I was simply surprised that the proposed answer to a not very specific
route question was that the "only" viable route involved a VOR and an airway, when the OP had not said anything about the type of flight or their preferences. This is simply not true, and as such could not be considered good advice. I should not have been surprised, because the response came from a non-pilot, so by definition one who is not used to flying. While there’s nothing "wrong" with the route proposed (the whole argument being a complete fabrication by MX) a more complete response might have been something like : "What kind of flight do you wish to make? If VFR, and not enthused about scud running under 1500’ over missile-firing ranges, you’ll want to plan to remain south of the Restricted areas west of Phoenix, or give a call to get cleared through them. Don’t assume you’ll get cleared though, as some of them have 'continuous' status, so you may have to just avoid them. Same goes for IFR and GPS-Direct. You can file it, but you may get the airway V66 instead. If you don’t want to bother with the restricted areas, just file the airway, or if VFR, keep south of these areas, or fly the airway." So, while there’s nothing wrong with V66, there is just everything wrong with MX’s initial response, and his ensuing vituperative argument. No wonder of it - those who do not fly airplanes and whose only references to aviation are a computer screen and some out of date textbooks will clearly not develop the reflex and practices of pilots. In article , says... On May 4, 11:16*am, Blanche wrote: And strangely enough (and I can't believe I'm saying this) Mx has made a perfectly reasonable route suggestion. While the route suggestion is perfectly reasonable, his response to VOR DME was not. |
On May 5, 10:09*am, VOR-DME wrote:
I was simply surprised that the proposed answer to a not very specific route question was that the "only" viable route involved a VOR and an airway, when the OP had not said anything about the type of flight or their preferences. This is simply not true, and as such could not be considered good advice. I should not have been surprised, because the response came from a non-pilot, so by definition one who is not used to flying. Also, if your training was like mine, in VFR training, I wasn't trained how to set up my Navs for airway navigation. Yes, I was trained on tracking a radial TO a VFR during my VFR training but that's it. The purpose of that was to help me get to a point on the sectional to locate myself should I get lost. To figure out where I was in relationship to a VOR, my instructor showed me how to use the FROM flag. Between the FROM flag and DME, I was able to figure out where I was in relationship to the VOR. I think your response was spot on with using GPS. This is the wave of the future for VFR navigation and in my neck of the country, it's the preferred method for IFR. Almost without exception, when I filed airways, I got a "would you like direct" question from ATC. The one time I wasn't equipped for /G (My GPS antenna become uncoupled) ATC offered me a 168 mile vector which I graciously accepted as airways put me out 50 miles off my direct routing. I did not learn how to track airways until I started my IFR training Most importantly, there is nothing unsafe about OROCA or MORA navigation providing all tools are used in flight planning as Mx implies. This applies to my flatlander flying, I can't say anything about mountain flying as that I would stay on airways for IFR ops. |
VOR-DME writes:
So, while there’s nothing wrong with V66, there is just everything wrong with MX’s initial response, and his ensuing vituperative argument. In other words, I was right, but your personal animosity towards me made it impossible for you to accept that fact. If you allow yourself to consider the messenger more important than the message, you make yourself vulnerable to manipulation. Demogogues know all about this. No wonder of it - those who do not fly airplanes and whose only references to aviation are a computer screen and some out of date textbooks will clearly not develop the reflex and practices of pilots. What reflexes do you need to develop a flight plan? |
On May 5, 3:29*pm, Mxsmanic wrote:
Individual clouds are not part of flight planning, since you don't know where they are or what they will be like until you encounter them. UMMM WRONG....... Flight planning DOES NOT stop after starting the engine. But it's obvious you don't know this. |
I plan as I would for a real-world flight and then fly that in the sim. What flight planner do you use???? |
KMYF TWR Radio prblms 62204 approx2315z | Doug | Piloting | 5 | June 24th 04 06:53 AM |
