Pneumatics Question
Old May 25th 10, 04:42 AM posted to rec.aviation.soaring
Darryl Ramm
Default Pneumatics Question
On May 24, 8:22*pm, sisu1a wrote:
Kestrel 19, two static ports in the tail boom, pitot and TE in the
fin. *The TE line is split under the seat using a Y connector and then
travels to two varios (a Winter mechanical and a 1990-era audio/final-
glide called a VariCalc). *Pitot and static lines are split behind the
panel using T connectors.
I replaced all the non-permanent tubing last year and they all seemed
to be leak-free.
Tailboom static. Prolly used to work OK till you fixed the leaks.
Simple test. Unplug the static tee from the tailboom source and let it
use cockpit air. Fly the ship and try to recreate the creeping
readings while using cockpit static. Lots of older ships had their
tailboom statics relocated due to errors induced at that location. At
least it's an easy test...
-Paul
He has a TE. Neither vario should be connected to a static source. The
old VariCalc I beleive have a single TE connection and is a direct
reading type electronic vario (no capacity flask).
Darryl
Old May 25th 10, 05:12 AM posted to rec.aviation.soaring
sisu1a
Tailboom static.
-Paul
Darryl
POOF! (the sound of me vanishing in a puff of logic...)
Old May 25th 10, 05:14 AM posted to rec.aviation.soaring
Mike the Strike
What Tuno said......
Mike
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Question re CNX-80 ROBIN FLY Instrument Flight Rules 6 April 15th 04 04:05 PM
Question about KLN-89B Casey Wilson Instrument Flight Rules 9 March 8th 04 08:07 PM
