Wow! I suspect they didn't hold that attitude for long ;-)
-- Mike Mackenzie (AVCOM Services) Brisbane, AUSTRALIA Remove "XYZ" from the "Reply to" address when responding by email. |
![]() "Mike Mackenzie" wrote in message ... Wow! I suspect they didn't hold that attitude for long ;-) -- Mike Mackenzie (AVCOM Services) Brisbane, AUSTRALIA Remove "XYZ" from the "Reply to" address when responding by email. I'm sure Glenn will let us know how he did it. I suspect it has to do with the lens used and his position on the field. Check out this Dakota, the write-up tells how he got it. http://www.airspacemag.com/flight-to...s-Head-On.html |
"Frydaddy" wrote (in part):
"Mike Mackenzie" wrote in message .. . Wow! I suspect they didn't hold that attitude for long ;-) -- Mike Mackenzie (AVCOM Services) Brisbane, AUSTRALIA Remove "XYZ" from the "Reply to" address when responding by email. I'm sure Glenn will let us know how he did it. I suspect it has to do with the lens used and his position on the field. Check out this Dakota, the write-up tells how he got it. http://www.airspacemag.com/flight-to...s-Head-On.html My comment was based on the apparent angle of climb, which I don't think has been exaggerated too much by the camera and/or lens. In your Texas example the pilot went to a lot of trouble using zoom momentum to achieve a near vertical attitude for a few secs before the speed bled off. The Kiwi one seems to be at about 30 deg attitude, which is reasonably easy to achieve - but you can't hold that for long even at full power with a near-empty aircraft. Makes a spectacular shot, though! -- Mike Mackenzie (AVCOM Services) Brisbane, AUSTRALIA Remove "XYZ" from the "Reply to" address when responding by email. |
Dakota | Glenn[_2_] | Aviation Photos | 2 | October 19th 09 06:38 AM |
Another Dakota - From NZ | Jack G[_2_] | Aviation Photos | 3 | April 10th 08 11:12 PM |
Dakota | Glenn[_2_] | Aviation Photos | 0 | December 15th 07 10:16 PM |
Dakota | Glenn[_2_] | Aviation Photos | 7 | July 21st 07 07:33 PM |
Dakota ZK-DAK | Glenn Alderton | Aviation Photos | 0 | January 1st 07 07:39 AM |
