SR-71
Old April 19th 10, 04:41 AM posted to alt.binaries.pictures.aviation
Maple1
Default SR-71
Not that one it is an sr71 I believe that is a later modification
Canuck wrote:
"Morgans" wrote in message
"Glenn" wrote in message
In this picture, a couple feet back on the chine on both sides, there
is a blunted, pushed in area on the chines. Almost looks like the
nose ran into a round hole in a wall, and dented the chines. Of
course, I doubt that happened.
What is the story with that? I had never noticed that on other models
of the 71. Is that damage, or a feature, and if it is a feature, what
is it designed to do - if you or someone knows?
Jim in NC
The original aircraft from which the SR-71 sprang was the Lockheed A-11.
It then morphed into the YF-12. Finally, it became the SR-71. The A-11
and the YF-12A sported a different nose/chine configuration than what
you finally got to see on the SR_71.
Nick
Old April 19th 10, 06:14 AM posted to alt.binaries.pictures.aviation
Canuck[_9_]
Default SR-71
"Maple1" wrote in message
Jim in NC
and the YF-12A sported a different nose/chine configuration than what you
Nick
Hmmmm....curious/strange. I went and had a look and you are right. My foggy
memory failed me. The A-11/YF-12A nosecones were different but not like what
is present in that image. It almost seems like an intermediate morph between
the A-11/YF-12A and the SR-71.
The other possibility is that someone bent it.
Nick
Click image for larger version
Old April 19th 10, 02:00 PM posted to alt.binaries.pictures.aviation
John Szalay
Default SR-71
"Canuck" wrote in
foggy memory failed me. The A-11/YF-12A nosecones were different but
not like what is present in that image. It almost seems like an
intermediate morph between the A-11/YF-12A and the SR-71.
Nick
Attachment decoded: YF-12A.jpg
------=_NextPart_000_0009_01CADF55.58129EF0--
This photo is the YF-12A and the chine mod is for the ASG-18 fire
control radar. to insure directional stability for the chine being cut
three small fins were added to the rear of the underside of the YF-12A
Old April 19th 10, 06:14 PM posted to alt.binaries.pictures.aviation
Canuck[_9_]
Default SR-71
"John Szalay" wrote in message
42...
"Canuck" wrote in
Nick
So, I did get it right. I guess they tried a number of different chines/nose
cone profiles before they settled on what is the more familiar one from the
SR-71.
Neat.
Nick
Old April 19th 10, 08:13 PM posted to alt.binaries.pictures.aviation
John Szalay
Default SR-71
"Canuck" wrote in
42...
cut three small fins were added to the rear of the underside of the
YF-12A
chines/nose cone profiles before they settled on what is the more
familiar one from the SR-71.
Neat.
Nick
Yep but there were only 3 YF-12A built and two crashed, the one
left is at Dayton. there were others in the production, but the
airframes were changed to the SR-71, can't recall how many off hand.
there were several nose mods tried, and the "dented" one was the last
& it was for the ECM antenna.
(from what I remember , NASA had a canard on atleast one test..)
have to go to the books to get the model/test...)
there were also several noses depending on the mission.
much like the Dragon lady has....
again got to go to the books, and can,t right now. got to
finish mowing the front yard.. .
Old April 20th 10, 10:15 PM posted to alt.binaries.pictures.aviation
Morgans[_2_]
Default SR-71
I'm sure ECM should be instantly clear to me, but I'm not sure in this
case...
Electronic Counter Measures? I didn't know 71's needed them! g
Thanks for your interest. It is good to know
(but not surprising that someone in this great group)
that someone has the resources to get a line on this difference.
Jim in NC
Old April 20th 10, 11:31 PM posted to alt.binaries.pictures.aviation
John Szalay
Default SR-71
"Morgans" wrote in news:KPozn.119653$mn6.68680
@newsfe07.iad:
case...
ITs not a case of needing them,
its a case of "you need to know whom is looking at you." In CASE you may
need them..
Remember the U-2 did,nt need them, at first, because nothing could reach
them, but things & times change...
Old May 25th 10, 05:22 PM posted to alt.binaries.pictures.aviation
Al[_3_]
Default SR-71
When I was stationed at Greenham Common AB we had an IAT one year.
They brought an SR-71 in, the peace-campers that were camped outside
the gate got onto the field somehow and spray paintedo ne of the
panels of the aircraft. It cost many thousands of dollars to replace
the panel.
When the plane departed, it took off, did a nice slow circle around
the field, came in super low, then hit full power as it was directly
over their encampment kissed the sky. Meanwhile, the entire camp was
blown against the fenceline f the base, anything plastic, tents, etc,
was melted. It was a beautiful thing.
This was during the 1982-1985 time frame.
I wish I could find my pictures.
Just thought you'd all be interested in a little war story and a
laugh.
Al
