We had a damaged/worn-out tail battery in our club DG1000S.
We ordered a replacement from DG at a very high cost. After that I disassembled the original. It consisted simply of 4 Panasonic LC-R067 R2P (6Volt, 7.2 Ah) batteries. 150mm x 94 mm x 34mm each. Switched 2 serial x 2 parallel for a total of 12V, 14.4 Ah. All of it is simply double-sided taped to eachother and to a flat aluminum strip ending in the bracket with fuse, connector and grip on top. Then heat shrink wrapped. Would have been very easy to replace yourself with some very basic handyman experience at a cost of about US$75. Hans Van Weersch |
restraining oxy bottle in a DG1000 | Pawnee Pilot | Soaring | 3 | November 19th 09 08:49 AM |
DG1000/2 | Frank Whiteley | Soaring | 10 | December 12th 08 05:14 PM |
DG-1000 Tail Battery Connector. Where to get one? | Jeremy Zawodny | Soaring | 7 | January 4th 07 02:50 PM |
Video or the DG1000 spin in | Mal | Soaring | 5 | September 12th 04 07:41 AM |
Duo Discus vs. DG1000 in a stall? | Gldcomp | Soaring | 2 | September 2nd 04 09:24 PM |
