On May 5, 10:19*am, Mark Jardini wrote:
Andy Avionic does not have a "jacked ramp". The cradle has an over center cam that lifts the aircraft off its main wheel. Agreed, the jack would be better for rigging purposes. The belt can be seen and inspected through it s length. The center portion of the mast is enclosed trapping the belt within by some mid shaft cross sectional enclosings. I can only assume this is one of those fiberglass impregnated toothed belts they use in cars that last 60k miles. My guess would be you send the mast back to be opened and reclosed or you buy a new one..... Mark And for those Cobra trailers with hydraulic jacked ramps and heavy motorgliders, I'd rather trust the hand cranked gears in my one-man rigger or the person holding my wingtip than trust the hydraulic jack with the weight of my motorglider while tweaking the jack height. I slide in a triangular wooden block as a safety device under the ramp scissors. If the jack fully collapses, I don't think the jack has the leverage to jack up mu ASH-26E again. Darryl |
I've routinely used the hydraulic jack to align the wing pins on my
ASH-26E. And to keep the wings at a comfortable height, that means it's operating near the bottom of its range. Really nice during disassembly to have one hand on the jack and the other on a main pin, then slowly lower the fuselage until the pin starts to rotate. I did disassemble the jack assembly recently to replace an O ring in the jack. The base plate was warped due to the horizontal force being applied to lift the glider from a completely lowered jack. Straightened it out in a hydraulic press, and might try to reinforce it next winter, but it will likely last another 5-10 years if I do nothing. -Tom On May 5, 11:09*am, Darryl Ramm wrote: And for those Cobra trailers with hydraulic jacked ramps and heavy motorgliders, I'd rather trust the hand cranked gears in my one-man rigger or the person holding my wingtip than trust the hydraulic jack with the weight of my motorglider while tweaking the jack height. I slide in a triangular wooden block as a safety device under the ramp scissors. If the jack fully collapses, *I don't think the jack has the leverage to jack up mu ASH-26E again. |
On 5/5/2010 11:09 AM, Darryl Ramm wrote:
And for those Cobra trailers with hydraulic jacked ramps and heavy motorgliders, I'd rather trust the hand cranked gears in my one-man rigger or the person holding my wingtip than trust the hydraulic jack with the weight of my motorglider while tweaking the jack height. I slide in a triangular wooden block as a safety device under the ramp scissors. If the jack fully collapses, I don't think the jack has the leverage to jack up mu ASH-26E again. I routinely lower my Cobra hydraulic ramp jack to the bottom to assemble my ASH 26 E. It has no problem raising the fully assembled glider from the bottom to the height needed to lower the gear. I've done that for over 400 rig/derig cycles. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Apis M pictures | Robertmudd1u | Soaring | 0 | February 20th 04 06:40 PM |
Apis M has arived | Robertmudd1u | Soaring | 0 | January 31st 04 01:50 AM |
Apis report | Apis Gliders | Soaring | 0 | September 10th 03 08:34 PM |
Apis goes East | Apis Gliders | Soaring | 0 | September 3rd 03 02:01 PM |
Apis at Oshkosh | Apis Gliders | Soaring | 0 | July 21st 03 03:34 AM |
