On May 17, 1:16*pm, Mxsmanic wrote:
writes: In fact, you can't even say you are a proficient pilot. *Maybe a proficient MSFS pilot, but not a pilot of a real plane. Practically the same thing. And what experience do you have to support this opinion?????? :YOUR experience please in flying real airplanes. Or are you going to continue to demonstrate you are not a credible source for flying real airplanes As stated in another thread, the two are not the same (MSFS and real life piloting an airplane) Not identical, but very close. And what experience do you have to support this opinion?????? :YOUR experience please in flying real airplanes. Or are you going to continue to demonstrate you are not a credible source for flying real airplanes Demonstrates you are not a credible source for flying real airplanes. See above. See above. Above demonstrates you are not a credible source for flying real airplanes You don't fly a real airplane do you? Not currently. Above demonstrates you are not a credible source for flying real airplanes |
On May 17, 3:16*pm, Mxsmanic wrote:
writes: And what experience do you have to support this opinion?????? *:YOUR experience please in flying real airplanes. What experience do you have to support your opinion. Your experience in simulation? I have MSFS 10. I fly a Beech Sundowner and now will be going back to Cessnas (sold my plane). I ASKED A VERY DIRECT QUESTION that you FAILED TO ANSWER. What REAL plane do you fly to support your opionion. I can support point by point the difference between MSFS and a real plane (I have already mentioned one). What can you provide???? You answering with questions doesn't show credibility that you know what you are talking about does it? It only shows you diverting the problem at hand that you do not know what it takes to fly a real plane. |
On May 17, 4:20*pm, " wrote:
On May 17, 3:16*pm, Mxsmanic wrote: writes: And what experience do you have to support this opinion?????? *:YOUR experience please in flying real airplanes. What experience do you have to support your opinion. Your experience in simulation? I have MSFS 10. *I fly a Beech Sundowner and now will be going back to Cessnas (sold my plane). I ASKED A VERY DIRECT QUESTION that you FAILED TO ANSWER. What REAL plane do you fly to support your opionion. *I can support point by point the difference between MSFS and a real plane (I have already mentioned one). *What can you provide???? You answering with questions doesn't show credibility that you know what you are talking about does it? *It only shows you diverting the problem at hand that you do not know what it takes to fly a real plane. There are several different 'models' of the world here. Many here, including you, experienced something like this "Outer Marker Inbound" "Contact tower now, on nnn.m" "Going to nnn.m, thanks" tower says visibility a half mile, ceiling 250 feet, winds 20 gusts 30 at 140 degrees, and you're inbound to runway 10. That's a serious crosswind. hand fly down, needles pretty much where they should be, very bumpy, very dark. The missed approach is memorized, a decision already made that the alternate, 150 miles away, is what'll happen if the airport environment isn't in sight at minimums Through 230 feet agl, big bounces, and there are the lead in strobes, 15 degrees from where the airplane is pointing, exactly where I thought they'd appear. Transition to visual, carry an extra 8 knots into the flare, only 20 degrees of flaps, and I start sucking them up going into the flare, because I want this thing to be done flying when it's on the runway. The upwind wheel makes contact, then the other main. Flaps retracted (I know my airplane well enough, and verify time and again my finger is on the flap control. Roll out turn off, get to my tiedown, shut down, tie that baby down in driving rain, get soaked, get into the car, as high on.Maslow's hierarchy as one can get, and drive home to a loving wife and a glass of wine. Then there's MSFS: Coming up on a simulated 400 feet agl, no buffeting, not feeling the yoke alive in your hands, not having the sensation of a wing lifting in a gust, the only evidence of a wind shear being what? change in indicated airspeed, change in indicated pitch, with no physical sensations to play with your senses? To my mind, and I am sure yours, there is a significant difference in the physiological and psychological rewards between the two models. It is not easily explained to someone who has experienced our real world. It's his loss. |
a writes:
There are several different 'models' of the world here. Many here, including you, experienced something like this "Outer Marker Inbound" "Contact tower now, on nnn.m" "Going to nnn.m, thanks" tower says visibility a half mile, ceiling 250 feet, winds 20 gusts 30 at 140 degrees, and you're inbound to runway 10. That's a serious crosswind. hand fly down, needles pretty much where they should be, very bumpy, very dark. The missed approach is memorized, a decision already made that the alternate, 150 miles away, is what'll happen if the airport environment isn't in sight at minimums Through 230 feet agl, big bounces, and there are the lead in strobes, 15 degrees from where the airplane is pointing, exactly where I thought they'd appear. Transition to visual, carry an extra 8 knots into the flare, only 20 degrees of flaps, and I start sucking them up going into the flare, because I want this thing to be done flying when it's on the runway. The upwind wheel makes contact, then the other main. Flaps retracted (I know my airplane well enough, and verify time and again my finger is on the flap control. I did this, too, a few flights ago. What's different? Roll out turn off, get to my tiedown, shut down, tie that baby down in driving rain, get soaked, get into the car, as high on.Maslow's hierarchy as one can get, and drive home to a loving wife and a glass of wine. My simulation stops with the tiedown, which is exactly where I prefer it to stop. Coming up on a simulated 400 feet agl, no buffeting, not feeling the yoke alive in your hands, not having the sensation of a wing lifting in a gust, the only evidence of a wind shear being what? change in indicated airspeed, change in indicated pitch, with no physical sensations to play with your senses? Which version of MSFS are you using? I get most of that except for the physical sensations. To my mind, and I am sure yours, there is a significant difference in the physiological and psychological rewards between the two models. It is not easily explained to someone who has experienced our real world. It depends on what you get out of flying. |
On May 17, 4:09*pm, a wrote:
There are several different 'models' of the world here. Many here, including you, experienced something like this "Outer Marker Inbound" "Contact tower now, on nnn.m" "Going to nnn.m, thanks" tower says visibility a half mile, ceiling 250 feet, winds 20 gusts 30 at 140 degrees, and you're inbound to runway 10. That's a serious crosswind. hand fly down, needles pretty much where they should be, very bumpy, very dark. The missed approach is memorized, a decision already made that the alternate, 150 miles away, is what'll happen if the airport environment isn't in sight at minimums Through 230 feet agl, big bounces, and there are the lead in strobes, 15 degrees from where the airplane is pointing, exactly where I thought they'd appear. Transition to visual, carry an extra 8 knots into the flare, only 20 degrees of flaps, and I start sucking them up going into the flare, because I want this thing to be done flying when it's on the runway. The upwind wheel makes contact, then the other main. Flaps retracted (I know my airplane well enough, and verify time and again my finger is on the flap control. Roll out *turn off, get to my tiedown, shut down, tie that baby down in driving rain, get soaked, get into the car, as high on.Maslow's hierarchy as one can get, and drive home to a loving wife and a glass of wine. 'nuf said...... Just reading it brings back the feelings that I have been there and done it. And I have..... It's his loss. Amen fellow PILOT. |
On May 17, 5:10*pm, Mxsmanic wrote:
writes: It only shows you diverting the problem at hand that you do not know what it takes to fly a real plane. Which things does it take that I don't know? Yet another question answering a question. Your answer is above. Detail must not be your forte. |
On May 17, 6:10*pm, Mxsmanic wrote:
Which aircraft do you fly in MSFS, and where did they come from? Toys-R-Us. --- Mark |
On Tue, 18 May 2010 06:14:55 -0700 (PDT), Mark wrote:
On May 17, 6:10*pm, Mxsmanic wrote: Which aircraft do you fly in MSFS, and where did they come from? Toys-R-Us. --- Mark *TIC, TOC, Tic..* -- A fireside chat not with Ari! http://tr.im/holj Motto: Live To Spooge It! |
Simulators | Birdog | Piloting | 33 | March 9th 09 10:46 PM |
PC IFR simulators | Nick Kliewer | Instrument Flight Rules | 20 | November 2nd 06 08:16 AM |
Simulators | [email protected] | Simulators | 1 | October 20th 04 09:12 PM |
IFR simulators | Tony | Owning | 8 | October 27th 03 08:42 PM |
IFR simulators | Richard Kaplan | Instrument Flight Rules | 3 | July 24th 03 03:53 AM |
