
Look at properties, power tab...
This shows the max current negotiated (max to be provided
by USB host), not the instantaneous actual current.
Hope that helps,
Best Regards, Dave
Old April 14th 10, 12:56 AM posted to rec.aviation.soaring
T8
-T8
different ones?
Leo (Buckley) could tell you more, but afaik he doesn't read r.a.s.
On his system -- I've watched this -- SD cards are recognized much
faster than USB drives. If we all used USB drives with identical
drivers it would probably be a non-issue.
-T8
Old April 14th 10, 05:08 AM posted to rec.aviation.soaring
Andy[_10_]
-T8
different ones?
faster than USB drives. *If we all used USB drives with identical
-T8
Could it be that the scorer usually has the SD card reader plugged in
and recognized by the computer and that somehow speeds the mounting of
individual contestants' SD cards whereas the USB drives need to get
recognized independently for each contestant?
9B
ILEC SN10 release 2.35 Dave Nadler Soaring 7 March 27th 10 07:46 PM
SN10 B for sale Dick[_3_] Soaring 1 November 29th 09 06:31 PM
SN10 Remote Repair Mike the Strike Soaring 5 February 19th 08 02:24 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 05:11 AM
SN10 Remote BMacLean Soaring 0 August 24th 03 10:32 PM
