On Topic
Old May 12th 10, 11:23 PM posted to rec.aviation.piloting
Jim Logajan
Default On Topic
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote:
"Peter Dohm" wrote in message
With the quest for efficiency, in recent years, most of the newer
tri-gear designs have featured free castering nose wheels. That has
certainly reduced the aerodynamic drag of the nose wheel;
Moving it to the back and reducing the size by a factor of 4 would do
even more...
Vans RV-6, 7, 8, and 9 experimentals can be built with tricycle gear and
conventional gear.
Without cheating and looking at the advertised performance difference
between the two gear choices at identical power settings, what would either
of you guess the percentage difference in speed might be?
Old May 13th 10, 02:07 AM posted to rec.aviation.piloting
Default On Topic
"Jim Logajan" wrote in message
even more...
conventional gear.
either
Two or three?
Or are you going to tell me that the nosewheel with wheel pants and a
fairing is faster than the tailwheel hanging out in the breeze?
Sure, go ahead, try to destroy our hopes, our dreams, our pre-concieved
misconceptions just for the sake of reality.
Geoff
When immigration is outlawed, only outlaws will immigrate
Old May 13th 10, 03:22 AM posted to rec.aviation.piloting
Jim Logajan
Default On Topic
even more...
conventional gear.
either
Two or three?
About 1 percent. At most 1.5%. The "A" models have the nosewheel, so here
are the performance figures Van's claims (I've read others say that he is
pretty honest about the performance numbers he lists):
http://www.vansaircraft.com/public/rv-6per.htm
http://www.vansaircraft.com/public/rv-7per.htm
http://www.vansaircraft.com/public/rv-8per.htm
http://www.vansaircraft.com/public/rv-9per.htm
I think the RV-9 compared with the RV-9A at 118 HP, 55% power, and gross
weight shows the largest percent difference at about 1.4% faster for
conventional gear. Oddly, all the aircraft show about 2 mph difference,
regardless of power setting.
No hopes, dreams, or pre-conceived misconceptions shattered, alas, but
perhaps beaten up a bit, eh? :-)
Old May 13th 10, 12:23 PM posted to rec.aviation.piloting
Mark
Default On Topic
tri-gear designs have featured free castering nose wheels. *That has
even more...
conventional gear.
either
Two or three?
http://www.vansaircraft.com/public/r...ic/rv-9per.htm
Well, at least there's always several RV-6s on the market at all
times, some very reasonable. Here's one from an estate sale.
They're only asking 45. You could offer 39 and take it from there.
http://barnstormers.com/listing_images.php?id=345031
Mark
Old May 13th 10, 11:59 PM posted to rec.aviation.piloting
Default On Topic
LOL....
Thanks. I needed that.
Geoff
Old May 13th 10, 07:16 PM posted to rec.aviation.piloting
Peter Dohm
Default On Topic
even more...
conventional gear.
either
Well, it's more than a year too late for me to avoid cheating in that way.
However, the advertised difference is around 2 knots; which is about 1/2 or
what I would have guessed before I looked.
But, that reduced difference in cruise performand was gained at the expense
of nowe wheel steering. So what we are really comparing on the RV-6, 7, 8,
and 9 models is a fully faired and free castering nosewheel versus an
unfaired and fully steerable tailwheel. So the ground handling advantage
does not automatically go to the nosewheel version.
On a more apples for apples comparison, when the lowly and "draggy" Cessna
150 and 152 are converted from a steerable oleo strut type nosewheel to a
steerable tailwheel, they are reputed to gain at least 8 knots.
Those are the reasons that I find myself willing to advocate for the
tailwheel.
Peter
Old May 14th 10, 02:21 AM posted to rec.aviation.piloting
Brian Whatcott
Default On Topic
Peter Dohm wrote:
... when the lowly and "draggy" Cessna
Peter
Hmmm...is this a comparison of a straight tail, no rear window, tail
wheel C150 and a nose wheel C-150, or are there are a few other little
details on a late model conversion, like wind LE cuffs, turbulators
etc., etc.
8 kts difference sound a little high to me, but I am willing to be
persuaded! :-)
Brian W
Old May 14th 10, 04:46 PM posted to rec.aviation.piloting
Peter Dohm
Default On Topic
"brian whatcott" wrote in message
Peter Dohm wrote:
... when the lowly and "draggy" Cessna 150 and 152 are converted from a
steerable oleo strut type nosewheel to a steerable tailwheel, they are
Peter
Hmmm...is this a comparison of a straight tail, no rear window, tail wheel
C150 and a nose wheel C-150, or are there are a few other little details
on a late model conversion, like wind LE cuffs, turbulators etc., etc.
persuaded! :-)
Brian W
No, it relates to my best recollection (that is possibly less than complete)
of the before and after performance for a Teas Taildragger conversion--which
removed the complete nosewheel assembly, added a steerable tailwheel, and
relocated the original main gear assembly to position forward of the wing
strut attachments.
That was reputed to drastically improve the cruise performance and provide
an accessible means for tailwheel training--during a time when tailwheel
trainers were in reportedly short supply. To the best of my recollection,
there was some critisism of the conversion in the case of the C152 and of
the L amd M models of the C150 because of the softer and slightly lower and
wider main gear--which alledgedly made it possible to compress the main gear
enough to strike the propeller during a hard landing.
Peter
Old May 14th 10, 02:30 AM posted to rec.aviation.piloting
Ron Wanttaja[_2_]
Default On Topic
Nosewheel RV-6A has a higher rate of pilot loss of control than the
taildragger RV-6.
Old May 14th 10, 03:16 AM posted to rec.aviation.piloting
Jim Logajan
Default On Topic
Cessna 150 and 152 are converted from a steerable oleo strut type
nosewheel to a steerable tailwheel, they are reputed to gain at least
8 knots.
I can believe that - and for anything with tires large enough for bush
flying I can see nosewheel reducing the performance much more than the RV
series, which do have more svelt nose gear and struts.
Also, I know that some other experimentals (like Kitfox) can be built in
either nosewheel or conventional gear, but I haven't searched for any
performance comparisons between two such planes that differ only in gear.
Besides, builders tend to make other changes in their homebuilts that
muddle direct comparisions.
tailwheel.
So far I've only flown and landed an aircraft with one tire (glider) but
when loaded the CG moves forward of the tire, but with no one on board the
SGS 2-33 settles back on its tail, indicating the CG moves aft of the tire.
(Okay okay - technically the 2-33 has 4 wheels! Two small rollers near the
wingtips and a small one on the tail, plus the main tire. And there is a
skid forward of the main tire.)
Off-topic Q D Ramapriya Piloting 17 July 23rd 09 04:30 AM
Off-topic, but in need of help Alan Erskine Aviation Photos 20 January 5th 07 06:21 AM
Almost on topic... Richard Lamb Home Built 22 January 30th 06 06:55 PM
off topic, just a little--maybe? L.D. Home Built 5 August 27th 05 04:56 PM
off topic Randall Robertson Simulators 0 January 2nd 04 01:29 PM
