Blanik Control Bridge AD
Old May 5th 10, 01:05 PM posted to rec.aviation.soaring
Mike[_28_]
Default Blanik Control Bridge AD
What are your experiences with the time required to complete this AD?
The AD itself says two hours. Any tips or tricks? I'm not an AP but
the one we use says it can take several hours w/alot of contortions
invovled.
Old May 5th 10, 02:31 PM posted to rec.aviation.soaring
nimbus
invovled.
We needed about halve a day for replacing the Control Bridge.
We know our hardware wery well, we are good technician, we have the
knwoledge "how to..".
Of course we were not in a hurry but we still needed about halve a
day.
Cheers,
Bruno
Old May 5th 10, 03:30 PM posted to rec.aviation.soaring
I think to do a proper job, you need to remove it from the aircraft.
I agree with two people, it is about a day.
Trying to get a new bridge may not be easy, still waiting for a
quote. If you have an L-23, I have heard a new bridge terminates the
repetive inspection part of the AD.
aerodyne
Old May 5th 10, 03:48 PM posted to rec.aviation.soaring
nimbus
quote. *If you have an L-23, I have heard a new bridge terminates the
aerodyne
I had to buy a new one. It cost about 880 Euros. What I bought is just
the "bridge" not the sticks associated to it.
In cases of cracks the AD stated that the bridge has to be replaced.
Replacement means that the old cracked bridge has to be removed.
Removing the old bridge takes about 90 minutes. Installing a new one
takes a little more because there are many little screws here and
there...
Bruno
Old May 5th 10, 05:31 PM posted to rec.aviation.soaring
Mike[_28_]
How about just the dye inspection w/o having to replace the parts?
Still half a day?
Thanks
Old May 5th 10, 08:50 PM posted to rec.aviation.soaring
Yes, at least half a day for two people, assuming you have not done it
before.
Cause you wouldn't be asking otherwise, right?
aerodyne
Old May 5th 10, 09:35 PM posted to rec.aviation.soaring
nimbus
before.
aerodyne
Doing inspection with dye takes 20 min. If there are cracks, you will
see it immediately !
I was surprised to discover those cracks forcing me to replace the
whole control bridge.
Cheers,
Bruno
Old May 6th 10, 04:49 AM posted to rec.aviation.soaring
Cheers,
Bruno
Don't assume the cracks will be that large to be easily seen espcially
if you leave the bridge in. I have seen a case where the dye check
was inconclusive, but the dye pen ran inside the tube right through
the edge of the weld! This was only found when the part was on the
bench in bright light, with a magnifier as called for in the AD.
aerodyne
Old May 6th 10, 08:19 AM posted to rec.aviation.soaring
nimbus
Cheers,
Bruno
if you leave the bridge in. *I have seen a case where the dye check
the edge of the weld! * This was only found when the part was on the
* aerodyne
Well....on my Blanik, cracks were huge ones.... so the conclusion was
easy to take...unfortunately....
Bruno
Old May 6th 10, 12:55 PM posted to rec.aviation.soaring
Mike[_28_]
So, y'all telling me that the Feds have grossly underestimated the
time (and therefore the cost) of completing the AD? Astonishing! Oh,
well it is what it is. Anyone want to buy an-out-of annual L13?Thanks.
Mike
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Blanik L-13 & TN L105 about inspection on control bridge nimbus Soaring 3 November 1st 09 07:53 AM
Old pics - new scans 3 - Than Hoa bridge after LGB strike - note adjacent pontoon bridge Dave Kearton Aviation Photos 0 January 15th 08 09:47 PM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
