US Air Force Museum Batch 2 [01/64] - WPAFM batch 2 Index 1.jpg (0/1)
Old April 25th 10, 07:53 PM posted to alt.binaries.pictures.aviation
Morgans[_2_]
Default US Air Force Museum Batch 2 [01/64] - WPAFM batch 2 Index 1.jpg (0/1)
"Indrek" wrote ..
Here is the second, and last, batch.
I would like to make a comment about your photography, but take it in the
light of constructive criticizm, please.
I have no idea if others feel the same way about your pictures, so this is
my opinion alone.
I realize that this particular museum is real tough to get good
line-of-sight, but I wonder if you could have gotten better placement to
take the pictures. Unless you are taking a close up to show a detail of a
particular feature, I would like to a view that shows more of a side view,
or at least an angle that shows the front and back plane at the same time.
Just backing up would help, in many cases, or using a lens with a slightly
wide angle, like a 28mm.
Also, I do not know if you are allowed to take a two foot step ladder of
something of the sort into the museum, but getting a little higher would
help the viewpoint, also.
Again, thanks for posting your pictures, as there are a lot of shots of cool
planes. Perhaps you can improve your pictures by keeping some of my
suggestions in mind.
Thanks for the series.
Jim in NC
Old April 25th 10, 10:31 PM posted to alt.binaries.pictures.aviation
Giganews[_2_]
"Morgans" wrote in message
"Indrek" wrote ..
my opinion alone.
cool planes. Perhaps you can improve your pictures by keeping some of my
Jim in NC
Thanks for your feedback. You make some good points.
The physical realities of the location and equipment posed certain
difficulties.
I was using 18 mm focal length for most of the pictures, which is as short
was my 18-55 lens will go. Even if I had owned a shorter focal length lens,
I suspect the picture quality would have been impaired by spherical
distortion.
As I mentioned in the preamble to the first batch, the aircraft are packed
very close together, and it was next to impossible to get far enough away
from the aircraft to get a full profile view. It was also very difficult to
avoid parts of other aircraft intruding into the frame.
I did consider trying some shots taken with the camera just above the floor,
but that would have necessitated shortening the tripod legs each time, and
time was very short. The tour only allowed 40 minutes in the hangars so
there was not enough time to fiddle with the tripod legs. As for using steps
to get the camera higher, it's something that might have been possible, but
I'm not sure how much that would have enhanced the images. Certainly it
would have made using a tripod difficult. Given the available light, many
shots were in the half to one second exposure time range. I think shots from
a low angle would be much more dramatic...but that's just my opinion.
Anyway, thanks for the feedback and I will, of course, bear in mind what you
have said the next time I have the opportunity to take some museum shots.
Cheers,
Indrek Aavisto
Criticism is easy; achievement is difficult W.S. Churchill
Old April 26th 10, 12:48 AM posted to alt.binaries.pictures.aviation
Morgans[_2_]
difficulties.
lens, I suspect the picture quality would have been impaired by spherical
distortion.
Wow, that is already short. Nothing more you could do there.
to avoid parts of other aircraft intruding into the frame.
Yes, I realized that, too. I would rather see parts of other airframes, and
see the full profile. That's just me, perhaps.
floor, but that would have necessitated shortening the tripod legs each
time, and time was very short. The tour only allowed 40 minutes in the
hangars so there was not enough time to fiddle with the tripod legs. As
for using steps to get the camera higher, it's something that might have
been possible, but I'm not sure how much that would have enhanced the
images. Certainly it would have made using a tripod difficult. Given the
available light, many shots were in the half to one second exposure time
range. I think shots from a low angle would be much more dramatic...but
you have said the next time I have the opportunity to take some museum
shots.
That long of exposures would make a high view hard, without a super tall
tripod. Perhaps it would be better to go with a super fast film, and accept
the graininess. I dunnow.
I think above views are superior, in most cases, because that allows you to
see the wing plan better, and the cockpit. Who wants to see the greasy
underside of planes, anyway? g
Perhaps that was the best that could be done in that place. Too bad the
taxpayers won't spring for some more hangars to spread out the planes some
more.
Jim in NC
US Air Force Museum Batch 1 ] [01/47] - WPAFM Batch 1 Index 1.jpg (0/1) Indrek Aviation Photos 1 April 25th 10 04:42 PM
US Air Force Museum Batch 1 ] [03/47] - WPAFM Batch 1 Index 3.jpg (1/1) Indrek Aviation Photos 0 April 24th 10 12:30 AM
US Air Force Museum Batch 1 ] [02/47] - WPAFM Batch 1 Index 2.jpg (1/1) Indrek Aviation Photos 0 April 24th 10 12:30 AM
US Air Force Museum Batch 1 ] [01/47] - WPAFM Batch 1 Index 1.jpg (1/1) Indrek Aviation Photos 0 April 24th 10 12:30 AM
