Tarver, you were "totally" wrong in your original response dated Nov
8th, 2002 about T-56's and TIT. I can't speak for other motors but I do know a T56-14 pretty well and have changed enough t-couples and enough TIT gauges and done hundreds enough efficiency runs and calculations to know that it is actually "Turbine Inlet Temperature". You have since tried to tap dance around being put on the spot, too funny! I got one for you, Mr. T-56, how can T-56 efficiencies sometimes be measured at over 100%??? And what are the test cell limits and the allowable differences between test cell runups and on the wing measurements? What are the allowable differences between flights? Ok, Mr. T-56, Lets hear your expalnation on this? How many t-couples on a T-56 have you actually changed out? How many hours, days etc. have you actually spent chasing an efficiency problem? On Wed, 21 Jan 2004 18:28:29 -0800, "Tarver Engineering" wrote: "Scet" wrote in message ... snip Yep, an averaged TIT signal on a T56. Nope, only an idiot would devide the Total. To devide would only increase the complexity and reduce reliability. Are you a janitor, by any chance, Scat? |
![]() "fudog50" wrote in message ... Tarver, you were "totally" wrong in your original response dated Nov 8th, 2002 about T-56's and TIT. Nope, but thanks for playing. Did you figure out that sailors call those things you think are "ships", "boats" yet? I mean, Funny dude, if you can't figure out what is going on right where you are, how can we believe anything you write about what is farther away? "Turbine Inlet Temperature". Turbine inlet temperature is a linear function, my idiot. |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Hercules Engines | Tarver Engineering | Home Built | 0 | January 19th 04 11:05 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
