Gap Tape For Sale
Old April 27th 10, 09:01 PM posted to rec.aviation.soaring
Andy[_1_]
Default Gap Tape For Sale
On Apr 26, 8:44*pm, ContestID67 wrote:
Wanting to put my two cents in, I bought a box of this tape and it is
very good stuff. *Stretches well around curves and such. *A great
value for the cost. *The ONLY negative is that it is in fact single
use only - so I have a expensive roll for multi-day needs - but the
seller lets you know that defact up front. *Oh, and it isn't a pretty
white-white-white, its a tiny bit grayish. *But heck, for this price
I'd even use it if it was black-black-black. *For a $1 a roll, give it
a try.
What do you mean by "single use"? What did the OP mean by "one day"
use?
Some cheap tapes leave a horrible residue, others creep badly and also
leave a horrible residue, some go brittle in the sun. What is the
problem with this stuff?
I use 3M electrical tape. I use it only once although it is possible
to re wind it and use it several times if you are really cheap. It
used to be really good and leave no residue. They seem to have
changed the adhesive because now it leaves a residue after only being
on the glider for 2 days.
Andy
Old April 27th 10, 10:14 PM posted to rec.aviation.soaring
ContestID67[_2_]
Here is my take on this tape. Good stuff. I have never had a
problem. It doesn't get brittle. It doesn't creep. It stays where
you want it to and goes around complex bends. It comes off when you
want it to and doesn't leave any gooey residue...unless you leave it
on for something on the order of 2 weeks. Even then the adhesive
wasn't nasty to remove.
3M stuff is good but I have only been able to find 1/2" and I think
that 3/4" wide is the minimum to seal up a glider. My $0.02.
- John
FS: Gap Tape TJ[_1_] Soaring 2 September 6th 08 05:49 AM
Gap Tape for sale TJ[_1_] Soaring 1 April 27th 08 11:20 AM
Gap Tape for sale TJ[_1_] Soaring 1 October 1st 07 06:19 PM
For Sale: IN THE COCKPIT VHS VIDEO SERIES - 6 Tape Series [email protected] Aviation Marketplace 0 November 2nd 06 04:12 PM
For Sale: IN THE COCKPIT VHS VIDEO SERIES - 6 Tape Series [email protected] Products 0 November 2nd 06 04:07 PM
