On Apr 29, 1:07*pm, "bds" wrote:
"Tony" wrote wing tanks or header tank? *has there been any consistency in fuel level during these events? ive had engine problems in airplanes with header tanks at extreme nose up attitudes and low fuel levels. *your "negative G" towpilot could be on to something. is there an engine driven fuel pump on the pawnee, even with a header tank? *have you checked to make sure it is working? ive had a valve stick (on a cessna 150) and it was VERY noticeable, not "very slight" roughness. ********************* It has a header tank but the problem occurs regardless of fuel level. *If anything, it is almost always full or at least half full when the problem occurs. I think part of the reason that the roughness isn't as bad on the 0-540 is because you're losing 1 out of 6 instead of 1 out of 4 when a valve sticks. Bruce fair enough. does it happen only on tow or sometimes off tow too? one towpilot mentioned negative G's as a possible trigger. I wouldn't rule out fuel delivery issues. with a header tank, possibly coupled with a weak or not working engine driven fuel pump (assumption), you could have issues when a glider pilot starts to yank the tail up or if your towpilots like to dive away after tow release. |
To Pawnee or not to Pawnee...that is the question... | Travis Beach | Soaring | 56 | March 24th 14 06:21 AM |
Looking for Pawnee | [email protected] | Soaring | 1 | July 13th 08 12:35 AM |
To Pawnee or not to Pawnee...that is the question... | Travis Beach | Soaring | 4 | October 17th 07 01:31 PM |
PA-25 PAWNEE | Rafgsa Centre | Soaring | 2 | March 3rd 05 03:13 AM |
Pawnee | Damien Dyer | Soaring | 2 | November 2nd 04 05:35 PM |
