TINSFOS question
Old May 24th 10, 10:24 PM posted to rec.aviation.soaring
Default TINSFOS question
On May 23, 11:06*pm, Steve Leonard wrote:
If the plane has flaps, and you don't run the ailerons on out, you
probably won't be able to use all or any of the negative flap for
higher speed running. *The LS-3/17 manual says "Thou Shalt Not Use ANY
negative flap if you installest thy long tips." *They didn't put
ailerons on their tips. *The Nimbus 3 manual says "Thou shalt limit
the flap travel to -2 (block thy "S" position) if you increase the
span from 24.5 to 25.5 meters. *Why? *As Hank said, if you run the
flaps up and don't have aileron (interconnected with the flaps, of
course) on the extension, the tips pick up a LOT of load, as they are
at a much higher angle of attack than the rest of the wing.
If the plane does not have flaps, adding aileron will only complicate
your life.
The poly wing actually helps the plane "groove" a bit more in
thermals. *It can also have the benefit of pushing the downwash field
down and outboard at the tips, potentially providing a small increase
in effective span. *Or maybe, less of a decrease in effective span as
compared to a planar wing. *And if your tip chord gets really small,
it makes it so you are less likely to drag three feet of wing on the
ground if a wing goes down on takeoff.
My nickels worth,
Steve
I was once told, by someone who is likely to know, that S-H put the
poly in the tips to keep them from ground contact loads and then
discovered it made the glider fly better. Not sure if this is true,
but it makes sense. Driving the outer aileron in one direction(up)
with spring down can allow poly and disconnects the mass which
simplifies the flutter issue-provided extension ailerons are properly
mass balanced.
In any case, they look cool.
UH
Old May 24th 10, 10:52 PM posted to rec.aviation.soaring
Brad[_2_]
your life.
My nickels worth,
Steve
mass balanced.
UH
I suppose if I can make the whole damn glider, I can make tips with
control surfaces! But.............that's down the road a ways. I
agree, they look really cool and the polyhedral will make good use of
the wing tip wheel I installed.
Brad
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Question about KLN-89B Casey Wilson Instrument Flight Rules 9 March 8th 04 08:07 PM
TINSFOS - looking for a Nimbus T in Europe somewhere tango4 Soaring 0 October 2nd 03 09:14 PM
