On Apr 22, 11:18*pm, Dave Doe wrote:
In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark |
On Apr 23, 6:27*am, Mark wrote:
On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? In reality it should configure the airplane at a reasonable attitude for climb at full throttle with airspeed somewhere around best angle of climb. I can tell you for sure in a Mooney if the trim is correct for rotation it is soon going to be adjusted as airspeed moves up. |
On Fri, 23 Apr 2010 04:29:37 -0700 (PDT), a wrote:
On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? *lol* Because it's Mark(ie) the bi-polar "pilot". -- A fireside chat not with Ari! http://tr.im/holj Motto: Live To Spooge It! |
![]() *lol* Because it's. |
On Apr 23, 7:29*am, a wrote:
On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Because I do what my flight instructor tells me, as per the check list, and we don't set trim until I've achieved significant altitude. In reality it should configure the airplane at a reasonable attitude for climb at full throttle with airspeed somewhere around best angle of climb. Which is what we're doing. I can tell you for sure in a Mooney if the trim is correct for rotation it is soon going to be adjusted as airspeed moves up. Which is exactly what I do, readjust the trim to maintain straight and level at my desired cruising speed. --- Mark |
On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Why would you think it doesn't? I think it's clear enough what neutral means here. The trim is even with the elevator. Elementary concept. --- Mark |
On Apr 23, 4:34*pm, Mark wrote:
On Apr 23, 7:29*am, a wrote: On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Why would you think it doesn't? I think it's clear enough what neutral means here. The trim is even with the elevator. Elementary concept. --- Mark Oh really? It depends on how the airplane is rigged. Most are rigged for effective flight, not effective take off. You'd give away airspeed if the trim tabs, assuming you have them, are not in trail at cruise. I can further assure you in some airplanes, my Mooney for example, you could look at the horizontal stabilizer elevator combination for a long time and have no idea of the trim setting. |
On Apr 23, 5:53*pm, a wrote:
On Apr 23, 4:34*pm, Mark wrote: On Apr 23, 7:29*am, a wrote: On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight..... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Why would you think it doesn't? I think it's clear enough what neutral means here. The trim is even with the elevator. Elementary concept. --- Mark Oh really? *It depends on how the airplane is rigged. Most are rigged for effective flight, not effective take off. You'd give away airspeed if the trim tabs, assuming you have them, are not in trail at cruise. I can further assure you in some airplanes, my Mooney for example, you could look at the horizontal stabilizer elevator combination for a long time and have no idea of the trim setting.- Hide quoted text - - Show quoted text - I tell ya what. Rather than me theorizing on why we do what we do at the academy, I'll call one of my instructors for a more definitive answer. No one around tonight, I already called. One is rated for jets, a former airline professional. And my other one also flys Chinook helicopters for the Army. Not having the checklist in hand I'm really commenting from memory. --- Mark |
On Fri, 23 Apr 2010 15:34:02 -0700 (PDT), Mark wrote:
On Apr 23, 5:53*pm, a wrote: On Apr 23, 4:34*pm, Mark wrote: On Apr 23, 7:29*am, a wrote: On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight.... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Why would you think it doesn't? I think it's clear enough what neutral means here. The trim is even with the elevator. Elementary concept. --- Mark Oh really? *It depends on how the airplane is rigged. Most are rigged for effective flight, not effective take off. You'd give away airspeed if the trim tabs, assuming you have them, are not in trail at cruise. I can further assure you in some airplanes, my Mooney for example, you could look at the horizontal stabilizer elevator combination for a long time and have no idea of the trim setting.- Hide quoted text - - Show quoted text - I tell ya what. Rather than me theorizing on why we do what we do at the academy, I'll call one of my instructors for a more definitive answer. No one around tonight, I already called. One is rated for jets, a former airline professional. And my other one also flys Chinook helicopters for the Army. Not having the checklist in hand I'm really commenting from memory. --- Mark Which one was trained in training mental health casenutz...like you, Mark(ie), that's the guy we want to shoot! -- A fireside chat not with Ari! http://tr.im/holj Motto: Live To Spooge It! |
On Apr 23, 6:34*pm, Mark wrote:
On Apr 23, 5:53*pm, a wrote: On Apr 23, 4:34*pm, Mark wrote: On Apr 23, 7:29*am, a wrote: On Apr 23, 6:27*am, Mark wrote: On Apr 22, 11:18*pm, Dave Doe wrote: In article d19343f7-1c71-49ff-b6ec-b847ddf6bad8 @g23g2000yqn.googlegroups.com, says... On Apr 21, 4:39*pm, george wrote: On Apr 22, 1:02*am, " wrote: On Apr 21, 12:44*am, Dave Doe wrote: So many variables. **Plane* for starters! Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Ummm, for starters plane comes in lighter after a flight..... *:-))) One other thing, I wouldn't have my trim set in the same spot on EVERY flight either :-))) as you allude above, more variables then just set trim and take off / land. I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Exactly. In one plane I fly, the white line is pretty much worn off beyond recognition. ( I find it later after landing) Where do you set it before first T/O ? -- Duncan.- Hide quoted text - There is a white line on the wheel, and I set it even with the indicator arrow, or...at a "neutral" position. (in other words, no trim) Mark Why would you think the take off mark on the trim wheel sets trim to neutral (whatever that means)? Why would you think it doesn't? I think it's clear enough what neutral means here. The trim is even with the elevator. Elementary concept. --- Mark Oh really? *It depends on how the airplane is rigged. Most are rigged for effective flight, not effective take off. You'd give away airspeed if the trim tabs, assuming you have them, are not in trail at cruise. I can further assure you in some airplanes, my Mooney for example, you could look at the horizontal stabilizer elevator combination for a long time and have no idea of the trim setting.- Hide quoted text - - Show quoted text - I tell ya what. Rather than me theorizing on why we do what we do at the academy, I'll call one of my instructors for a more definitive answer. *No one around tonight, I already called. *One is rated for jets, a former airline professional. *And my other one also flys Chinook helicopters for the Army. *Not having the checklist in hand I'm really commenting from memory. --- Mark I have not flown a 152 or 172 in some time. My training was, and practice in BFRs is, to use the trim to negate yoke pressure and that is what I do in the Mooney and among my friends at least the way they fly their complex singles. Your instructors may do it differently -- if so, I'd encourage you to find different CFIs Take off and climb speeds in these airplanes is markedly different than climb speeds, and I don't want to fly a XC holding yoke pressure or adjusting airspeed rather than trim. Moreover I descend most often at cruise speed, and would rather trim for that attitude than to spend 20 minutes coming down at 500 fpm from 11,000 feet holding forward pressure. You may choose to fly differently. If you're being taught differently see my 'find different' comment above. Start with a badly out of trim airplane and practice some under-the-hood recovery from unusual attitude stuff. It's simply adding difficulty. The Mooney, by the way, does not have trim tabs but can be trimmed. Other complex singles do have tabs. Set the trim on one for takeoff then look at the tab. You will likely find it out of trail. If you bother landing one without adjusting trim from cruise (I don;t know why you'd bother doing this, but never the less) unless the CG is close to limits you'll find it close to in trail position if the airplane is well rigged. I am a real pilot with a real airplane talking about my approach to the real practice of committing aviation safely. Others may have different techniques to trimming an airplane -- mine is not broken, so I choose not to change it, most especially when the authority quoted is based on someone's alleged 152/172 experience. |
interesting video of a takeoff and landing | John | Piloting | 7 | November 13th 07 01:19 AM |
Please adjust your trim settings. | Montblack | Owning | 17 | April 11th 07 08:04 PM |
Takeoff/Landing same direction? | Willie | Soaring | 24 | September 13th 06 04:47 AM |
Stuck at work--need takeoff/landing distances for a 172 please | Yossarian | Piloting | 12 | July 14th 05 01:12 PM |
Takeoff/Landing roll data | John Penta | Military Aviation | 4 | October 30th 03 04:18 AM |
