replacement gas strut for wing wheel
Old April 26th 10, 10:29 PM posted to rec.aviation.soaring
Craig[_2_]
Default replacement gas strut for wing wheel
On Apr 26, 1:41*pm, sisu1a wrote:
I have a wing wheel with a German gas strut that I suspect needs to be
replaced. *On the side of the strut is printed
G8 1 80 1 265 AU19 AU19 250N /5/
The nominal uncompressed length is about 11" (28cm) with about
3" (7.5cm) strut showing. *Strut diameter is about 5/16" (7-8mm), and
the outside cylinder diameter is about 3/4" (19-20mm).
I would appreciate any input on specs/sources for a replacement strut.
I dont know your exact make and model, but I can decipher most of the
info in the serial number, which should make it easy to buy an
equivalent.
Our local NAPA store has a pretty good selection & I suspect they
should be pretty much the same nationwide (I'm assuming you're in the
US). Might try there.
Craig
G8 * * * * * * *=? * (prolly determines end termination style-
eyelets, yolks, etc, you know what you need here)
1 80 1 * * * * =80mm stroke
265 * * * * * * =265mm uncompressed length (measured center to center
on the eyes)
AU19 AU19 = body is 19mm diameter (standard dia, not sure why appears
twice though...)
250N * * * * *= 250 newton force (roughly 50lbs...)
/5/ * * * * * * *=? * (possibly the bolt/clevis diameter for the
eyelets, possibly the number assigned to its compressive non-
linearity)
This should be enough info to find a suitable replacement though, and
after all it's just a wingwheel...
-Paul
If i
Cobra Trailer Replacement Wheel Chip Bearden Soaring 5 September 29th 09 08:35 PM
Replacement nose wheel pant for 1971 172 [email protected] Owning 1 May 9th 07 11:23 PM
Lunar Roving Vehicle (LRV) Wheel Strut 7020263.jpg [email protected] Aviation Photos 0 April 10th 07 02:46 PM
Granville's Strut Seal - Or Other Strut Maintenance Techniques zatatime Owning 4 August 31st 05 04:30 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
